Help!!!how do i open the door of a KENWOOD MINI 900 washing machine? We are in a house rental and the washing machine door will not open. It is new I think. The owner is Swiss and we are in italy.
We cannot open the door. To be clear, we have never opened the door. This is the first time we are trying to use it. We cannot find the manual.
SOURCE: Door Wont Open
Your washing machine is fucked, and your clothes probably have more chance of fitting your cat than they do you. is your washing machine french...?
Posted on Jan 02, 2008
SOURCE: Door won't open on Samsung washer
This has happened to me twice. Both times I found the drain pump seized up with
1st time) The right rim from a pair of reading glasses
2nd time) A plastic toothpick
Both times the object was in the discharge port of the pump. You can see this by lifting the check valve with the pump removed. Removing the pump is simple. Unplug the washer. You have to remove the drain line from where its attached to the rear of the machine (one screw) to remove the rear access panel which slides into upper and lower slots. You will see the pump with an inlet and discharge line attached. The lines have simple squeeze clamps. When you remove the lines, you will drain the wash basin so have towels and a squeegie handy. Remove both lines and wait until the basin drains. When it stops draining remove the pumps electrical connector by squeezing the release catch on it while pulling it. The connector can only go on one way. Remove the 3 hold-down bolts on the pump baseplate. Remove the pump and lift open the discharge check valve and you'll find something there I guarantee it. Remove with needle nose pliers and re-assemble in reverse order.
This is actually a good design because the computer protects the pump by sensing a higher than normal current draw when foreign debris gets jammed in it. It will trigger the ND (No Drain) code and sometimes lock the door. Always check this first before you call the expensive repair man. If its not a jammed pump it will most likely be the control panel/processor. Good luck and always clean out pockets before loading the washer to prevent this,
Posted on Feb 14, 2009
SOURCE: Baumatic BTWM6 washing machine flashing F02 error
hi, you need to empty the filter, ours does the same all too often. The filter is located bottom right of the machine at floor level, which is rather daft for an integrated applicance; we have to remove a whole length of plinth to empty ours. Be warned, a lot of gunge and water will come out so have towels at the ready, especially if you have a laminated floor. Turn the white slot with a a 10p piece......and empty. Not the most pleasant of jobs, but effective. Good luck!
Posted on Mar 18, 2009
  • 24 Answers
SOURCE: Washing Machine Door is jammed (Indesit WD12x): I
UNPLUG IT
Posted on Oct 13, 2009
SOURCE: LG Tromm Front door won't unlock
I have this exact problem!!! Did anyone ever figure it out??!! HELP!!
Posted on Jul 19, 2010
Now whether this questions category that this question is in is the right category or not but my kenwood k30css14 when I close the door after opening the door during the cycle it Dosen't continue
These new ones don't like to be interrupted! have you tried restarting cycle, if so try restarting cycle, with cycle in the on position, turn timer from beginning to end till clicks open door, close, restart cycle. hope this helps. Try unplugging re plug with timer in off position, end cycle first !
Nov 03, 2016 | Washing Machines
I have a Roper fridge, small in a rental house. Water to the house was turned off. Cleaned, put all back together, the door won't close. Looks like the inside is bulging out. Help
door seals or plastic interior warped ?
check all the racks and draws are back in place
if vacating the rental
leave doors as is .. has to dry a
a closed door the fridge may mould
or gaffer /clear tape doors as closed as you can
Oct 22, 2016 | Roper Refrigerators
Zanussi aquacycle 900
You will probably find that the power fluctuation has blown the controller, the door will not open until it's replaced. You can drain out the water by tilting the machine back &remove the pump, please make sure the unit is unplugged befor attempting any work on these machines, They Will Kill You.
Nov 21, 2013 | Washing Machines
The washing machine does start and doesn't open
Sometimes during moving the unit it will twist slightly or jam the lock try moving it around a bit or lift the door slightly , once you get it open clean around the lock
Sep 10, 2013 | Kenwood Washing Machine Mini 1150 rapid
Cabrio washer door won't open!
if you plug it back in.... set at any cycle it should release then unplug asap. the aggitor/drum belt is what you are smelling.
Feb 14, 2018 | Whirlpool WTW5700XW Cabrio HE Washer
EUROLEC Model WM002 Washing Machine How do I open the door after it completes a wash?
im hoping you solved the mystery and would be kind enough to tell me ,how the door opens , moved into a new house with that machine insitu, i cannot get the door open have wet washing inside since yesterday, i would appreciate if you would let me know the secret.
Dec 30, 2010 | Washing Machines
I got a kenmore with my rental Apartment. Can't find the place to empty Lint. Where is it?
When you open the dryer door, the lint screen should be on the bottom of the door opening, above the control panel.
Nov 28, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenwood elite washer is spurting water 3 to 4 times during the agitate cycle. i do not know how to take it apart. it does not leak water at any other time.
The smell in my Kenwood Elite washer is horrible. I use bleach, I use the new TIde Washing Machine Cleaner, I have tried the hot cycles, I have left it open between washings but can't leave it open very much because we have a door out to garage that would hit the washer door if left open too wide. I can't leave clothes in there too long or they smell too much and have to rewash. The clothes never come out of washer smelling super clean. After I dry them using a scented dryer sheet, they are acceptable, but I never have really clean smelling scented clothes any more.
Apr 26, 2009 | Kenmore Washing Machines
Washing Machines Logo
Top Washing Machines Experts
