60 mm to inches - Office Equipment & Supplies
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 6 Answers
About 1 1/4 inches.
Posted on May 18, 2017
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Sep 28, 2016 | John Deere Garden
Can I put 235/60R16 on 2008 chevy uplander
The stock wheel and tire is ;
wheel - 17 x 6.5 inches
TIRE - 225 60 17 702 mm diameter
If you wanted a 235 60 17 that would be ok but the tire diameter is larger by a small margin.
If you are reducing wheel size with 16 inch wheels in order to fit the 16 inch tires mentioned in your question you better make sure that the smaller diameter wheel will clear the brakes front and rear.
For a 235 tire the wheel width will need to be 6.5 inches minimum.
So if you go with ...............
wheel- 16 x 6.5 or 16 x 7 inch
TIRE - 235 60 16(as in your question)- 688 mm diameter
Provided the 16 inch wheel clears the brakes that would be OK but that tire is slightly smaller in diameter than stock but within an acceptable margin.
Make sure whatever tire you select that the tire load rating is not less than the stock tire and not less than the tire load rating stipulated by General Motors for that vehicle..
Feb 28, 2016 | Cars & Trucks
Avalanche minimum rotor thickness
Rear Brakes JC5/JH5 Utility Only
Rotor Discard Thickness* .............................. 28.50 mm (1.122 inch)
Rotor Minimum Allowable Thickness After Refinish ....... 29.0 mm (1.142 inch)
Rotor Thickness-new .................................... 30.0 mm (1.181 inch)
Rotor Maximum Allowable Lateral Runout ................. 0.05 mm (0.002 inch)
Rotor Maximum Allowable Scoring ........................ 1.50 mm (0.059 inch)
Rotor Maximum Allowable Thickness Variation ........... 0.025 mm (0.001 inch)
Rear Brakes JH6
Rotor Discard Thickness * ............................. 27.50 mm (1.082 inch)
Rotor Minimum Allowable Thickness After Refinish ....... 28.0 mm (1.102 inch)
Rotor Thickness-new .................................... 29.0 mm (1.141 inch)
Nov 12, 2013 | 2002 Chevrolet Avalanche
Computer case fan for Gateway Performance, mid-tower case
Case fan size is typically measured in mm. Common sizes include 40, 60, 80, 92, 120 and 140 mm. OEM cases can have proprietary fan sizes as well.
Jun 12, 2012 | Gateway Computers & Internet
Excuse me i have a suzuki savage 650 1987 and y want to know what is the timinng for this motorcycle, please help me .... thanks
here are some specifications i hope they help you
Manufacturer (Make) Suzuki Model Name LS 650 Savage Year 1986 Category(class) Cruiser / Chopper / Custom Engine Engine Capacity (Displacement) 652 ccm (39.79 cubic inches) Engine Type 1 cylinder Bore x Stroke ?94.0 mm x 94.0 mm (?3.7 inches x 3.7 inches) Bore/Stroke Ratio 1 Stroke 4 Valves per Cylinder 4 Timing System OHC Cooling System Air Powertrain Gearbox 4 speed Chassis/Suspension/Brakes Front Brakes Single disc Rear Brakes Drum Front Tire 100/90-19 Rear Tire 140/80-15 Dimensions Curb Weight 171 kg (377 lb) Fuel Capacity 11 litres (2.91 gallons) Performance Max Power 27.00 HP (19.7 kW) at 5200 RPM Power/Weight Ratio 0.16 Hp/Kg Top Speed 127 km/h (79mph) Acceleration (dart, speedup) time
0-100 km/h 9.2 seconds 0-60 mph 8.7 seconds
  • 1/4 mile
  • 60 to 140 km/h, highest gear
    also heres a link of a almost complete tare down and rebuild
