Question about Home
I need service manual for a dual flush waterridge toilet
  • 129 Answers
SOURCE: I have a dual flush vitrA and it leaks
You will need to replace the flapper in the tank, its very simple.
Posted on Sep 26, 2009
  • 1922 Answers
SOURCE: running toilet
your float is stuck
Posted on Oct 13, 2009
  • 11 Answers
SOURCE: Pegusas toilet.
I have the same problem .... I took it apart and found that there is not any screws, nuts bolts, washers .... what it is (was) is a piece of lead (like a sinker on the end of a fishing line) attached to the end of the cable, yes the cable, that hooks into the handle and into the top of the flush mechanism - that yellow plastic tube )the cable goes through it) I was able to take it apart and repair the end of the lead weight with a split shot sinker BB - is the size I used. I also had to deform and cut some of the sinker away since the hole it sits in, is small. When I went to Home Depot to buy/get a repolacement unit, one store told me to call the manufaturer -- Foremost and gave me the number, I lost that piece of paper now that I have time to call again, I was left on hold for 10 minutes the first time. 1-888-256-7551
I just called and pressed a few buttons, waited 2 minutes, got a live person, she asked me what was wrong, I told her that my handle was just spinning, she asked for my model number 131-926 (found on the inside back of the toilet) when I purchased it (make this up, within this year ... and yes you have the receipt - she never asked for it, just that I had one!) she took my address down and gave me a client number .... tada!
Posted on Dec 16, 2009
  • 349 Answers
SOURCE: how do i set the flush levels for a glacier bay
Go to page 5 & 6 and it will guide you through setting levels.
Posted on May 23, 2010
woobie dog
  • 1273 Answers
SOURCE: How can we stop our
Remove the lid from the tank. Verify that the tank is full. Shut off the water to the tank, at the wall. Wait 5 minutes. If the level has fallen in the tank, the flapper valve in the bottom of the tank is the culprit. If the tank remained full, the issue is with either the fill valve assembly or the overflow tube.
Posted on Jan 16, 2011
Our WaterRidge toilet tank will not fill with water
This sounds like the float is getting stuck , while the toilet is trying to fill if you see the float ball that is attached to a arm that pivots , if you lift the float up it should turn the water flow off from trying to fill the tank , some problems that can stop this are the rubber seal that lifts up when you press the flush button to allow water to flush the bowl does not seal back in a position so that the tank can never fill , sometimes the float ball can get stuck which stops it from rising up with the water level and shutting off the water , but my best guess is that the rubber seal has started to perish or distort and needs to be replaced you can find this right at the bottom of the tank and it is directly connected to the flush button ,so if you inspect inside the water tank and press the flush button you will see that it opens up and lets water pour into the toilet bowl but if a tight seal can not be made water will never fill the tank
Sep 26, 2017 | Washing Machines
Hi all, I have a Jacuzzi SWP-1 Perfecto Dual
Hi, Go to amazon and look for replacement parts.... here:
Jacuzzi SWP2959 Perfecta Dual Flush Two Piece Elongated Comfort Height... I hope this was helpful.
Aug 15, 2013 | Jacuzzi Home
Uberhaus dual flush toilet keeps running
The flapper may not be seating properly after a flush. Even though you say the toilets are brand new, something may be askew in the flushing assembly or may have been affected during installation
May 27, 2013 | Home
What is the problem when water is running on a dual flush toilet
water level set to high push botton rods not ajusted rite 5 year warranty on flush valve
1-800-459-4409 service and parts
Jan 21, 2011 | Toto Aquia II Dual Flush Toilet
Aquia II Dual Flush Toilet: toilet after flush removes to much water from bowl...
Adjust the float on the Fluid-master a little higher if possible. This should allow more water to enter the bowl after the flush.
May 16, 2010 | Toto Aquia II Dual Flush Toilet
My whip dual flush toilet leaks around the flapper
the flush neck must be pitted or someting, the part that the flapper sits on that needs to be replaced.
Jul 02, 2009 | Toto Aquia II Dual Flush Toilet
Toilet will not flush
You need to replace the fill valve with a oem replacment valve. You need to use toto parts.
Mar 07, 2009 | Toto Aquia II Dual Flush Toilet
Home Logo
57 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
