Question about Pioneer Car Audio & Video
Installed a pioneer avh-x5700bhs d-din reciever. It will not turn off. Yellow is constant power, red ignition,and orange illumination. Any ideas?
  • 4102 Answers
SOURCE: re sent wire diagram gat all messed up
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Posted on Apr 21, 2008
  • 64 Answers
SOURCE: pioneer AVH-P5700 instalation
You can find a wiring diagram for your 87 monte at You can refer to the installation manual for your deck at Since you are removing a shaft style radio and installing a DIN style you will need to perform extensive modifications to your dash. The Pioneer manual provides the dimensions.
Posted on Nov 25, 2008
SOURCE: My Head Unit wont turn OFF??? Pioneer AVH-P3100DVD
sounds like when you wired the harness up you messed up some where, make sure all the wire colors match up.. yellow to yellow red to red.
Posted on Dec 28, 2009
  • 69 Answers
SOURCE: install a pioneer AVH-P6800DVD
Here is a link to the manuals for this device:
1st manual is the installation manual, it is mislabled.
Posted on Feb 15, 2010
  • 5660 Answers
SOURCE: When I turn the computer on I get a buzzing noise
The LED lights on the Front Panel are Diagnostic Lights.
LED's 3, and 4 being illuminated, indicate a problem with the ram memory modules (Sticks), according to Dell.
This is Dell Support, and the Service Manual main menu, for the Dimension E520,
On this main menu page left-click on - Advanced Troubleshooting.
Now click on - Diagnostic Lights
Look at the chart.
My diagnoses is different. I think it is a Power Supply issue.
Do you have more than one ram memory module ('Stick') installed in your computer?
Basic procedure, implementing safety guidelines both for you, and your computer.
Computer off, And unplugged from power.
Open the computer case, and touch the metal frame.
Your body carries Static electricity. Touching the metal frame of the open computer case, will relieve your body of Static. (Computer unplugged from power first)
Static electricity will fry out, (Short Circuit), the hardware components inside a computer ]
In the main menu you can click on - Removing and Installing Parts, for guidance in opening your computer case, and removing/installing ram memory modules.
(Removing the Computer Cover, and Memory, respectively)
If you have one memory module, remove it, and clean the gold plated contact pins on the bottom, with a pencil eraser.
Use care, and refrain from touching the contact pins with your fingers.
You can hold the ram module anywhere on the body of it, as the body is coated with a see-through plastic.
Apply the pencil eraser to the top of each contact pin, and stroke down with the eraser.
A side to side motion is not a good idea, as well as starting from the bottom of the contact pin, and going up.
[This is DDR Sdram, and not DDR2 Sdram that is used in your computer.
I linked it to show you a close up view of the gold plated contact pins, and the Black DRAM chips on the side of the ram module,
The top of the contact pin is is close to the DRAM chips.
{DDR Sdram has 184 contact pins. 92 on each side.
DDR2 Sdram has 240 contact pins. 120 on each side]
After you clean the contact pins with the pencil eraser, use air from you, or a can of compressed air for computers, to remove the eraser 'dust'.
If you have more than one ram memory module, do the above procedure for all of them.
With having just one ram memory module, reinstall it back into ram memory Slot 1.
(DIMM 1 may be stamped on the motherboard next to ram Slot 1.
Slot 1 is the ram slot that is closest to the Processor, that is sitting at an angle on your motherboard)
If you just have one ram memory module, place it in Slot 1.
If you have more than one ram memory module, pick one, and install it in ram Slot 1.
Do not close the computer case at this time. Plug the computer back into power. WAIT 1 minute, turn the computer on.
Still No?
If you have more than one ram memory module, use it in Slot 1. Test again.
If the second ram module you try works, then the first ram module is bad.
If you have just one ram memory module, and this test resulted in the computer not working, the diagnoses is that you have a bad ram memory module.
Same thing if both ram modules do not work, if you have more than one ram memory module.
I think it is the Power Supply is bad, due to the fact that the computer, 'Fell to it's knees', when you tried to turn it on the second time.
Bad voltage power rail. Not enough power from the power supply to turn the Processor on, and keep it running.
Computer power supply's power is rated in Watts. (Wattage)
Voltage times Amp's = Watts
1) ALL the lights use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor uses 55 to 125 Watts of power.
When you press the Power On button, 5 Volts of standby power is redirected to the Power Supply.
This turns the Power Supply on.
The first chip to receive power is the BIOS chip.
The BIOS program burned into that chip, looks to see what devices are connected, does a Ram Memory count, turns the Processor on, and hands the computer over to the Operating System.
(Windows XP is an example of an O/S)
I believe you do not have enough power to turn the Processor on.
There is a way to test the power supply with a power supply tester, (About $15)
Or a known, good, and compatible power supply, can be used for a test.
(One more thing to Note*
For a time period Dell built their computers as a Proprietary computer design.
This means they wanted THEIR computer parts, installed in THEIR computers.
The main proprietary item at that time was the Power Supply.
