Question about The Computers & Internet
How do I erase the memory stored in the monitor
    New Friend:
  • 41 Answers
If you want to erase all the data on it completely, you need to try professional utility tool to do that. Aomei Partition Assistant provides the wipe memory data, and you can check the detailed tutorial here. Wipe Data
Posted on May 26, 2017
  • The Master
  • 3,368 Answers
Format it! Overwrite it! then Format it again!
Posted on May 17, 2017
I have a problem to erase memory card in my phone, how do I fix the problem and erase the card,please?
Is it an android with a removable memory chip? In which case take it out and reformat it. You will need a card reader with a USB hook up for your computer. Or if it is an iphone go to the app store and find a file to download that is much larger than the memory capacity of the phone. The phone will erase everything non vital trying to down load the file. This is what the apple store does to wipe all the search history files off the phones.
Sep 27, 2017 | Cell Phones
How can I erase the memory of an unidentified BPM?
press M and hold it down for 5 to 10 seconds
Dec 14, 2015 | Health & Beauty
Who can repair a Gateway DC-T50
Refer to the manual page below - note the last 2 items
If you take the camera and the card to a sales outlet the assistants are usually helpful
Inserting an SD Memory Card(Optional)
All images and video clips taken by the camera can be stored in an SD (Secure
Digital) Memory Card. Even if the camera's power is OFF, the images saved in the
SD Memory Card are not erased. An SD Memory Card can be repeatedly read and
written. You may also expand the memory capacity up to 512MB so that you can
store additional images and video clips.
1. Make sure the camera is off.
2. Slide the battery/SD Memory Card cover in the direction of the [OPEN] arrow.
3. Insert an SD Memory Card :
The front side of the memory card (printed
arrow) should face towards the front side
of the camera.
If the card cannot be inserted, check the
4. Close the battery/SD Memory Card cover.
To remove the SD Memory Card, make sure
the camera is off. Open the battery/SD Memory Card card cover. Press
lightly on the edge of the memory card and it will eject.
If the camera is powered-on without the card, the "NO CARD" message appears on
the LCD monitor.
To prevent valuable data from being accidentally
erased from an SD Memory Card you can slide the
write-protected tab (on the side of the SD Memory
Card) to "LOCK".
To save, edit or erase data on an SD Memory Card,
you must unlock the card.
MultiMedia Card (MMC) can not be used.
You need to format an SD Memory Card before using it in this camera
Feb 19, 2015 | Gateway DC-T50 Digital Camera
This Greg thanks . how do I clear the code?
Clearing Codes
Stored faults should only be cleared by use of the DRB-II or similar scan tool. Disconnecting the battery will clear codes but is not recommended as doing so will also clear all other memories on the vehicle and may affect driveability. Unplugging the PCM connector will also clear codes, but on newer models it may store a power loss code and will affect driveability until the vehicle is driven and the PCM can relearn its driveability memory.
The -ERASE- screen will appear when ATM is pressed at the end of the stored faults. Select the desired action from ERASE or DON'T ERASE. If ERASE is chosen, the display asks ARE YOU SURE- Pressing ENTER erases stored faults and displays the message FAULTS ERASED. After the faults are erased, press ATM to return the FUEL/IGN MENU.
Sep 29, 2013 | 1993 Jeep Grand Cherokee
When i switch on the computer, the only thing that appears on the screen is "power save mode on". i have checked all the cables, i changed monitors, but no solution for the moment thanks for...
Im assuming the monitor worked OK until now. The two things I can think of is, First is the cable from the monitor to the computer is either not connected tight either on the monitor side or the computer. The second thing I can think of is a bad video card. I think the monitor is ok because your getting the power save mode on the screen.
I hope this helps you out, if it does please leave me some positive feedback.
Apr 04, 2011 | LG Flatron L1710S 17" LCD Monitor
How do I erase the memory on a Workio 1820?
go to the menu of the machine, check memory option, then, you will see the option to erase or store memory. select erase or remove memory.
Feb 04, 2011 | Panasonic Workio DP-1820E Copier
I would like to clear out the stored readings.
Press the User-Select button. User 1 or User 2.
Press and old the small button that looks like it has a clock impression on it and the + button at the same time while in the Memory Recall Mode and the data for the selected user will be erased automatically.
Jan 31, 2011 | Homedics BPW 200 Automatic Wrist Blood...
How to erase info stored on the monitor and how to change date and store new info again it is a used monitor can i go on line to print guide on how to use it.
I also do not have a manual, but probed around on my unit until I found something that worked. I'm not sure it is the best solution because you need to erase the stored readings one at a time. That means it will take a few minutes, but it does work and it's very simple: Push the Bank button to get the bank you want, M1 or M2. When a stored reading appears, hold down the Memory button for about five seconds and the reading will start to flash. Keep holding the Memory button and a series of dashes will appear on the screen. Release the memory button and press Start. The old reading will be erased and the next reading will appear. Keep doing this until you have erased as many readings as you want. Hope this helps. JD
Aug 24, 2010 | Mark Of Fitness DS 1902 Blood Pressure...
Computers & Internet Logo
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