    http://www.motorcycleforum.com/showthread.php?t=102346
    Mar 25, 2011 | 1986 Suzuki LS 650 Savage
    What is the clearance for rod bearings on the crank of a 98 ford f 150 4.6
    General Specifications Item Specification
    Displacement L (CID) 4.6 (281)
    Number of Cylinders 8
    Bore and Stroke mm 90.2 x 90.0
    Firing Order 1-3-7-2-6-5-4-8
    Oil Pressure (HOT @ 1500 rpm) kPa 138-310
    Drive Belt Tension a
    Cylinder Head and Valve Train
    Combustion Chamber Volume cm 52?±.5
    Valve Seats Width?€"Intake mm 1.9-2.1
    Valve Seats Width?€"Exhaust mm 1.9-2.1
    Valve Seats Angle 44.51-45.01 degrees
    Valve Seats Runout (T.I.R.) Max mm 0.025
    Valve Arrangement (Front-to-Rear) (Left Hand) E-I-E-I-E-I-E-I
    (Right Hand)
    I-E-I-E-I-E-I-E
    Valve Stem to Guide Clearance?€"Intake mm (Inch) 0.020-0.069
    (0.00078-0.00272)
    Valve Stem to Guide Clearance?€"Exhaust mm (Inch) 0.045-0.095 (0.0018-0.0037)
    Valve Head Diameter?€"Intake mm (Inch) 44.5- (1.75)
    Valve Head Diameter?€"Exhaust mm (Inch) 34.0 (1.34)
    Valve Head Diameter?€"Gauge Diameters mm (Inch) 42.5- and 32.0
    (1.67 and 1.26)
    Valve Face Runout Limit mm (Inch) 0.05 (0.002)
    Valve Face Angle 45.25-45.75 degrees
    Valve Stem Diameter (STD)
    ?€"Intake mm (Inch) 6.995-6.975 (0.275-0.2746)
    Valve Stem Diameter (Std)
    ?€"Exhaust mm (Inch) 6.970-6.949 (0.274-0.2736)
    Valve Springs?€"
    Compression Pressure N @
    Spec. Length?€"Intake 587.14 N @ 28.02 mm
    Valve Springs?€"
    Spec. Length?€"Exhaust 587.14 N @
    28.02 mm
    Valve Springs?€"Free
    Length ( Approximate)?€"
    Intake mm (Inch) 49.55 (1.951)
    Length (Approximate)?€"
    Exhaust mm (Inch) 49.55 (1.951)
    Valve Springs?€"Installed
    Pressure N @ Spec. Length
    ?€"Intake 244.64 N @ 40.0 mm
    Valve Spring?€"Installed
    ?€"Exhaust 244.64 N @ 40.0 mm
    ?€"Service Limit 10 % Pressure Less @ 28.02 mm
    ?€"Out of Square Limit 2 degrees
    Valve Guide Inner
    Diameter mm (Inch) 7.015-7.044 (0.2761-0.2773)
    Rocker Arm?€"Ratio 1.75:1
    Valve Tappet?€"Diameter
    (STD) mm (Inch) 16.000-15.988 (0.66-0.629)
    Valve Tappet?€"Clearance
    to Bore mm (Inch) 0.018-0.069
    (0.00071-0.00272)
    Valve Tappet?€"Service
    Limit mm (Inch) 0.016 (0.00063)
    Valve Tappet?€"Hydraulic
    Leakdown Rate b 5-25 seconds
    Valve Tappet?€"Collapsed
    Valve Tappet Gap?€"
    Desired mm (Inch) 0.085-0.45 (0.0033-0.0177)
    Camshaft
    Lobe Lift?€"Intake
    mm (Inch) 6.58939 (0.2594)
    Lobe Lift?€"Exhaust
    Lobe Lift?€"Allowable
    Lobe Lift Loss mm (Inch) 0 (0)
    Theoretical Valve Lift @
    Zero Lash?€"Intake
    mm (Inch) 12.0 (0.472)
    Zero Lash?€"Exhaust
    End Play mm (Inch) 0.025-0.165
    (0.00098-0.0065)
    Journal to Bearing
    Clearance mm (Inch) 0.025-0.076
    (0.00098-0.003
    Journal to Bearing
    Clearance?€"Service Limit
    mm (Inch) 0.021 (0.0048)
    Journal Diameter (All)
    mm (Inch) 26.962-26.936
    (1.061-1.060)
    Journal Diameter (All)?€"
    Bearing Inside Diameter
    (All) mm (Inch) 27.012-26.987
    (1.063-1.0625)
    Camshaft Runout
    Cylinder Bore
    Diameter?€"Surface Finish
    (RMS) 0.2-0.6 Microns
    Diameter?€"Out-of-Round
    Limit mm (Inch) 0.015 (0.0006)
    Service Limit mm (Inch) 0.020 (0.00079)
