Question about Samsung Refrigerators
Samsung RB217ABRS stainless steel single door. No power! Receptacle has power. Light in fridge not coming on. Fuse?
I have a Samsung RB217ABRS a friend left the freezer drawer open and the compressor ran and ran. Now no power, light inside does not coming on. Power okay to unit. Where is the fuse located so I can check it??
  • 66 Answers
SOURCE: Handle to freezer on french door fridge
if the butter fly clip is brroken . you need to change the door. other than that you can replace the handle only. with the butter fly clip. parts cast only 100.00
Posted on Feb 07, 2008
SOURCE: Fridge and Freezer not cold, compressor not coming on
these are 2 different things.check the light switch. also check cold-control, defrost timer, relay on compressor.
Posted on Jul 22, 2008
aborcass
  • 2651 Answers
SOURCE: left ge stainless steel fridge and freezer door open acciently
youll need to unplug and defrost all the ice from hte back panel, leave unplugged for a min of 24, hours, then plug back in you should be fine. way too much ice has built up behind hte inner panel ,cutting of all air flow to both compartments.you did no real harm( other then losing your food
Posted on Nov 28, 2008
SOURCE: Samsung PKG001 Stainless steel Single Oven and ceramic hob
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
Posted on Sep 04, 2009
  • 277 Answers
SOURCE: mfd2561hes freezer is working but the fridge is not
your theomostat is broken
Posted on Nov 01, 2009
Plugs in but wont turn on
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric ...
www.amazon.com/Koldfront-Bottle-Stainless-Slim-Fit...
Amazon.com, Inc.
Rating: 3.7 - ‎42 reviews
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric Wine Cooler - Black/Stainless Steel ... Item model number, TWR121SS .... the fridge. so you hvae to take out a wine bottle to reach it an usually I would like the controls on the door and only turn in .... The door can be reversed which the description did not mention.
www.edgestar.com/Koldfront-12-Bottle-Stainless-Steel-Slim-Fit-Thermo...
Koldfront 12 Bottle Stainless Steel Slim-Fit Wine Cooler Primary Image ... steel, the Koldfront 12 Bottle Slim-Fit Thermoelectric Wine Cooler (TWR121SS) is ... cabinet and stainless steel accents ensure that this freestanding unit will look ... Power: 70 W/0.95 A .... Unfortunately, your browser does not support video elements.
www.walmart.com/.../Koldfront-12-Bottle-Stainless-Steel-Slim-F...
Walmart
$109.99 - ‎In stock
Jan 20, 2016 | Koldfront 12 Bottle Stainless Steel...
Why power does not come on when put on?
Could have a blown fuse. All microwaves have a fuse inside. Do you have power in the wall receptacle?
Check this out first.
Apr 10, 2015 | Daewoo 20ltr 800w Stainless Steel Touch...
Cannot reset the filter light on our maytag mfd2562kes
Unplug the fridge from the A/C receptacle for 30 seconds. Then, plug it back in. Sometimes this resets the computer board inside the fridge.
Apr 24, 2017 | Maytag MFD2562KES Stainless Steel Side by...
If my Kitchen Aid KSF26C6XYY00 door is in fact made of stainless steel, why do fridge magnets stick to it? Ohter people I know that have stainless steel fridges say that the magnets do not stick to t
Stainless steel is a term for a family of high chromium steels, some of which do in fact stain, although they do not rust as ordinary steel does.
The more expensive 'austenitic' stainless is non-magnetic, but harder to work into product shapes. 'Martensitic' stainless is a little more prone to staining and corrosion, but easier to work with, and is magnetic. Then 'ferritic' stainless is even cheaper, but less corrosion proof, and is also magnetic.
So yes, many stainless steels are magnetic, and if the manufacturer has not used the very most corrosion proof but expensive grade, then you will see it in that way. I would not see much reason for a fridge door to be made from austenitic stainless.
Feb 17, 2012 | KitchenAid KSF26C6Xyy Side by Side...
The fridge is not cooling and the freezer is not freezing. The light is still coming on when we open the doors. It sounds like the compressor is still running. What do we do?
the fridge is not cooling and the freezer is not freezing. The light is still coming on when we open the doors. It sounds like the compressor is still running. What do we do?
Mar 09, 2010 | Kenmore 73503 Stainless Steel Bottom...
My lg fridge just stopped working no lights or power, the receptacle works and no breakers tripped
I have a similar manual that shows just what you are up against. How about the power cord itself? Is it ok?
FRENCH DOOR REPAIR MANUAL
Feb 16, 2010 | LG LFC20760ST Stainless Steel Bottom...
Rrefrigerator not running no lights on no power, it worked today, and now nothing! The fridge is only 1 1/2 years old
check to see if you have a ground fault circuit on the receptacle you are using the frig on. Or maybe a breaker in the breaker box might be tripped.
Dec 16, 2009 | LG LFC20760ST Stainless Steel Bottom...
Samsung PKG001 Stainless steel Single Oven and Ceramic Hob : Hob working ok oven light comes on and fans work ok no display on oven and no heat any suggestions
Jul 15, 2009 | Ovens
Power failure
Code actually calls for the refrigerator to be on a separate circuit for this reason. you may have a refrgerator that may have a higher voltage spike at compressor start up and that is causing the trip. You can try upgrading your GFCI to a 20amp (most are 15amp). Although you may have to replace with a standard outlet if the problem does not subside.
Jul 28, 2008 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Refrigerators Logo
20 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
