Question about Refrigerators
What is the energy efficiency rating of the KIC Super Cool fridge with bottom freezer? Ours is approx. 5 years old
SOURCE: fan is running, fridge and freezer not cold
I have a Westinghouse side by side refrig/freezer that the compressor will run but will not cool or freeze. Do you have any suggestions?
Posted on Apr 06, 2009
  • 212 Answers
SOURCE: Amana energy saver not keeping fridge section cool enough. HELP!
if there is frost build up on rear wall of freezer section the unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow to the fresh food section. one of three things are bad. defrost heater, defrost thermostat or defrost timer. if no frost on rear wall you might be low of freon.
Posted on Jun 24, 2009
adnanbhatti
  • 1188 Answers
SOURCE: fridge barely cool freezer not freezing
I suggest first getting it checked. Maybe there is just a small leak which can be sealed and coolant refilled. If say the compressor is damaged or other major component then only the repair cost will dictate what to do next.
Refrigerators are not very complex and have relatively few parts. You will probably get satisfactory results from repairs.
Posted on Jul 29, 2009
  • 118 Answers
SOURCE: PTS25 Top Freezer Model- Fridge & Freezer won't cool
If the compressor is still good your hard start relay might be bad.
Posted on Aug 05, 2009
WALNUTS420
  • 3 Answers
SOURCE: Fridge not staying cold, periodically
CHECK FAN OPERATION   MOST OF THE TIME IT IS THE THERMOSTAT
Posted on Aug 12, 2009
Testimonial: "Seems this comfirms what I am hearing. sounds like I should change the thermostate and go from there. Thank you. "
LEFT DOOR OPEN OF FREEZER. CLOSE3D DOOR FOR 24 HRS. nOW LIGHTS FLASHING ON SUPER COOL AND SUPER FREEZE.
You will need to unplug and defrost the fridge for a few hours then replug the power. Leaving the doors open allows moisture to freeze on the evaporator while compressor continues to run confusing the control board
APPLIANCE911
Apr 10, 2016 | Hotpoint Combi FFFL1810G Graphite 297 l...
What year is magic chef model ctb1922grw refrigerator?
There should be a sticker in the FRONT door that has the YEAR manufactured. ENERYSTAR has been around for quite some time. The newer the more efficient but still efficient.
Apr 05, 2014 | Magic Chef CTB1922 Top Freezer...
My kic fridge have 2 compartments. Freezer and fridge. only the fridge part dont work help please
The freezer is where the heat is removed from the box and cold air should circulate from the freezer into the refrigerator section. Something must be blocking the vent between the two. There is only one cooling unit; it cools the freezer and is also vented into the fridge for sub-freezing temperatures.
Nov 26, 2013 | Red Line Mens Classic Gmt Black Dial Black...
Jun 24, 2009 | Amana ABB1927DE Bottom Freezer...
Fan is running, fridge and freezer not cold
Apr 06, 2009 | Refrigerators
Frigidaire refridgerator #frt21prhw1, not cooling or freezing
You said, your frigidaire refrigerator are not cooling
Check the outlet that it is still has power. You can plug a small lamp in to test it.
If there is power, wait 5 minutes before plugging the fridge back in and then see if it reset the system.
And how old is the fridge?
If not then you have a bad thermostat or leaking freon, and the pressure is too low to cool anything.
Or,if the compressor went then you may find this article I just read interesting!!!!!!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Please remember to enter a rating before you sign off!
Thank You, HUUUM
Oct 05, 2008 | Refrigerators
My fridge stop cooling including the freezer section, motor is running okay. This is a icemaker fridgedair. Help , please.
Hello kenbarn
Welcome to Fixya
You said,
your fridge stop cooling including the freezer section, motor is running okay. This is a ice maker Frigidaire. Help , please.
What is the model number?
First try to unplug the fridge for 5 minutes and then turn it on again and see if we reset the system.
Repair or replace?
Thank You, HUUUM
Oct 05, 2008 | Frigidaire Refrigerators
The fridge has two doors upper part that is freezer is running well while the lower part is colling real slow
Hello aman_judge20,Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your fridge has two doors upper part that is freezer is running well while the lower part is cooling real slow.
Ready?
If the freezer is cold and not the fridge, you need to make sure the freezer is not filled to the top and covering the cold air vents and passages usually found in the rear or bottom rear of the freezer!
If they are blocked or covered with packages the unit will not be able to transfer cold air to and from the fridge!
Yes, they share the air in most refrigerators!
It will take some 5- 8 hours for the temperature to fall to the correct number if this was the problem.
If not then you have a bad control switch, and need a repair service!
What is the type fridge,
The model and age?
Let me know what happens! Ahumdillilah
Please remember to leave a rating when you are done!
Bless You, Huuum
Please remember to leave a rating before you sign off!
Here is an interesting report I just read!
Repair or replace?
When a repair makes sense.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Sep 24, 2008 | Refrigerators
Side by Side Maytag Frig/Freezer Frig not cooling
Hello momeddy41,
I'm Huuum to your rescue.
Is your freezer packed to the top, and covering any air ducts near the back of the freezer?
The freezer and fridge share the air and if the circulation from the freezer to the fridge is cut off ,
this could cause problems.
Or you may just need a shot of coolant to raise the pressure in the coil.
It's not necessarily wise to spend a lot of money on an old fridge over 7 years old.
But*** it's better to try one service call and find out if it is one of the many simple things first, as I showed you. Then you would ne saving the price of a new fridge for awhile!
That's your call.
Repair or replace?
Please do not forget to give me a rating before you sign off!
Bless You, Thank You, HUUUM
Sep 22, 2008 | Refrigerators
Fridge/freezer not cool.
Hello
Welcome to fixya.
I believe your problem is an old thermostat or compressor !
How old is it?
My advice is do not put good money into bad!
A new fridge will pay for itself in a few years by using a lot less electricity!
Repair or replace?
Please remember to leave me a rating before you sign off!
Thank You, HUUUM
Sep 20, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
20 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