    Diameter?€"Taper Service
    Limit mm (Inch) 0.006 (0.00023)
    Piston
    Piston?€"Diameter?€"
    Coded Red 1 mm (Inch) 90.177-90.197
    (3.550-3.551)
    Coded Blue 2 mm (Inch) 90.190-90.210
    (3.5507-3.5515)
    Coded Yellow 3 mm (Inch) 90.203-90.223
    (3.513-3.5521)
    Piston-to-Bore-Clearance
    mm (Inch) -0.015 + 0.031 (0.0005-0.0012)
    Pin Bore Diameter
    mm (Inch) 22.0015-22.004
    (0.866-0.8663)
    Ring Groove Width?€"
    Compression (Top)
    mm (Inch) 1.520-1.550 (0.06-0.610)
    Compression (Bottom)
    mm (Inch) 1.520-1.530 (0.060-0.0602)
    Ring Groove Width?€"Oil
    Ring mm (Inch) 6.996-7.224 (0.275-0.2844)
    Piston Pin?€"Length
    mm (Inch) 61.93-62.05 (2.44-2.443)
    Diameter mm (Inch) 21.994-21.999
    (0.866-0.8661)
    Pin to Piston Clearance
    mm (Inch) 0.005-0.010
    (0.0002-0.0004)
    Pin to Rod Clearance
    mm (Inch) 0.015-0.040
    (0.0006-0.00157)
    Piston Rings?€"Ring Gap
    ?€"Compression (Top)
    mm (Inch) 1.0 MAX (0.0394)
    Oil Ring?€"Side Clearance
    mm (Inch) 1.25 MAX (0.05)
    Oil Ring?€"Compression
    (Top) mm (Inch) 0.040-0.090
    (0.0016-0.0031)
    (Top) mm (Inch) 0.030-0.080
    (0.0012-0.00031)
    Oil Ring Snug Fit
    Oil Ring?€"Service Limit
    mm (Inch) 0.015 MAX (0.0006)
    Ring Gap?€"Compression
    (Top) mm (Inch) 0.23-0.49
    (0.01-0.02)
    (Bottom) mm (Inch) 0.23-0.49
    (0.01-0.02)
    Ring Gap?€"Oil Ring (Steel
    Rail) mm (Inch) 0.05-0.66 (0.006-0.026)
    Lubrication System
    Oil Capacity?€"Automatic
    Transmission (Quarts U.S.) 6.675?±0.125
    Oil Capacity?€"Manual
    Transmission (Quarts U.S.) 6.425?±0.125
    Cylinder Block
    Main Bearing Bore
    Diameter mm (Inch) 72.401-72.422 (2.85-2.851)
    Crankshaft and Flywheel
    Main Bearing Journal
    Diameter mm (Inch) 67.483-67-503 (2.65-2.657)
    Connecting Rod Journal?€"
    Diameter mm (Inch) 52.988-53.003
    (2.0861-2.0867)
    Crankshaft Free End Play
    mm (Inch) 0.130-0.301 (0.0051-0.012)
    Crankshaft Runout to Rear
    Face of Block mm (Inch) 0.050 MAX (0.002)
    Connecting Rod Bearings
    Clearance to Crankshaft?€"
    Desired mm (Inch) 0.027-0.069 (0.001-0.0027)
    Allowable mm (Inch) 0.027-0/069 (0.001-0.0027)
    Bearing Wall Thickness
    (STD) mm (Inch) 2.44-2.452 (0.096-0.0965)
    Main Bearings
    Desired mm (Inch) 0027-0.065
    (0.0011-0.0026)
    Allowable mm (Inch) 0.027-0.065
    (0.0011-0.0026)
    (STD) mm (Inch) 1.920-1.928 (0.075-0.076)
    Connecting Rod, Piston and Rings
    Connecting Rod?€"Piston
    Pin Bore Diameter
    mm (Inch) 21.959-21.979
    (0.864-0.865)
    Connecting Rod?€"
    Crankshaft Bearing Bore
    Diameter mm (Inch) 56.756-56.876 (2.234-2.24)
    Connecting Rod?€"Length
    (Center-to-Center)
    mm (Inch) 150.7 (5.93)
    Alignment (Bore-to-Bore
    Max. Diff.) c ?€"Twist
    mm (Inch) 0.050 per 25 (0.0015-0.984)
    Max. Diff.)?€"Bend
    mm (Inch) 0.038 per 25 (0.0015-0.984)
    Side Clearance (Assembled
    to Crank)?€"Standard
    mm (Inch) 0.015-0.45 (0.0006-0.0177)
    to Crank)?€"Service Limit
    mm (Inch) 0.05 MAX (0.02)
    Crankshaft Main Bearing
    Journal Taper mm (Inch) 0.020 (0.0007)
    Journal Runout mm (Inch) 0.05 (0.002)
    Crankshaft Connecting Rod
    Journal Taper mm (Inch) 0.015 (0.0006)
    Feb 15, 2011 | 1998 Ford F150 Regular Cab
