Question about Minolta Office Equipment & Supplies
The control panel of my konical minolta c451 display blank screen with the light on the control panel on and the printer boot normally with only the sound of the engine to detect this
  • Minolta Master
  • 6,696 Answers
Replace the control panel
Posted on Feb 18, 2018
  • 3 Answers
SOURCE: c451 Bizhub Konica Minolta printer
press utility. press metercount. press metercount details. press stop 0 0 stop 0 1 to access service mode in service mode look for admin initialialation function
Posted on May 22, 2008
jqsababa967
  • 145 Answers
SOURCE: Konica Minolta c451: Tray 1 is not available
look behind the tray for paper....
if not do the folowning
power machine off from main switch sould be on the side or open the front door it;s on bottom left side.hold down the utility botton while powering on keep holdin untel prompted with message ...TROUBLE RESET press it should say ok than powr machine off wait 20sec power back on
hope that help
keep us posted
Posted on Mar 18, 2009
waqar697
  • 67 Answers
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
Posted on Mar 30, 2009
  • 3940 Answers
SOURCE: Dell Inspiron 9400 display goes blank after a few minutes
If the issue occurs in the safe mode, then I'm suspecting a failure of the LCD backlight. (It warms up and quits) Also see if video stays on using an external monitor. If it does, then the LCD is most likely failing.
If video goes out on an external monitor as well, then the Video card is failing due to overheating. Make sure all vents are free of dust (Clean with canned compressed air) and the all fans are functional (Run the fan test in diagnostics) If fans check up, then video card is failure point. If fans fail diags, replace affected fan 1st
Posted on May 22, 2009
  • 788 Answers
SOURCE: blank HP w1907
If the power light does not turn color and stay's green on startup, it is not a power problem. It is most likely the inverter. If the unit is in warranty, send it out ASAP. Contact HP customer care by email and have the issue logged in.
If in warranty, they will send you a box by FedX second day and have repaired.
This is a 19" monitor and will not be worth paying for repairs if not in warranty.
Posted on Sep 03, 2009
Testimonial: "I am very happy that this guru was able to concisely evaluate the problem from the information provided. "
Power not booting c451
Can i know any message appearing on screen,
any hour glass symbol?
Nov 23, 2016 | Konica Minolta Bizhub C451 Copy-print-scan
Konica minolta c451 not booting after power on
Need to know screen advancement.
konica minolta appearing or
hour glass symbol or screen completely blank or full white...
Nov 22, 2016 | Konica Minolta Bizhub C451 Copy-print-scan
Blank copies on a Konica-Minolta c451 copier/printer.
Black or color or both? Check the transfer roller sponge looking roller on the right side cover that opens
Nov 09, 2016 | Konica Minolta Bizhub C451 Copy-print-scan
Customer has C451 bizhub that has unresponsive control panel except it will make ONE copy after hard reboot. Then no buttons work, particularly the Utility/Counter button. Can't get in to service mo
Hi
The bizhub C451 is a Konica-Minolta machine and I have found a webpage here:
Error Codes Konica Minolta bizhub C451
that details the error codes that can occur on your machine. I know that this may not be of much use as you don't appear to have any error codes appearing. However, there is also a link at the top of the page from which you can get a copy of the Service Manual which will probably have a lot more detail in it and may answer your question.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 28, 2014 | Office Equipment & Supplies
Errore Trouble code C-C172
Refer to Konica Minolta Bizhub C451 Printer/Scanner/Finisher's User Manual or Call Service Center.
May 01, 2014 | Konica Minolta Bizhub C451...
Bizhub C451 error C-3924
c7ff0589-2c1c-428b-8214-5be985c427d0.jpgkonica minolta c451 printing problem
Jul 16, 2012 | Konica Minolta Bizhub C451...
Ensure that the electrical connections both the plug in the wall and the connection at the back of the machine snug! Also good surge protector, on separate circuit? Then next is to have the machine software re-flashed. Must be from secure konicaminolta web site. Technician done
Mar 10, 2012 | Konica Minolta KONICA BR BIZHUB C451...
53 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
