Question about Bosch Washing Machines
How to fix Lock pin which holds the pipe BOSCH
I have a Bosch oven with the "key" sign constantly lit and the oven won't function at all. Re set it at wall etc.
the key sign shows that the child lock is engaged. to unlock, usually you push and hold the lock button for a few seconds. the correct button is usually a dual function and so marked. if you need more help, go to manualsonline.com and look up your model number for your manual. good luck
Dec 27, 2015 | Bosch Ovens
CHILDLOCK WONT SWITCH OFF ON BOSCH OVEN
There are a few reasons for this. One is the most obvious and that is the child lock switch needs to be engaged to unlock.Some models call it panel lock.
Turning the panel lock on and off:
To turn the panel lock on, press and hold the Panel Lock key for four seconds. The Panel Lock symbol will appear in the display.
To turn the panel lock off, press and hold the Panel Lock key for four seconds. The message in the display will disappear.
Aug 05, 2014 | Bosch Ovens
We have a problem with two of the burners on our Bosch hob which refuse to stay lit, at certain times. The problem is confined the front burners (medium size), with the largest and smallest burners which...
Remove the brass burner heads.Remove the Butterfly nut ( in some models just a screw ) and remover the cast iron base.At the narrow end there is a nozzle with a small pin hole which couples with this pipe. Take a fine needle or pin and insert into the small hole and clean. Reassemble and Voila !!!! bobhifi.jpg
Mar 07, 2011 | Bosch NHT645SGB Gas Cooktop
Bosch 500 series washer E:27 error code?
turn dial to off. hold down both delayed start and spin select buttons and turn dial to the left one click, to the cold position. keep holding button until you here a click. let go of buttons and turn dial to off. Every thing should go back to normal. Just fixed mine and all is good.
Nov 21, 2010 | Bosch WFVC5400UC Washer
How do i replace a door seal on a Bosch Exxcel WFO285S
This video will show you how to change a door seal on this appliance
Aug 09, 2009 | Bosch Washing Machines
Bosch Classixx 6 1200 express front load washer - the 'screen' has a lock symbol on it, preventing operation: not sure whta this means or how to resolve, please.
The 'start' button appears to contain a lock - possibly a child lock. Hold the button in for a few seconds to clear the lock
Mar 25, 2009 | Bosch Washing Machines
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 | Freezers
Bosch WFF1201
Your problem is most likely the door interlock switch which is shorted. Replace the lock by removing the retainer spring around the door boot from the front, then remove door boot on side where lock is and fold back. Remove the two screws holding the lock (some models just clip off) and disconnect plug....make sure power is disconnected. A burning smell on the lock is usually a sure sign of failure, sometimes no indication at all.
Feb 01, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