    The copies are dirty, with black long tracks!
    I would suggest either a fuser problem, If all Colors affected, or the Black Toner Cartridge. The Below chart may help isolate which component is malfunctioning. Repetitive image defects Measurement Component 24.7 mm (0.97 inch) Developer sleeve (Print Cartridge) 26.7 mm (1.05 inches) Charge roller (Print Cartridge) 32.9 mm (1.3 inches) RS roller 37.7 mm (1.48 inches) Transfer roller (ETB) 54.5 mm (2.15 inches) ETB rollers (ETB) 56.6 mm (2.22 inches) Fuser sleeve (Fusing Assembly) 62.8 mm (2.47 inches) Pressure roller (Fusing Assembly) 75.4 mm (2.97 inches) OPC (Print Cartridge)
    Jan 13, 2011 | HP Color LaserJet 2600n Printer
    Shows out of paper. Says paper jam. Open door . Clear carriage. Press ok. Cannot solve problem!!! 75 years old with 1st computer!
    Out of paper
    Cause: There is not enough paper in the input tray.
    Solution: If the HP All-in-One is out of paper or there are only a few sheets
    remaining, load more paper in the input tray. If there is paper in the input tray, remove
    the paper, tap the stack of paper against a flat surface, and reload the paper into the
    input tray. To continue your print job, press OK on the control panel of the HP All-in-
    One.
    Cause: The rear door is off the HP All-in-One.
    Solution: If you removed the rear door to clear a paper jam, replace it.
    rear door.
    Paper can also jam in the automatic document feeder. Several common actions can
    cause paper to jam the automatic document feeder:
    • Placing too much paper in the document feeder tray. For information on the maximum
    number of sheets allowed in the automatic document feeder, see Technical
    information.
    • Using paper that is too thick or too thin for the HP All-in-One.
    • Trying to add paper to the document feeder tray while the HP All-in-One is feeding
    pages.
    To clear a paper jam from the rear door
    1. Press in the tab on the left side of the rear door to release the door. Remove the door
    by pulling it away from the HP All-in-One.
    CAUTION: Trying to clear a paper jam from the front of the HP All-in-One can
    damage the print mechanism. Always access and clear paper jams through the
    rear door.
    Paper specifications
    This section contains information about paper tray capacities, paper sizes, and print margin
    specifications.
    • Paper tray capacities
    • Paper sizes
    • Print margin specifications
    Type Paper weight Input tray1 Output tray2 Document
    feeder tray
    Plain paper 16 to 24 lb. (60 to
    90 gsm)
    up to 100
    (20 lb. paper)
    up to 50
    (20 lb. paper)
    up to 35
    Legal paper 20 to 24 lb. (75 to
    90 gsm)
    up to 100
    (20 lb. paper)
    up to 50
    (20 lb. paper)
    up to 20
    Cards up to 110 lb.
    index (200 gsm)
    40 10 N/A
    Envelopes 20 to 24 lb. (75 to
    90 gsm)
    15 10 N/A
    Transparency film N/A 25 25 or fewer N/A
    Labels N/A 20 20 N/A
    4 x 6 inch photo
    paper
    up to 145 lb. (236
    gsm)
    30 10 N/A
    8.5 x 11 inch photo
    paper
    N/A 40 20 N/A
    1 Maximum capacity.
    2 Output tray capacity is affected by the type of paper and the amount of ink you are using.
    HP recommends emptying the output tray frequently.
