Question about Refrigerators
Icemaker not crushing ice - Refrigerators
SOURCE: icemaker only dispenses crushed ice, not cubes
There is an opening next to the auger that dispenses the ice.  In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed.  Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Viola! Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
check it out!  Thanks to Jake!
Posted on Jul 01, 2008
  • 65 Answers
SOURCE: Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Posted on Jan 27, 2009
woodchuck789
  • 4070 Answers
SOURCE: Dispenses crushed ice and will not dispense ice cubes
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Posted on Aug 17, 2009
SOURCE: icemaker won't crush ice
FRIGIDAIRE SIDE BY SIDE ... WON'T CRUSH ICE...
... makes ice and dispenses H20 just fine.
Found this solution elsewhere on line, just adjusting the white plastic "thingy" a la #2 mentioned below solved my problem, yippee!
SOLUTION:
"The most common reason for this problem is frost forming on the shaft of a solenoid that shifts the ice bucket discharge from cubed to crush.
1.Take the ice bucket out, and look at the back wall of the frig. You should see a small hole that lines up with a metal arm that was sticking out the back of the ice bucket. In the hole you can see the end of the mechanism that moves the ice bucket arm.
2. With your finger you should be able to move it up and down about half an inch or so. If you can't, you have found your problem. Sometimes you can just free them up by working it up and down a few times.
3. If that fails you will need to remove the whole panel to get access. Thaw it out, dry it out, then put a little lithium grease(very thin coating) on the shaft, and put it back together.
Sometimes the (solenoid)coil is bad, or the inside of the coil has distorted it's shape inside so the shaft won't move. Then you need a part.
good luck, let us know what you found
Posted on May 16, 2010
  • 7 Answers
SOURCE: icemaker crushed ice only, no cubes
I had the same problem of only crushed ice. The solution is very simple. Pull out the ice drawer and in the back on the fridge you will see a small square hole. This is the hole that the long rod that runs along the bottom corner of the ice drawer sticks into. The rod controls if the ice is crushed or not. If not crushed the rod twists and opens the door by the grinder so it does not grind. This rod is not opening the door. Put your finger into the hole in the back of the fridge and push down on the white plastic crossbar. Mine was stuck or frozen in the up position. When it snapped down and was free to move up and down I put the drawer back and it works perfectly. Good luck.
Posted on Jul 27, 2010
LG ice maker will not dispense cubes without crushing them
Check the evaporator system, that release the cubes, when that does not work the cubes stay stuck inside.
Oct 31, 2008 | Refrigerators
Recurring buzzing sound with icemaker
The buzzing sound may be the sounf of the electric water valve (Solenoid) when filling ice cube tray.
Aug 31, 2009 | Jenn-Air JCD2389G Side by Side...
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
My icemaker, a ge profile is only making crushed ice, no cubes,
There is a selector for crushed or cube and is usually at the dispensor.or above it. good luck
May 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
WE HAVE A GE REFRIGERATOR THAT IS ONE YR OLD AND IT WILL NOT CRUSH ICE. WE'VE REPLACED THE ICE MAKER AND IT STILL WILL NOT CRUSH. IS THE SOLENOID OUT BEHIND THE ICEMAKER ARM IN THE FRIG WALL? GE MODEL...
You may be on the right track. Remove the ice bucket and check the square hole behind the ice bucket in the back wall of the freezer. You should be able to move the horizontal rod in it up and down with your finger. If not, it may be frozen in one position. If so, just warm the area a bit with a hair dryer to free it. Replace ice bucket and test. Another thing which may cause that is the ice auger itself may have separated from the drive shaft. (The icemaker itself has nothing to do with making "crushed" ice. It only makes cubes. The cubes are dispensed or crushed and dispensed at the front of the ice bucket using the auger and the metal parts there.) You might also want to verify that the long metal rod (which extends past the ice bucket and into that square hole) is able to move. (it is spring loaded)
Feb 03, 2009 | Refrigerators
Ice maker in door not making ice
make sure the switch is turned on on the icemaker if it is then see if there is water in the icemaker it could be either water valve or icemaker
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working no water getting to icemaker
Icemaker is making ice slowly. Crushed ice button does work.
Aug 25, 2008 | Refrigerators
GHE monogram ice maker.
pull the icemaker out, say be one inch, shack it a bit, and jam it back in. We've done that each time we had that problem, before it started to work. The icemaker is designed poorly, my openion, and gets jammed easily each time you use the crushed ice. crushed ice jams the ice crusher, and cloggs the pathway resulting a no ice dispensing situation. Also try using only whole ice cubes, instead of the crushed ice. the less you use the crusher the less you'll have to problem. one last thing. if the ice is sitting in the basket for a while, due to poor ice despensor opening door design, the ice in the basket cloggs together causing the probelm.
May 19, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Whirlpool icemaker not giving cubes, only crushed ice
If less than a year old should still be under warranty
Sep 05, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
