Question about The Computers & Internet
I have a Fanuc OTC control and frequently am getting a 998 Rom Parity Error. Not sure what the problem is.
Fanuc 6m wiringdiagragm manual
i have beaver vc15 with fanuc 6m . when switched on to main breaker it is worked . but when control power on then it is tripping
control is not on.
Aug 24, 2013 | 1986 Toyota Cressida
A 1xx POST error code indicates a problem with the ??
It indicates a problem with the system boards. For more info, start here.
Oct 30, 2012 | HP Computers & Internet
We have a parity error on our ThinkCentre S51 Desktop. What is this and how do we rectify this issue?
A RAM parity error? Just tell it (in the BIOS settings) that you don't have memory with parity installed, or replace the memory with that kind. You probably had to replace the BIOS battery and the setting defaulted to DDR with parity bits somehow.
There's serial communications parity too...mostly deprecated by USB, but it can come up in connecting POS (point of sale) printers, etc.
If the error instead arises in another context; well, you'd need to search for some enlightenment relating to that and 'parity' to get some enlightenment on the subject.
Jul 09, 2011 | IBM ThinkCentre S51 Intel Desktop PC -...
We have an IBM ThinkCentre S51 Desktop PC and the computer froze up with a parity error. We restarted it and we would like to know if that will solve the problem for the future.
Parity error pops up when the memory encounters a read error. It may be a one time glitch or a sign of memory failure to come.
'Parity' is a form of error detection that uses a single bit to represent the odd or even quantities of '1's and '0's in the data. Parity usually consists of one parity bit for each eight bits of data.
On most systems, a parity error detection results in the computer system freezing entirely and the displaying of a 'Parity Error' message on the screen. The system must then be restarted.
I would run a memory diagnostic to see if your memory (RAM) is stable.
Download Windows Memory Diagnostics tool,copy it to a CD and run it. There is a User guide to instruct you how to do this.
http://oca.microsoft.com/en/windiag.asp
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
We need a used manual for a Whedco Drive # SMD-3041-1-A to complete a repair.
no luck finding a manual online. you will need to call them.
Corporate Headquarters
1800 Lakewood Blvd.
Hoffman Estates,IL 60192
binarywriterservlet?imguid=343dc937-2e42-42d4-9e68-0a04ae5ea95a&ubasvariant=33333333-3333-3333-3333-333333333333 1-847-898-5000
binarywriterservlet?imguid=e5d59637-68bc-46df-99b5-0805a6c8116f&ubasvariant=33333333-3333-3333-3333-333333333333 1-847-898-5001
Department binarywriterservlet?imguid=343dc937-2e42-42d4-9e68-0a04ae5ea95a&ubasvariant=33333333-3333-3333-3333-333333333333 Phone binarywriterservlet?imguid=e5d59637-68bc-46df-99b5-0805a6c8116f&ubasvariant=33333333-3333-3333-3333-333333333333 Fax E-mail Part Sales 1-888-FANUC US (select-1) 1-847-898-5021 binarywriterservlet?size=2&imguid=8ff70218-92bc-02f4-33d2-58cc02986030&ubasvariant=33333333-3333-3333-3333-333333333333 Service 1-888-FANUC US (select-2) 1-847-898-5011 binarywriterservlet?size=2&imguid=8ff70218-92bc-02f4-33d2-58cc02986030&ubasvariant=33333333-3333-3333-3333-333333333333 Repair 1-888-FANUC US (select-3) 1-847-898-5590 binarywriterservlet?size=2&imguid=8ff70218-92bc-02f4-33d2-58cc02986030&ubasvariant=33333333-3333-3333-3333-333333333333 Training 1-888-FANUC US (select-4) 1-847-898-5319 binarywriterservlet?size=2&imguid=8ff70218-92bc-02f4-33d2-58cc02986030&ubasvariant=33333333-3333-3333-3333-333333333333 Option and CNC System Sales 1-888-FANUC US (select-5) Option Sales (select-1) 1-847-898-5006 binarywriterservlet?size=2&imguid=8ff70218-92bc-02f4-33d2-58cc02986030&ubasvariant=33333333-3333-3333-3333-333333333333 CNC System Sales (select-2) 1-847-898-5691 binarywriterservlet?size=2&imguid=8ff70218-92bc-02f4-33d2-58cc02986030&ubasvariant=33333333-3333-3333-3333-333333333333 Accounting 1-888-FANUC US (select-6) 1-847-898-5016 binarywriterservlet?size=2&imguid=8ff70218-92bc-02f4-33d2-58cc02986030&ubasvariant=33333333-3333-3333-3333-333333333333 Service Contracts 1-888-FANUC US (select-7) 1-847-898-5031 binarywriterservlet?size=2&imguid=8ff70218-92bc-02f4-33d2-58cc02986030&ubasvariant=33333333-3333-3333-3333-333333333333If you have technical, service or parts related questions, or request requiring immediate attention, please contact us directly at our toll-free number 1-888-FANUC US (1-888-326-8287).
Good luck
Please rate FIXYA
Apr 07, 2011 | Computers & Internet
Getting the following error repeatedly: A parity error was detected on \Device\RaidPort1. Source: adpu320 Event ID: 5 Any help would be greatly appreciated...
Any "Parity Error" is from a communication error on the SCSI bus, and it's bad! Errors are a way of life, and the SCSI transceiver has failsafes to fight them, and one of these is parity. Consider it extra data that the controller sends when you transfer data to your hard disks. Once there, the drives transceiver does a simple ccheck and verifies that the parity is correct. If not, a Parity Error is generated.
99% of the problems surround the SCSI bus itself in the form of a damaged SCSI cable, loose terminator, or a bent pin on a SCSI connector (latter being most common). This error is more apparent after moving the SCSI devices, resulting in unplugging and then replugging the cables back onto the Targets (HDD, CD/DVD ROM, printer, etc.) or back onto the Host Bus Adapter (HBA - the 29320 in your case). Check ALL pins. You can try to straighten the pins, otherwise it's time to replace the cable. REMEMBER that terminators are a must and can also cause Parity Errors if there is no termination present on one end of the bus or the other.
This coming from an ex-Adaptec employee and support person! :)
Best of luck
Mar 02, 2011 | Adaptec 29320 SCSI Controller
I need fanuc ot cnc parameter discription for 900 to 940
The parameters 900 to 940 are different for each type of machine. You need to specify the control
Mar 30, 2010 | Computers & Internet
E7-00
E7 00 Content ICU communication trouble (ICU
detection)
Detail Communication setup error,
framing/parity/protocol error
Cause Slave unit PWB connector improper
connection
Slave unit PWB – ICU PWB harness
trouble
Connector pin breakage of the motor
PWB of the slave unit PWB
Slave unit ROM trouble. no ROM, ROM
reverse insertion, ROM pin breakage
May 01, 2009 | Sharp AR-507 Copier
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
Computers & Internet Logo
16 people viewed this question
Top The Computers & Internet Experts
Ed Watson
Level 1 Expert
Alex Krenvalk
Alex Krenvalk
mukhtar21 shaikh
mukhtar21 shaikh
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
