Question about Black & Decker Garden
My grasshog spool runs through all the line to quickly.
Filled the spools with line and the grasshog just releases all the line immediately
  • 313 Answers
SOURCE: My grasshog gh600 wont feed
check out a white plastic lever at the back of the spool line. if its broken then replace it. cost of the parts around $4.00 or so. this parts controls the auto feed of the spool
thanx
Posted on Jun 26, 2008
SOURCE: Black & Decker Grasshog GH600 lever replacement
this has been driving me crazy. try this pdf from the black and decker site http://support.blackanddecker.com/cgi-bin/blackanddecker.cfg/php/enduser/fattach_get.php?p_sid=98uDbvBj&p_li=&p_accessibility=0&p_redirect=&p_tbl=9&p_id=1885&p_created=1148586888&p_olh=0
Posted on Jun 28, 2009
SOURCE: how to replace line on the double sided spool for my grasshog
HOW TO REPLACE LINE, PLS CAN YOU SHOW ME FROM THE PICTURES.
Posted on Nov 16, 2009
vincob
  • 718 Answers
SOURCE: how to string spool for black and decker corless
Go to smalleng.com they have video on how to do what you need. Check it out awesome website!
Posted on Apr 08, 2010
jyackle5
  • 8197 Answers
SOURCE: Removing spool on weedeater SG11 Electic
Pull on the tap head. Straight out. Hard. Here's the Weedeater manual. http://72.3.225.179/manuals/545117522e.pdf The spool should just pull out, its held in by 2 clips, royate it till it pops up then pull it out, with a wiggling motion, Grasp firmly and pull straight out....per tech support from 800 number on machine.
Posted on May 14, 2010
Need to replace the wirefeed? Purchased 8" orange
Hi gramcherry1...
1 Press the lock and rotate the spool counter-clockwise or some will remove the center knob.
2 Remove the locking ring if your weed eater has one.
3 Take off the automatic feed button.
4 Wipe away any dirt and debris.
5 Push down on the spool to release the locking tabs.
6 Remove the spool from the chamber.
Restringing the Weed Eater
1 Feed one end of the line into one of the holes of the spool, and secure the end that was inserted
2 Wrap the line in the direction of the arrows. Do this until until you fill the spool up with line.
3 Secure each of the lines into its own upper and lower grooves.
4 Re-install the spool into the chamber from which it was removed.
5 Pass the lines into the left and right holes and snap the spool into place.
6 Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
7 Reinstall the locking ring if necessary, reinstall the center knob.
Please take time to rate me
Jul 03, 2011 | Black & Decker Grasshog 12 Inch 18 Volt...
Having trouble replacing trimmer line
Hello. I just answered a similar question not twenty minutes ago. Hope this helps.
Please read all the way through this before beginning to actually rewind the spools.
1. Pull the spool off of the head. Clear the dust and debris out.
2. Note that it is actually two spools that are separated by a disc, and that the disc has a slot in it. The outer spool is the spool closest to the bump head, and the inner spool is the one that fits closest to the machine and has notches in it. If you turn the spool so that the inner spool base is up, you will see that there are decimal numbers next to the notches. The decimal numbers are your line size(s). I say sizes here as some machines will accept more than one line size. You will also notice arrows on the inner spool base, telling you which direction to wind the line on to the spool(s).
3. Wind the inner spool first: Put the end of the line into the hole that is in the core of the inner spool. insert ~1/8". Wind in the direction of the arrows until you get roughly even with the divider between the inner and outer spools. You want to end up with your line 180 degrees from the slot in the divider, and snap the line into the notch that is in the inner spool base. You want about 6" of line beyond the notch. Cut the line, leaving a 6" tail.
4. Wind the outer spool: Wind the outer spool like you did the inner spool, filling the spool as before, and ending at the slot in the divider. Feed the line through the slot and snap it into the notch. Cut a 6" tail as before.
5. Reinsert the spool: Get the spool close to the machine. Insert the tails into the grommets in the head, and snap the head into place.
6. Preparing the line for use: Push the spool in as if you were bumping it against the ground to advance the line. Grab the tails and pull. This will release the line from the notches, and should release about 1" of line in doing so.
You should be good to go.
Every so often, it's a good idea to put some graphite dust into the spool just before putting the spool back onto the machine. This helps when you are advancing the line. I do this every 8 to 10 times I rewind the spools.
If this fails to correct your problem with the spool, it would be best to purchase a replacement spool.
Best regards, --W/D--
Jan 31, 2011 | Tanaka 22" Double Sided 24cc Hedge Trimmer
How to respool the line on grasshog electric grass trimmer
The empty spool can be refilled with 30' of size .065" nylon line. Make sure you run the line in the direction of the arrow embossed on the spool.
Sep 06, 2010 | Black & Decker 14" Grass Hog Xp...
Black and Decker Grasshog auto line feeder just spits line out non-stop. Tried lots of things but nothing seems to work.
I'm gonna take a guess and say you re-spooled the line yourself. If you did you may have put too much line on the spool. The max. is 30', but I've found that that can cause jamming, which forces out more line, if not done perfectly. Reduce the amount of line by about 5 feet and you should be OK.
Apr 10, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
Line will not advance line is not crossed in spool
Rewind the line and make sure you wind in the direction of the arrow on the spool. Not an unusual situation.
Mar 31, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
How to replace line on the double sided spool for my grasshog
Oct 14, 2009 | Black & Decker 14" Grass Hog Xp...
My Balck&Decker Grasshog won't automatically feed line.
Just replace the LEVER, Item #29, Part #598435-00, for about $3.00 (B&D, Dewalt). Just pull old level straight out (pliers) and push replacement in. Level end expands to hold it in place. No other parts. Forget cleaning and replacement the spool, graphite or oiling... just replace the lever.
Aug 24, 2009 | Black & Decker 14" Grass Hog Xp...
Auto feed spool doesn't work
You may need to purchase a new spool housing, which may not be too hard to do, if you have one of the name brand trimmers. This replaces the whole mechanism that holds the line, the retaining ring, etc.
Sep 21, 2008 | Black & Decker Black and Decker & Grass...
Garden Logo
319 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
