Need plug for kool operator fan - Heating & Cooling
Do you need to drain the kool king ac?
What kool king? Some are fully evaporative, some partial. None the less depending on humidity and how much condensation machine is producing all need drained. Typically it will shut down when and if it needs drained but if you are concerned, pull the plug!!
Aug 26, 2017 | Kool King Heating & Cooling
Need manual for emerson quiet kool air conditoner model 12HT13?
I found this I hope it helps.
Performance BTU/H Cooling: EER: Voltage: Amps: Watts: Cooling Area (Sq. Ft.): Pints/Hour: Room Air Delivery (CFM): Plug Cap Amps: Plug Type: Dimensions Width: Depth: Height: Net Weight: Shipping Weight: http://www.appliancefactoryparts.com/airconditioners/emerson/12ht13.html#Manuals
Jun 02, 2014 | Emerson Quiet Kool 12HT13 Air Conditioner
Need stroller manual
Either call Kool Stop in Oregon and ask for the Kool Stride manual you need or download this online one which is similar...
http://ebookbrowse.com/kool-stop-kool-stride-sr-paramount-series-jogging-stroller-owners-manual-pdf-d359030674
Apr 10, 2012 | Baby Gear
I need to remove the blower motor from my Emerson Quiet Kool model 1350, how do I do this..
First open the control panel and remove all wires of your fan motor from the control switch and the capacitor. Remove also the compressor wires. Unscrew all panels and move the evaporator farther from the mounting base Pull-out the fan motor assembly with the panels. Unscrew the blower, fan blade, and them from the assembly. Unscrew the motor and now it is free.
Aug 31, 2011 | Emerson Quiet Kool 6GC53 Air Conditioner
I need a replacement condenser fan for model# EQK 1350 part #F12021 any idea where I can find one?
I was looking for the same condenser fan blade, for my emerson quite kool 1100. F12021-02 can be found on ebay for 24.95 + 15.00 shipping hope this helps, and good luck......
Jul 10, 2011 | Emerson Quiet Kool 10MW42K Air Conditioner
Heat/AC unit in working order, plugged in 20Amp outlet.. no fan?
Hi1
Do you have at least 200 volts at your outlet? Check that first. You said you brought it home from work, so when you plugged it in at home did you plug it into a 120 volt recepticle?
Jan 01, 2010 | Emerson Quiet Kool 12NW46HK Air...
Fuse to kooling fans
try replacing the thermastatic fan relay or just by pass it to see if the fan operates
Jun 22, 2009 | 1991 Pontiac Firebird
BTU's on Emerson Quiet Kool A/C
AC Type dtrquestion.gif Thru-Wall/Window Cooling Capacity dtrquestion.gif 10000 BTU/hr Energy Efficiency Rating dtrquestion.gif 9 EER Fan Speeds (Cooling) 3
May 27, 2009 | Emerson Quiet Kool 10GV13 Air Conditioner
Emerson Quiet Kool Drips Water into the house
depends on the unit. you will probably have to slide it out of its case and clean the outside part . there should be a hose that goes from the inside to the outside for the water to go out. this hose may be clogged, trapping the water inside. as i always say a picture of the unit always helps so i can identify it and tell you what to do to try and fix the problem. email the pics to eyg2181@yahoo.com
Jul 31, 2007 | Emerson Quiet Kool 14LW22K Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
