CASSIO LK35 ORGAN 1ST 7 KEYS ONLEFTHAND LIGHT UP WHEN AUTOPLAY BUT DONT HAVE ANY SOUND WHEN PRESSED
QS8 keyboard. Why is volume in organ mode much louder than piano mode when I switch between modes without touching volume slide?
On organ mode, in general, almost all brands of the modern keyboard, velocity setting is not enabled. Setting velocity is used to determine how much the level of the sound that follows how strongly you press the keys. It is really just to imitate the sound of vintage organs, which in the past, electronic organ technologi not use the velocity on the keys. So, how strong / slow we press the keys, the sound level will remain the same.
At the Piano mode,modern keyboard using setting velocity. This also to imitate an acoustic piano, which, if we press the keys slowly, the sound level will be slow as well, and vice versa.
So, in your case,at the same volume slider, try to play on the organ modes, note level. Moving to the piano mode and press the keys securely powered (full power). Then the sound level should be equal to the organ mode.
On modern keyboards, also included organ sound that added velocity setting. Usually found on the user bank.
Sep 01, 2015 | Alesis Music
Alesis QS8 keyboard. The volume of the organ is much louder than the keyboard when I switch between both modes without touching the volume slide. How can I fix this.
Thomas playmate color glo organ series 1200
This is not one of the newest organs around. The organ still could have real switches. Like silver threads touching when a key is pressed. sully some oxidation on these contacts should not be noticed while playing, but if you can reach the contacts, try some Contact cleaner on the contacts like Deoxit in the US and Kontact 60 in Europe.
Jul 13, 2014 | Music
I have a Korg Pa800 and it now has 1 key sounds louder than the others, I dont know if I had pressed something wrong. Please help
hi Peter
try to change to organ sound if is not happened the problem is the rubber contact under the keyboard (clean o change the rubber)
Sep 01, 2013 | Korg Pa800 61-Key Professional Arranger...
How do I correct error E1 on a cassio CE-2300
You have turned the key before you finished in the last mode. turn the key back to where you were and finish what you started. If you were in X or Z mode, try pressing subtotal before turning the key. ---------------------------------------------------------------------------------------------------
If anyone needs a Casio CE-2300 manual, go here: http://the-checkout-tech.com/manuals/cashregisters/casio1.php
May 31, 2010 | Casio Parts Cash Register PC Desktop
How to get stock report from cassio TK-6500
For PLU stock balance report
1. Key turn to "X1"
2. Press [6][4] [CA/Amt Tend]
For PLU sold report
1. Key turn to "X1"
2. Press [1][4] [CA/Amt Tend]
Jul 24, 2009 | Casio Parts Cash Register PC Desktop
On my Technics EX-70 organ, have lost my presets that were originally set up by a professional teacher who is no longer available. I need some detailed help in programming the Voice Setting Computer and...
To Big Gord. To program voice setting computer, set up a sound you want press & hold white button then button 1 while still holding
white button. repeat for other setups. before turning organ off always press cancel on VSC should hold settings for next time you use it.
To set upper organ presets, the sequence is shown on page 17 of the manual.
To RishiMalla. To reset organ turn on Fullband Setting Computer switch then press black Inital key on bottom key board.
Feb 28, 2008 | Audio Players & Recorders
Forgotton password for Sharp OZ-730
Hi, I has this problem but I found in the user manual this instructions and works ok: 1. Press and hold the Start key.
2. While holding down the Start key, push the RESET button
on the bottom of the Organizer using a pen or some other
pointed object. The following message will appear.
"Do you really want to initialize the organizer's memory (this will delete all data)? Yes:[ENTER/No:[ESC]
3. Press to initialize the Organizer.
The message .Working... Please wait.. appears while the
Organizer proceeds with the initialization procedure.
The Welcome message then appears.
Jan 04, 2008 | Sharp Wizard OZ-730
Sharp wizard oz-730
Oct 10, 2007 | Sharp Wizard OZ-730
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
