Question about Miller Welding Tools
Miller xmt 350 amps fluctuating,how to solve?
4 Suggested Answers
  • 2976 Answers
SOURCE: connect ln 9 gma to miller xmt 304 inverter with 14pin recep.
One of your pins isn't wired correctly for your combination.
Posted on Feb 12, 2009
97F350diesel
  • 1326 Answers
SOURCE: MILLER XMT-300 CC/CV, DISPLAY READS [HELP 1
Coould be excitor coils, relay or main control board. Have to have em all tested to narrow down.
Posted on Sep 22, 2009
luis_david
  • 407 Answers
SOURCE: I have a miller xmt
Hi:
Ok, let troubleshoot this one.
There is only two connectors on your 12VS wire feeder; the lead cable that goes to the + side of the XMT welding machine and the VS cable (Volt Sensing) that goes to you work piece joining the ground cable (don't forget the ground clamp).
a) The mode switch on your XMT must be on V-sense feeder.
b) Your 12VS feeder depending on what kind of wire you are using (innershield) negative side or gas wire + side.
That's it. If there i no spark, there is something wrong with your XMT.
If this was useful to you please vote. Thanks.
Posted on Apr 02, 2011
Miller welding machine XMT MPa 450 facing help 6 / contactor for 24 volts not energised and help 6 comes out/
This is a voltage issue and it's low or getting a false reading of voltage. TThings to do.
You really want to make sure the little 5/16" head screws on the output board are torqued, something like 13 inch/lbs on the caps and 20 inch/lbs on the rest of the board. ( I use the #6 setting on my Makita clutch drill for all of them)
i'd remove and reinstall ALL the molex connectors on the boards to reseat the pins. Also look for corrosion anywhere else at same time.
Now if you took out SR1 bridge, the chances you took out or damaged the main on/off switch are pretty good. It may work, however there may be resistance on the contacts, something to check.
Mar 25, 2016 | Miller XMT 450 MPa 230/460V w/out Aux...
I have a HEL p-6 code on a xmt 304 how do I fix it
Sounds like a input power problem . Make sure voltage is correct coming to the unit and wired correctly. I checked a Miller welder recently ,auto link that would come on and weld but not good . Took cover off and it was wired wrong .
Dec 08, 2014 | Welding Tools
Burning up tips fast with Miller S-22A
tooslow and probaly too close to work piece try turning heat down a little also make shure you have a good ground/ maybe angle your gun a little more
Dec 17, 2012 | Miller Welding Tools
I have a miller xmt 304 i bought it used. i have a 12vs wire feeder on it and im not getting power to it. any suggestions on what the problem could be
Hi:
Apr 01, 2011 | Welding Tools
When im welding the xmt 304 machine will arc out and the volts will say HE.L and the amps will say P.5 its like it loses ground what does the volts and amps mean when it says that.
Help 5 Display Indicates the right side of the unit has overheated.
The unit has shut down to allow the fan to cool it. Operation will continue when the unit has cooled.
If unit overheats, output stops, a Help 5 message is displayed, and cooling fan runs.
Wait fifteen minutes for unit to cool.
To avoid this problem Reduce amperage or voltage, or duty cycle before welding.
Jan 22, 2011 | Miller Welding Tools
MILLER XMT-300 CC/CV, DISPLAY READS [HELP 1 ] UNIT POWERS UP BUT NO ARC
Sep 22, 2009 | Welding Tools
Welding Tools Logo
103 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
