Question about Keurig Coffee Makers & Espresso Machines
OUR KEURIG 2.0 425 PREHEATS PRESS BUTTON WITH LIGHT FLASHING IT STARTS A FEW DROPS THEN OFF AND A SIGN COMES UP WATER UNDER PRESSURE LT STOPS
SOURCE: Washing machine problem
my w830 is doing exactly the same thing.
I am usually pretty good at fixing these sort of things so if/when I solve it I will post back here.
I think it is a motor fault - most likely the motor brushes are worn out.
Posted on Aug 07, 2008
ltfrc
  • 227 Answers
SOURCE: 6 month old 139.53985dm garage door opener shuts off going down
Unplug unit at power source and check and tighten all connections in the control box. And try this link.
http://www.garagedooropeners.us/technical_information.html
Mike
Posted on Mar 22, 2009
flacooo1
  • 172 Answers
SOURCE: Laars Lt heater will not start- pressure switch light
it is time to check your filter make sure is not dirty and if your filter is clean and still doing this then the problem can be with one of the safety sensors they do have 2 hight limit switch located in the heater heather they re round with two wires on each one turn power off to heater and get a voltemer reader and check the hight limits for continuty they should read zero on your metter it can be your temp sensor heaters are so complicated that it is always good to have a pool tech service it I was a pool tech in california but now I am located in georgia
Posted on Jun 15, 2009
SOURCE: The two coffee lights and the water light are flashing
Had the same problem. I sealed my lips around the steam wand and sucked as hard as I could, first with open steam knob, then with closed. Obviously there was some air left inside from steaming before. Machine worked fine afterwards.
Posted on Jan 23, 2010
SOURCE: My triton T100xr shower is flashing low pressure
my triton t100xr shower will work for a while then the low pressure light comes on and the shower shuts down not restarting for quite some time, any suggestions please
Posted on Aug 21, 2010
1650 husky pressure washer starts and then stops
If you are not squeezing the handle to let the water out, it will shut off.
Nov 30, 2013 | Garden
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
Memorex travel speaker with ipod dock speaker system black I cannot set the clock on this item
Hold the "Time Set" button until the time starts flashing, then press the "play/pause" button so that only the hour is flashing. Use the ">>" and "<<" buttons to set the desired hour. Once the hour is set, press the "play/pause" button again so that the minute is flashing. Again, use the ">>" and "<<" buttons to set the desired time.
To change to military time from am/pm, hold the "Time Set" button until the time starts flashing, then press the ">>" button. In order to revert back to am/pm, hold the "Time Set" button until the time starts flashing (if it is not already flashing) and then press the "<<" button.
Sep 16, 2010 | Memorex Travel Speaker with iPod Dock...
How do you set the time and alarm on a MI2290 Memorex Ipod Dock system
Here's how to set the time, but I don't know how to set the alarm.
Apr 07, 2010 | Memorex Travel Speaker with iPod Dock...
Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
May 11, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
B 50, starts and stops right away
My B50 just did the same thing. Since I had registered it I called Keurig and they said it cannot be fixed but they are sending me a new coffee maker. It is still under warranty. Nice folks. This makes me think that it is a known problem that is not worth fixing or can't be fixed easily.
Jun 29, 2006 | Keurig B50 Coffee Maker
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
