Question about Garden
Replaced pto clutch and switch, when I turn on deck, blades start to spin, then motor dies
  • 202 Answers
SOURCE: Husqvarna yth2448 pto switch kills motor/battery will not charge
you may hav a bad alt. problem with the mower dying when you engage the pto is most likley a bad sensor or wire unplugged on the seat sensor.the way it works is if the blades are turning and it dosent sense you being on the seat the mower shuts down.this has been standard on mowers for quite a few years now. it keeps the blades from cutting you up if you fall off the seat while mowing. as for charging i would try cleaning the battery connections and get the battery checked first.
Posted on Jul 19, 2009
  • 153 Answers
SOURCE: When I engage the front PTO the engine dies.
There is somthing in the PTO that is binding up. I am assuming the PTO is for the mower blades. The belt(s) could be binding up, not on the pulleys, etc. The blades should turn by hand easily.
Posted on Oct 14, 2009
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
huffman49
  • 235 Answers
SOURCE: Riding mower stalls when PTO is engaged.
check the kill switch and the wire it could be that a small piece of the covering came off and is grounding to the deck or frame there by killing the engine the jerkink of the mower maybe whats causing the wire to come into contact with metal..good luck
Posted on Apr 03, 2010
  • 18 Answers
SOURCE: PTO loads engine down and almost quits running!
pto is going bad
Posted on Jun 06, 2010
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
Sep 19, 2008
Apr 6, 2008
Sep 25, 2015 | Cub Cadet Garden
Husqvarna yth2148 mower dies when clutch is released or deck is engaged. has new seat switch, clutch switch and pto switch whats my solution
Has the belt been replaced recently? A two small belt with kill the motor due to too much tension on the driveshaft. Also make sure blades spin relatively well. I'd be looking for excess tension.
Sep 12, 2013 | Garden
X520 jd mower trouble
Sounds like a problem with the governor. Start it up. Don't engage the blades. Drive to a hill. Idle all the way down. Try driving up the hill. The motor should pick up when it slows while pulling up the hill. If it doesn't, the governor isn't working right.
Jul 16, 2013 | Garden
On John Deere lawn tractor when we pull the yellow button up to engage the blades to start spinning, they dont move.
If you have an electric pto switch, the switch, connecting wire from the switch to the pto clutch, or the clutch itself could be defective. You can check the switch and wire with an ohm meter. You can also check for proper voltage at the pto clutch plug.
Sep 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
PTO will not engage blades on riding mower. The
Using a test light or volt meter, check to see if you are getting a full 12 volts at the connector where the PTO plugs in. If no voltage present, locate the fuse for the PTO and check it, also check the PTO switch to see if it is working. You can turn on the ignition switch to the run position, don't start the engine, and turn the PTO switch on and off several times listening for a clicking sound. If you hear it clicking, have someone sit in the seat and start up the engine, while it is running, observe the PTO clutch and see if it spins when turned on and if the belt turns with it. If none of this works, post a follow up and include your Craftsman Model number. I will look it up and see if I can find anything else we might be missing
Sep 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine chokes & dies when deck PTO engaged...
you need to start with your electric clutch and then backwards to your idler pulleys and deck spindles and bearings.
your electric clutch should almost stop the blades instantly when disengaged ,check the center bolt in the clutch to be sure it is tight also
remove the belt from the electric clutch and energize clutch any noise? sometimes the bearing goes bad in the clutch itself.
check all of your 3 spindles for noise and loose. remove belt and spin by hand and listen for quiet and they should turn free with no binding
check blade tightness
any item the belt goes around needs to be looked at for secure and operable.
Jun 08, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Pto willl not engage
Hi mate, Although my trade is repairing turfcare machinery, I have no experience with this model, so I will try my best. Firstly, the clicking you hear will probably be the electric clutch engaging/dissengaging. Firstly, see if you can get the clicking with engine off, keyswitch in first position/on/lights on dash. You may have to place something heavy on the seat and have traction pedal in neutral. MAKE SURE YOU DO NOT ENGAGE THE STARTER MOTOR/START THE ENGINE THROUGHT THIS!
Now have a look under the footwell on top of the deck and try to determine where the clicking is coming from, there will be a clutch there somewhere joining the engine drive pulley to a deck pulley, Also at this point check that both belts are on and with the ENGINE OFF! spin the blade/blades with your hand and ensure that the deck belts are not slipping on the deck pulleys. If they are you will need to establish where the tensioning system is. (Sorry i know pretty vague)
Back to the Clutch, once you establish where it is, engage the blades ENGINE OFF! and you should feel a greater resistance turning the blades as you are now turning the engine as well, beware though, it is theoretically possible to start the engine by doing this, but you will almost certainly not be able to spin the blades that quickly by hand.
If it is clicking to engage but not turning the engine pulley when spinning the blades by hand, then try tapping the clutch lightly as it may not be fully dissengaging.
I would put money on it being either one of the belts coming off/snapping, the blades jamming or the clutch not engaging fully.
If you find that the clicking is not the clutch engaging and its actually getting no power to the clutch then you need to go back to the pto switch and go through all safety switches! (good luck, it usually ends up with me bypassing them or running a new cable to the switch,then, smoke, shouting, swearing etc etc!) Either not advisable.
In doing all this you should have been able to have determined the problem be it one that I have mentioned or another.
Hope this helps,
Chris.
May 30, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Engine dies when engaging PTO switch on a John Deere GT235. I have replaced the seat switch and the PTO switch.
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Feb 21, 2009 | Garden
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
