Can I set up my chromecast in more than one region
How to reset google chromecast?
According to official Google Support documents, there are two ways to Factory Data Reset (FDR) your Chromecast:
  1. Factory Data Reset your Chromecast from the Chromecast app. You will find the option to FDR under 'Settings' or 'Menu'
  2. Physically hold down the button on your Chromecast for at least 25 seconds or until the solid light begins flashing.
May 01, 2018 | Televison & Video
Have new bt up how do I connect to the chromcast
You have to put in the new wifi settings for the new BT Router into the Chromecast
Change the Wi-Fi network of Chromecast or Chromecast Audio ...
https://support.google.com > Chromecast Help > Chromecast
  1. Cached
To change the Wi-Fi network connected to a Chromecast device, follow the ... for the Chromecast, Chromecast Audio, or Google Home you want to set up on a ...
. chromecast setup wifi Google Search
Aug 30, 2017 | Televison & Video
How do I connect a chromecast to WiFi
This page should help, but it is not in the best order.
1. Download chrome browser on your pc or tablet, cellphone as chromecast will only talk to this browser.
2. Download the chromecast app and install it on the computing device.
3. Search for a program the chromcast device on the same wireless network, you need to use the power supply provided and plug it into the TV.
4. Setup the chromecast device.
5. Now set up the TV side of things by selecting the USB or HDMI connection.
6. Now it should connect to the Internet, if doesn't check your router is letting it pass through to the internet.
Chromecast manual Chromecast setup guide All About Chromecast
Mar 08, 2015 | ASUS Computers & Internet
How do I connect my router N600 to Chromecast?
  1. Check your NETGEAR router settings
  2. Uncheck Enable Wireless Isolation This step will disable AP Isolation.
  3. Uncheck Disable IGMP Proxying This step will turn Multicasting ON.
Feb 15, 2015 | NetGear WNDR3400 N600 Wireless Dual Band...
How to set up showbox using chrome cast
you need to run the chromecast app on your phone first. then you should get the icon to send to the chromecast
Nov 09, 2014 | Google Chromecast HDMI Streaming Media...
How to set up my chromecast
Hi, just follow the instructions on Google's instructions:
Plug In Connect Watch
There is basically two sides to set up:
  1. Connecting and powering the Chromecast, then configuring it to work with your Wifi network.
  2. Installing the App on your Android phone or Chrome browser.
Apr 21, 2014 | Google Chromecast
Scrambled screen
Hi, this could be a power issue, are you using a USB port on the TV to power the Chromecast?
Some older USB ports might not have enough power capacity in which case you should use the small power adaptor that came with your Chromecast and power it from a wall socket.
Hope this helps!
Feb 02, 2014 | Google Chromecast
I had chromecast setup on laptop and iphone. AT&T changed out my modem and now laptop and iphone do not connect to chromecast. Power light on chromecast is white and blinking rapidly.
Hi, did they set your Wifi password back to the original one you had?
Can you still connect to your Wifi network with your phone or tablet?
Ensure that your Wifi password on your modem is the same as before or go though the initial setup again to enable that Chromecast to connect to your network again.
Hope this helps.
Jan 31, 2014 | Google Chromecast
Connect chromecast to belkin wi-fi
Ensure that wireless isolation (or any labeled form of network isolation) is disabled, though it shouldn't be enabled unless it was manually set that way. I've also run into this issue when setting up Chromecasts occasionally, and I had to do a factory reset (hold down the small reset button on the Chromecast for 30 seconds) and repeat the setup process in order for it to be detected. You might try that as well.
Nov 02, 2013 | Google Chromecast
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
