LK35 1ST 7 KEYS ONLEFTHAND LIGHT UP WHEN AUTOPLAY BUT DONT HAVE ANY SOUND WHEN PRESSED
Optical drive D: repair in windows 8.1
Sounds like Autoplay is not configured. You can see how to change your Autoplay settings on Microsoft's web site here: http://windows.microsoft.com/en-us/windows/change-autoplay-settings#1TC=windows-7. Autoplay is a strange duck, doesn't always work regardless of settings. You can also open 'computer', which in Windows 81 shows as your User Name, not 'Computer' or 'My Computer' like older versions, then right-click Drive: D, and click 'Play with VLC Media Player', which is the best player I believe - I've used it for years.
Feb 11, 2014 | Toshiba Satellite S955-S5376 15.6-Inch...
I dont know how to install microscoft office excel 2007
When you put your office cd in your cd rom it will autoplay(if autoplay is enabled on your pc) and start installing automatically.The only thing it will ask is key.Just enter that and click next it will install.
If autoplay is not enabled open cd and click on setup it will install.
Aug 05, 2011 | Microsoft Office Professional 2007 Full...
The Camera Window, which used to open automatically in WinXP, does not open in Windows 7. It stilll works, if openned manually. How to fix the automatic openning after connecting the camera?
This is an issue with AutoRun/AutoPlay. Microsoft has turned off the feature for some devices with external storage due to media loaded with malware of various types.
Click on Start > Control Panel > Hardware and Sound > AutoPlay. See if your camera is listed in the devices section. If it is, then set the AutoPlay to open the Camera Window. Otherwise, you will need to continue opening the window manually.
I wish that I had better news.
(the people who write malware for zero-day problems caused hassles for all the other normal users.)
Mar 13, 2011 | Canon PowerShot A1100 IS Digital Camera
Im having problems with my plug and play and or autoplay, whenever I put in my memory card the options dont pop up but it is recognized.
There should be no problem if the options box does not pop up but the card is still recognized. However, if you want to see the options box, then follow the following procedure.
To fix this you will need to change your autoplay settings. If you are still running windows xp, then you need to go to microsoft and get this download. It is a program that will attempt to fix your autoplay settings. If you are running windows vista or windows 7, then you need to find your autoplay settings in the control panel to change your settings.
Mar 08, 2011 | Gateway GX7018E PC Desktop
My CD ROM's Auto-load/Auto-exe is not working. I put in CD software and it doesn't load it. I put in a DVD movie and it doesn't auto-play.
Enabling AutoPlay in Windows XPEnable through Windows Explorer
  1. Open My Computer or Explorer
  2. Right-click the CD-ROM drive or other drive and click Properties.
  3. Click the AutoPlay tab. Within this section you will be able to specify all Windows AutoPlay features.
Enabling AutoPlay in Windows7 and Vista
http://www.techtalkz.com/windows-7/516004-how-configure-autoplay-settings-windows-7-a.html
Aug 23, 2010 | HP Pavilion dv6000z Notebook
When i plug in external hard drive and put in dvd Auto play doesnt appear???can u help
For that you need to enable "Auotoplay" option in Group Policy on computer.
For that press windows key + R or go to start menu click on run so you can see run.
Type in run "gpedit.msc" then press enter then you can see group policy of computer.
Go to user configuration->system->
Then you can see "turn off autoplay" in right pane double click on it and disable it then apply and ok.
Then restart computer for take effect.
Then autoplay will work.
Let me know if you need further assistance.
Thanks for using FixYa.
May 14, 2010 | Microsoft Windows XP Professional for PC
7/8,9/10 work but1/2-3/4-5/6 will not light up keypad entry-door
if the ones dont light when pressing. the keypad will need to be replaced, , then the code in trunk should work, the code prob contains numbers that dont work
Jan 21, 2010 | 2001 Lincoln Continental
Hi, my asus drw-20B1LT has suddenly stopped autoplay i seam to have latest drivers from MS,gone to properties checked autoplay all ok,put a game ect in nothing(reg prog on my computer/dvd-rom) if i hit...
Try this: Open Registry editor (Start > Run > (Type regedit and press enter) Open the following key (You will have to keep on clicking several keys to get to this starting with HKEY_CURRENT_USER)
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
Double click 'NoDriveTypeAutoRun' key on right and set the value to 'b9'
Close registry editor, restart and try.
Aug 25, 2009 | ASUS (GENEIRC DRW-1608P BLACK)...
My computer does not have a AutoPlay feature in it so I can insert and run my Cd-ROM PC games. It must have come with one but I can't find it.
Enabling AutoPlay on a data and audio CD (Windows XP)
  2. Highlight the CD-ROM drive, right-click the CD-ROM drive and click properties.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 26, 2008 | HP Computers & Internet
Anti viurus Problem
And you proberly didnt get any virus "copy.exe is a dos command found in most computers but now obsolete. Methinks you pressed the wrong key and should just brush it aside. IF there are files on that pen and you want to copy them across to your computer then drag them across rather than use the Autoplay. Windows is real friendly you need not follow its intruction sometimes there are other ways one needs to learn in how to do things? Please dont get me wrong Im not putting you down but a computer is for experimenting so you learn sometimes there are things on there that the creator knows nothing of.
Sep 24, 2007 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
