Question about Microwave Ovens
I have model lra18hmu2 ser# kk31058750 unit comes on and cuts off sometimes it will stay on for a while works fine , then sometimes when unit works the control panel has no control over the unit
Got swan sm2060R microwave. Plugged it in clock is set but no functions working
test the power outlet plug some lamp desk if work is o.k if NOT reset the c. breaker. follow this stepFirst check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
God bless you
Apr 04, 2013 | Microwave Ovens
Samsung microwave not working
God bless you
Apr 02, 2013 | Samsung Microwave Ovens
Hi. my micromark MM60106 oven seems to be dead ,no red light, no heat ,no fan. power is getting to the switch but nothing works, do I need a new selector switch
Try using the VOM
Apr 02, 2013 | Microwave Ovens
Wont turn on
see this causes and fix it. God bless you
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Oct 10, 2012 | Daewoo KOR6N9RR Microwave Oven
Won't run
Test the switchs door see diagram
Oct 10, 2012 | Frigidaire FMV156DC Microwave Oven
Kenmore microwave 911 41479791 no power?
Sep 24, 2012 | Microwave Ovens
Panasonic Counter top Microwave model # NNT695SF Often when I push the start button, the microwave will go for a few seconds and then cut out. I then open the door and then shut the door and push the...
Issue with your Main Panel Power Fail to innitiate ..Du to Component mal-functioning inside the unit ...Possibility Magnetron defect, Or main Transformer Over heat, Also check for safety swich on the door for bad connection...
Sep 30, 2010 | Panasonic NN-T695SF Microwave Oven
Microwave cut off
the main control board is "seeingf" a high amprage draw from the inverter board . you have a problem with the inverter or the magntron . parts are more than a new unit . try to stay away from the inverter type , there just not ready for prime time . google "panasonic inverter reviews " and you will see just common your problem is good luck
Jan 16, 2009 | Panasonic NN-S753 Microwave Oven
Microwave Ovens Logo
22 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