    Paper sizes
    Type Size
    Paper Letter: 216 x 280 mm (8.5 x 11 inches)
    A4: 210 x 297 mm
    Chapter 15
    266 Technical information
    Type Size
    Legal: 216 x 356 mm (8.5 x 14 inches)
    Envelopes U.S. #10: 105 x 241 mm (4.125 x 9.5 inches)
    U.S. #9: 98 x 225 mm (3.9 x 8.9 inches)
    A2: 111 x 146 mm (4.4 x 5.8 inches)
    DL: 110 x 220 mm (4.3 x 8.7 inches)
    C6: 114 x 162 mm (4.5 x 6.4 inches)
    Transparency film Letter: 216 x 279 mm (8.5 x 11 inches)
    A4: 210 x 297 mm
    Premium photo paper 102 x 152 mm (4 x 6 inches)
    A4: 210 x 297 mm
    Cards A6: 105 x 148.5 mm
    Index card: 76 x 127 mm (3 x 5 inches)
    Index card: 101 x 152 mm (4 x 6 inches)
    Labels Letter: 216 x 279 mm (8.5 x 11 inches)
    A4: 210 x 297 mm
    Custom 102 x 152 mm up to 216 x 356 mm (4 x 6 inches up to 8.5 x 14
    inches)
    Top (leading edge) Bottom (trailing
    edge)
    Left and Right
    margins
    U.S. Letter
    U.S. Legal
    A4
    Photo media
    1.8 mm (0.07 inches) 2 mm (0.12 inches) 2 mm (0.12 inches)
    U.S. Executive
    B5
    A5
    Cards
    1.8 mm (0.07 inches) 6 mm (0.24 inches) 2 mm (0.12 inches)
    Envelopes 16.5 mm (0.65
    inches)
    16.5 mm (0.66
    inches)
    3.3 mm (0.13 inches)
    Print specifications
    • Resolution: 1200 x 1200 dpi black, 4800 optimized dpi color or 6 ink
    • Method: drop-on-demand thermal inkjet
    • Language: Lightweight Imaging Device Interface Language (LIDIL)
    • Print speed varies according to the complexity of the document
    (continued)
    Print specifications 267
    Copy specifications
    • Digital image processing
    • Up to 100 copies from original (varies by model)
    • Digital zoom: from 25 to 400% (varies by model)
    • Fit to page, pre-scan
    • Copy speeds vary according to the complexity of the document
    Mode Type Scan resolution
    (dpi)1
    Best Black up to 600 x 1200
    Color up to 600 x 1200
    Normal Black up to 300 x 300
    Color up to 300 x 300
    Fast Black up to 300 x 300
    Try clearing all paper from all carriages (Top,Rear, Front, etc. then reinserting proper amounts. Even the smallest piece of paper can cause a jam. Here is a user manual in case you don't have one you can get it here: http://h10032.www1.hp.com/ctg/Manual/c00844812.pdf
    This is a PDF and it is searchable and easy to navigate (Red lettering will take you to that section), so you will need Adobe Acrobat Reader (if you don't already have it you can get free here:
    http://get.adobe.com/reader/
    Also, once you have done all you can turn the printer off for a moment then turn it back on.
    Hope this helps. Good luck
    If this helps you resolve your problem, please
    consider giving me a good rating and a quick thanks
    or good job.It will help me as well Thank you.
    Oct 26, 2010 | HP Officejet J5780 All-In-One InkJet...
    My hp lazer jet 1600 is making big black horozonal
    Measure your marks and replace whatever is indicated by this chart.
    Nov 09, 2009 | Office Equipment & Supplies
    19 people viewed this question
    jasbo
    jasbo
