Question about Cycling
Scooter won't move forward or backward
I have a Bladez DKS200 mobility scooter and it will not move forward or backwards when it is turned on. The horn blows and the freehand is pushed down in the back. What could the problem be?
Jdl0755, I'm having the same problem with my DKS-200. I was wondering if you determined the problem? I'll let you know if I figure it out with mine.
Posted on Dec 17, 2009
Go to electricscooterparts.com get a rear wheel clutch assemly fixed ours!!
Posted on Jul 25, 2009
Scooter not charging when plugged into the charger
measure the voltage of the batteries thru the charging socket of the scooter, the outside 2 pins.
Sep 20, 2014 | Health & Beauty
I have got a tga breeze mobility scooter. I charged the batteries as it was not used for a while the display showed up grey put in the key. The indicators & lights etc didn't work but the scooter would...
If the scooter functions OK backwards & forwards and drives the distance you require, then i would hazard a guess at the PCB in the tiller head, paired with BDI (Battery Display Indicator).
Batteries on the Breeze are most likely 70-100ah, and ideally must be kept charged, either after use or at least once per week if you are not using it. Failing to do so will end up costing a lot of money :-)
Sep 24, 2013 | Health & Beauty
Mobility scooter - Electrics work, but won't go
hi, they are a nice scooter so let's get it working ,
First check that the freewheel lever is disengaged, in drive mode.
Do you hear a click when pressing the lever to go forward or backwards?
What can happen is the brake located on the side of the motor can seize,,,
Please keep me updated
Regards
Jan 04, 2013 | Electric Mobility Mobility Electric Power...
Scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
Aug 09, 2012 | Electric Mobility Merits Electric...
Looking for a bladez DKS200 mobility scooter battery case?
http://www.bladezscooters.com/
http://www.monsterscooterparts.com/
Unlikely some other manufacturer's box will fit, if only because the circuit connecter is built into the pack.
May 03, 2012 | Health & Beauty
My mom's Bladez DKS200 mobility scooter suddenly stopped working when she tried to take it up a steep hill. At first, even the battery light wouldn't come on, but after pushing the reset button, the...
Not exactly sure this is helpful, but make sure the bottom of the scooter is dry; all it takes is a little moisture and the scooter won't work.
Sep 16, 2010 | Electric Health & Beauty
Moving problem
More than likely its the speed pod or engager (paddle assy. This would need to be replaced.
Jun 26, 2009 | Golden Technologies Companion II Travel...
Cycling Logo
356 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
