Question about Minka Dryers
The track and brush assembly in a Minka Gyro Wet was damaged when wasps built a mud cone inside. The mud cone got lodged under the rotation gear and broke the plastic divider. Where do I get parts?
SOURCE: Questions on Fellowes Shredder Spare Parts
these guys might be able to help http://wheelermachines.com/fellowes_parts.htm
Posted on Aug 07, 2008
  • 6 Answers
SOURCE: minka aire f602
There are tiny dip switches on the remote as well as on the receiver. Make sure they are set to the same sequence. The receiver is the black box that all the wires connect to in the ceiling.
Posted on Jun 11, 2009
  • 6 Answers
SOURCE: Traditional Gyro by Minka Aire - Just installed and does not work
I would triple check that the wiring is correct, then I would check the dip switches on the receiver and the wall switch to make sure they are set the same.
  • 6 Answers
SOURCE: Parts
Talk to customer service or sales. They can probably sell you those parts.
HEADQUARTERS
1151 W. Bradford Ct.
Corona, CA 92882
EAST COAST DISTRIBUTION CENTER
9348 D. Ducks Lane
Charlotte, NC 28273
--> TEL: +1 (951) 735-9220
FAX: +1 (951) 735-9758
EMAIL:
SALES DEPARTMENT:
sales@minkagroup.net
CUSTOMER CARE DEPARTMENT:
minkalaverycustomercare@minkagroup.net
  • 3 Answers
SOURCE: plastic gear broke
There is a quick fix, but you have to sacrifice a blade to get its rubber gear for the Power Base:
www.ehow.com/how_5137984_repair-magic-bullet-blender.html
Posted on Jul 01, 2009
Minka f502 is noisy - how do you tighten the screws that attach the fan blade to the motor hub?
With a screw driver? And perhaps you also clean all blades. Sorry if you already did that.
Mar 16, 2015 | Minka Aire Ceiling Fans Gyro Traditional...
Fans work but won't rotate
Probably needs a new receiver. Call Minka Aire
Oct 06, 2014 | Minka Aire F602-BNCH Gyro? Fan
Minka aire gyro fan quit oprating
Contact Minka Aire @ 1-800-307-3267. You might have to ship it back to Minka for repair or replacement depending how old it is. fanman9952@aol.com
Feb 28, 2014 | Minka Dryers
Gyro fan quit rotating
You need to call Minka Aire at 1-800-307-3267
Aug 22, 2013 | Minka Aire Ceiling Fan
360 rotation
Call 1-800-307-3267 Minka aire. I think you need a new receiver.
Jul 24, 2013 | Minka Aire F602-BNCH Gyro? Fan
Minka gyro fan noise, my fan has a popping sound at the same point in each full rotation.
i'd take it back and get a replacement. It has a lifetime motor warranty. I used to sale Minka Aire but always had motor problems.
Apr 19, 2013 | Minka Aire F602-BNCH Gyro? Fan
Water on passengr side floor
Some ideas for you:
Usually the problem is the drain hose from the air conditioning in your vehicle is leaking or plugged up or was damaged somehow and the condensate water is running onto your floor. Was the car even in an accident where the right front fender was involved? Might you have insects such as a mud-dauber wasp might have built a mud nest inside the bottom of the drain tube? The drain tube usually would drain the water only when running the A.C. out under the feet of your passenger, but under the car, not inside.
I just finished two years of chasing a leak that was on the driver's side of an old Honda Civic, to find salt had eaten a hole in the firewall under the windshield behing the driver's wiper assembly.
Jan 01, 2013 | 2005 Nissan Terrano 2.7
1st two speeds not working
If the fans rotate on high, then they can rotate on low. So it's either the remote or the receiver that's not succeeding in adjusting the speed. You might try changing the dip switch settings to a different combination and see if that helps. Otherwise, my first guess is that it's the receiver since it has the "brains" of the unit. Also, with electronics it sometimes helps to completely remove all sources of electricity for a minute in order to reset everything. That would mean turning off the circuit that powers the fan for a minute then flipping it back on.
Apr 27, 2009 | Minka Aire F602-BNCH Gyro? Fan
Apr 28, 2008 | Minka Aire F602-BNCH Gyro? Fan
Dryers Logo
22 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