This is in reference to the 24-pin ATX main power cable connector, and the wire placement in that connector.
Close up examples of a 24-pin main power cable connector, (In your Dell computer this connector has P1 stamped on the side),
Look, at your 24-pin ATX main power cable connector on your Dell power supply, and observe the color code of the wires.
Use the lock tab on the side of the connector, to orient where the wires are placed.
Now look at the 24-pin ATX main power cable connector for the power supply you are wishing to use.
The color code of the wires MUST be in the same.
Posted on Feb 17, 2010
Testimonial: "Thanks for this, it was the memory modules. Took them out and cleaned as suggested and computer rebooted and is all working great. Thanks again."
Pionner avh-x2550bt wiering diagram
Yellow=memory or constant power
Blue/blue w/white=Amp remote
Speakers are white/white w/stripe= front left
grey/grey w/stripe =front right
purple/purple w/stripe rear left
Green/green w/stripe rear right
If its a dvd player one wire will be for brake "ground" (have to be in park in order to watch movie unless bypassed)
Jul 11, 2016 | Car Audio & Video
I shut off my car and turn it back on i need to setup the radio and my settings again it doesnt save ! im missing the orange wire for illumination but my deck still illuminates its the memory thats doesnt...
Make sure the yellow wire is going to a source that still has 12v when the key is turned off. The yellow wire controls the memory and needs to be connected to a constant power source.
Sep 08, 2011 | Pioneer DEH-3400 CD Player
Pioneer KEH-8031ZT connection diagram of power and speakers
There are two kinds of pioneer color codes:
pre 1999
P o w e r Memory (+12v Constant) Orange Ignition (+12v Switched) Red Ground (-) Black Illumination Yellow Phone Mute Yellow/Black Power Antenna Blue S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) Green Left Front (-) Green/Black Right Rear (+) Gray/Red Right Rear (-) Black/Gray Left Rear (+) Green/Red Left Rear (-) Black/Green
and 2000 or newer
Memory / Constant 12V(+) Yellow Switch / Accessory Red Ground Black Illumination Orange/White Antenna Remote Blue Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black headunitwh.gif
Jul 01, 2011 | Car Audio & Video
I have a avh-4900dvd that I was trying to install in my 04 silverado and it will not power up at all I know the fuse is good in the vehicle because the factory radio works fine and I only connected the Red...
there should be a yellow wire that is used for 12 volt power. the red is usually just switched power. I hope you are using a harness from metra or scosche for this install as cutting into a factory harness is not a good idea
Oct 04, 2010 | Pioneer AVH-P4900 Car Video Player
Colour codes for 83 corona, wiring stereo the colours are grey/black grey/red Brown Purple/green Grey Blue/yellow blue white/black any help would be great thanks!
Hello! I'm having a hard time reading your colors...So, I'll give you the 1983 Corona wiring...
Constant +12= Blue/Yellow Switched +12= Gray
Ground= Brown Antenna= Black/Red
Illumination= Green
FR+ Light Green
FR- Blue
FL+ Pink
FL- Purple
RR+ Red
RR- White
RL+ Black
RL- Yellow
May 30, 2010 | Pioneer AVH-P5700DVD Car DVD Player
I'm installing a pioneer deh- 2750mp cd player into a '92 Ford Laser, and was wondering how the wire colours match up?
Hello! Ford wiring
Constant +12volts Green/Yellow
Switched +12volts Yellow/Black
Ground Red
Power antenna Blue
Illumination Blue/Red
Front Right + White/Green
Front Right - Green/Orange
Front Left + Orange/Green
Front Left - Light Blue
Rear Right + Pink/Blue
Rear Right - Green/Orange
Rear Left + Pink/Green
Rear Left - Pink/Blue
Jan 22, 2010 | Pioneer DEH-2700 CD Player
The wires are backwards. Are you using an adapter or did you straight wire it?
The yellow wires is memory, the red wire is for power when the ignition is on.
Jul 05, 2009 | Pioneer AVIC-D3 Car DVD Player
Red wire missing
the power wire goes above a blue wire or next to (white/orange) and (green) in top row if there is a space there
yellow should be above black
(white/orange) should be above (blue/yellow) i think
than red over blue
hope this helps
Jan 11, 2009 | Pioneer AVH-P6400CD Car DVD Player
I need a wiring diagram for a Pioneer GM-A200 Amplifier
For a Pioneer GM-A200, pls use below wiring scheme:
  • Green & Green/Black - Left Speaker;
  • Gray & Gray/Black - Right Speaker;
  • Yellow - Illumination B+12;
  • Red - ACC B+12;
  • Orange - Always ON B+12;
  • Black - Ground/Chassis.
For the 8P INPUT DIN connector:
  • 1 - SWD +B;
  • 2 - Left Input
  • 3 - Audio Ground
  • 4 - Mute
  • 5 - Right Input
  • 6 - UN SWD +B
  • 7 - Illumination B+12
  • 8 - NC
  • Body - Ground
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 23, 2008 | Car Audio & Video
Car Audio & Video Logo
23 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
