Question about The Office Equipment & Supplies
Have error message "Time for maintenance cassette 1". The machine is fairly new, why am I receiving this and what do we do?
3 Suggested Answers
  • 208 Answers
SOURCE: Error Msg: Maintenance drawer A is missing - Phaser 8200
There is supposed to be an orange chip on the back of that tray.
If that is not present or seating properly that will cause that problem.
Pull out the green tray and see if the chip is snapped on the back ot the maintenance tray.
Posted on Dec 07, 2007
  • 32 Answers
SOURCE: error message
try to re-instal the driver or check the cable
Posted on Sep 09, 2009
Have error message Time for maintenance cassette 1. The machine is fairly new, why am I receiving this and what do we do?
I'd first try to make sure that the Cassette 1 is inserted/seated correctly. Depending on what equipment this is, the cassette that came with it may not have been as full or you have simply used the cassette up sooner than you anticipated.
May 17, 2017 | The Office Equipment & Supplies
Epson 3640 won't copy. Only scans. This just happened? Also new a message insert cassette 1 correctly. Haven't touched cassette??
You have to comply with error messages.
Remove the wall plug.
Remove the cassettes all the way out, most have two. Check inside for paper, or any bits of paper covering the cassette drawer open sensors. Replace the cassettes.
Plug the machine back in.
Dec 30, 2016 | Epson Office Equipment & Supplies
I have a Kyocera FS6530MFP Printer and gives a ' error in cassette 1 ' message. Any clues?
Could be the rollers in that cassette are worn and causing a delay jam (Not picking the next sheet up) Try cleaning them.
Aug 13, 2014 | Kyocera Office Equipment & Supplies
Every time I insert a new cassette, the came gives me the following error message, ' resert the cassette'. Any guesses why I'm running into this error message?
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Feb 06, 2011 | Sony Handycam DCR-TRV280 Digital Camcorder
Error message 71
This error means that there is a scanner motor error. Try and remove the error by following these steps: Press MENU *,2,8,6,4. The machine beeps for approximately 1 second and will display "MAINTENANCE" on the screen, indicating that it is placed in the initial stage of the maintenance mode, a mode in which the machine is ready to accept entry from the keys. Now you are inside the simulation, Press 01 to reset the error status. After that press 99 to exit the simulation.
- Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine exit from the maintenance mode, restoring it to the standby state.
- Pressing the Stop button after entering only one digit restores the machine to the initial stage of the maintenance mode.
If the error comes back call Brother support, here are the contact details:
7777 North Brother Blvd.
Bartlett, Tennessee 38133
Phone: 1-877-BROTHER (877-276-8437)
901-379-1215 (fax)
Monday-Friday, 9:00am to 8:00pm Eastern Time
Feb 14, 2010 | Brother MFC 8440 All-In-One Laser Printer
I change replace all ink in my brother mfc-5100c after that I receive this message: "Machine error 41, unplug the machine call brother". Please,What can I do to fix it? I rely on you for any assitance.
Machine Error 41means the printhead is bad. It's a fairly easy repair on that model, but an expensive part and requires replacing all four ink cartridges at the same time. New machines are so much smaller and cheaper that it may not be worth it. There are also some setting that must be changed in Service Mode to match the machine to the characteristics of the new head.
If you're still interested, look for Brother part number LK0935001.
Jun 01, 2009 | Brother MFC 5100c InkJet Printer
Error message
Mar 16, 2009 | Office Equipment & Supplies
Brother MFC-9700 error message says "reinstall cassette #2 properly". It is installed properly. Turned machine off. looked inside, no paper jambs, cassette seems to be okay, reinstalled just...
I just experienced the same issue, and from research it looks like there is an optional second paper cassette that you can purchase. If it is set to have the second cassette turned on and you don't have that option the machine is looking for something that does not exist. In my case cassette #2 was turned on via the menu (Menu, Option 1 (General Set-up), Option 5 (Cassette #2), make sure it is set to "off"). Once Cassette #2 was set to off the machine started working properly again.
Jul 10, 2008 | Brother Office Equipment & Supplies
Reinsert cassette error... cannot record via tape
What error message is it giving to you ?? as this will be a good indication of fault.You have tried all the usual things to try by the sounds of things,
May 14, 2007 | Sony Handycam DCR-HC46 Mini DV Digital...
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
Top The Office Equipment & Supplies Experts
Victorman
Victorman
micky dee
fhonwizards
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
