Hour screen not appearing - Televison & Video
How to switch 12 hour from 24 hour in cerruti 1881 digital watch
Hold down the C for about 2 seconds (set Hold) will appear and the time offset valve will flash on the display. Press B twice to display the screen for selecting 12-hour or 24-hour timekeeping. Press D to select (12-hour) timekeeping.
Note: The PM indicator appears between noon and 11:59 PM. After all the settings are the way you want Press C to exit the setting screen.
Jun 27, 2017 | Cerruti Watches
My LGG3 lock screen started pressing its own numbers. It lasted for an hour then the security screen came on and letters were appearing by themselves and that lasted for an hour. Now the phone is frozen...
If you can turn it off, hold your power and volume down button until a Hard reset option appears. Cancel it and turn your phone back on.
Mar 16, 2015 | Cell Phones
I lost my manuals for puma watch PU910541005 where can I download?
push the touch button, the word TOUCH may appear on screen, then touch the cloud/sun on screen and hold it for 4 second aprox (the word "hold" it's gonna appear on screen), then the hour number its gonna blink....... to change the hour number just touch the hour glass or the chrono figures.....
Jan 21, 2011 | Sport & Outdoor - Others
Have Rado 193. am trying to sync analog and digital time. Manual says turning crown slowly adjusts minutes. Does not - only hours change
You can adjust the analogue hands without changing the digital ONLY when you have set the watch to 24hr fornat. Do this by going to the second Timezone screen (T2) and pressing the crown once briefly. If A or P appears, the time display is in 12-hour mode. If no letter appears, the time display is in 24-hour mode. To change mode, press crown briefly a second time.
Now go to the basic display where no digital info is shown. Pull the crown out. Now slow turning will adjust the minutes and fast turning the hours, but only of the hands. Therefore you can synchronize the two. After they show the same time, press the crown back in and adjust both times together using the crown as normal on the standard "Time" digital screen
Dec 28, 2010 | Rado Maxi R21347712 wristwatch
Please tell me how to program my timer. How do I set the time and when it should come on and go off everyday
Smarthome has the T-1032 pdf manual
http://www.smarthome.com/manuals/4256.pdf
1) Test installation to see if your wiring technique is correct.
Open cover > set on-off switch to 'ON'
Press the tiny round reset button with paper clip
Screen displays 0:00, MO, MAN, OFF
Close cover
Push cover inward like a push-button (the cover is the manual override)
Lights should turn on
If lights don't turn on, then you need to rewire ... so re-post a re-wire question ... and then come back to this answer to program
2) Set Time and Day/ Correct time and day are needed for programs to work.
To start, notice on the screen - in the corners are little letters: MAN, MO, OFF. And to left of time is PM.
Set the Hour: Press hour button until correct hour shows, including PM or AM
Set minutes: Press MIN button until correct minutes show
Set the day. Press day key ... MO in corner changes ... for example TU is Tuesday, WE Wednesday, TU Thursday
Press one of the control buttons to finish operation
Programming overview
Timer allows 7 programs
Program 1, Program 2 etc
Each program has ON and OFF time
So you have to select Program 1
And then set DAY for Program 1, set ON time for Program 1, and then set OFF time for Program 1
Next you do the same for Program 2 , and then Program 3, 4 etc to 7
If you only want Program 1, then you do not need to set Programs 2 thru 7
Let's program
Press PGM button ... the timer screen show a P to right of time
The number 1 appears below P and indicates Program 1
Set days you want Program 1 to work: Press day button and you can see MO TU WE TH etc appear on screen.
If you want all week long, press day button until all 7 days appear in tiny print on bottom of screen
Now you have the Day set for Program 1
Notice the screen shows ON ... this means you are going to set the ON time for Program 1
First, Set hour you want Program 1 to turn ON: press Hour button until correct AM PM time shows on screen
Last, set minutes to go along with hour: press MIN button until correct ON time minutes show
You have the day, hour and minute set for ON time
Set OFF time for Program 1: we are going to set a Day, hour and minute you want Program 1 to turn OFF
Press PGM button, and notice that OFF appears in top right corner of screen
Set the day you want timer to turn OFF for Program 1 by pressing DAY button >>> Tip set same days you set for ON times. So if you selected all seven days for ON time, then select all seven days for OFF time
Set the hour and minute you want Program 1 to turn OFF by using Hour and MIN buttons as before.
OK, the ON and OFF day, hour and minute are set for Program 1.
To continue to Program 2, press PGM button until a 2 appears on screen below the P
If you do not want to set more Programs, then you're finished
To finish, press any control button
Close the lid, cross your fingers, you did good
Sep 30, 2010 | Aube Technologies Aube 7-Day 40-500w Light...
The device is an InFocus LP 290 with less than 100 hours on the bulb. I have used the projector several times over the course of two years without any problem, but never longer than 3 hours at a time. A...
there is an issue with the power supply edge connection with the main board. you'll need to have it sent to an infocus service center for repair. try av solutions in ny. they're pretty good. www.avsolutionsny.com
Nov 24, 2009 | InFocus LP290 1100 Lumen XGA LCD Projector...
Just got new laptop, followed the prompts to start up..got screen saying "preparing your system etc, stopped and rebooted then logged on, then the same screen came up and has been going for about 3...
This screen appears when you have successfully gone through the Windows Setup Wizard entering Computer name, User details, Network settings and Seting the Time and Date.
If you get the problem of the screen appearing for the past 3 hours. I suggest you try and use the Laptop Recovery CD as by using this, this will just recover the system back to origional factory default settings and will not cause any problems with your system.
Try this and itshould work.
Sep 23, 2009 | Toshiba Satellite Pro L300 Notebook
Power Up Hour Glass appears an stays on for 3 hours
This should help. When the hourglass symbol stays on, press and hold down the start button for at least 15 seconds. The screen should clear and then you can navigate back to the correct opening screen and select music, videos, photos etc. as you require.
Nov 26, 2008 | Archos 405 Digital Media Player
Picture takes hours to appear
Spounds like the b+ feed filter capacitor off the flyback that supplys voltage to the three drive transistors on the crt board is bad.
Apr 16, 2006 | Sony KV-32V16 TV
Camera will not respond
hi your memory card had retired buy a new 1 good luck
Apr 01, 2006 | Concord Camera 3346z Digital Camera
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
