Question about AEG Dishwashers
I HAVE A AEG 4020 DISHWASHER. WATER IS NOT COMING INTO MACHINE. LOOKING FOR WATER VALVE . LOOKING FOR A SECOND HAND ONE. CANNOT CANNOT FIND NEW ONE.
  • 54 Answers
SOURCE: AEG 50760 Dishwasher shows Error Code 30
there is water in the base of the macine. lean it over to the side to get all of the water out then try again.
Posted on Feb 14, 2008
SOURCE: AEG 16810 UPGRADE WASHER DRYER E10 ERROR
This is worth posting in case anyone else has the problem. The mechanic was stumped and then around 3 days later a Zanussi gave the same problem - steam emitting from the drum. He changed the valve - the entire unit. Problem solved. Zanussi and AEG have identical internals. He changed our valve - problem solved.
Posted on Aug 03, 2008
  • 1462 Answers
SOURCE: AEG WASHING MACHINE
fit hoses at random. put on a rinse cycle. if cold water comes in then hoses are correct. if hot water comes in, then reverse hoses
Posted on Sep 07, 2008
  • 1462 Answers
SOURCE: Have an Aeg oko 4020
it probably has water in the bottom tray
take bottom front panel off and this exposes the bottom tray
mop out water and machine will run
if fault reoccure then you have a leak
Posted on Nov 29, 2008
SOURCE: AEG DISHWASHER, DOES NOT HEAT WATER.
I had this same problem on our AEG dishwasher. The reason was on the controller board. There is one relay switch which drives the heater element.One of the legs of that relay box was disconnecteds from the circuitboard. Check this out.
Posted on Dec 09, 2008
Problems disconnecting the wastepipe on an AEG Dishwasher
Pour some bleach into the stinky backwash. I know that this is not good for the environment but it will take the stench away while you get a new dishwasher. Sorry but you have plumbing problems out of my range.
Oct 25, 2012 | AEG 24 in. Favorit 80800 Free-standing...
Hi there, Do you have a part number for the drain AEG OKO FAVORIT 4020 hose. Thanks Neville
Hi ntalbany,
The Part Number is 8996461335607.
It can be found here:
http://www.apart4u.co.uk/dishwasher-drain-hose-aeg.html
Hope it helps :-)
If you found this solution helpfull, please rate my answer.
Apr 27, 2011 | Dishwashers
My dishwasher aeg favorit 50870 not use hot water(not do hot water)
If the water isn't getting hot, then either the water inlet valve that opens the hot water is faulty or the heating element that heats the machine may be bad.
Sep 29, 2010 | AEG Dishwashers
Keeps flooding: pump comes on when switched off.
This sounds like an inlet valve problem, Replace it. Often a dirt particle gets in the valve.
Nov 01, 2009 | AEG 18 in. Favorit 44630W Slim-Line...
AEG Favorit 60820 sensorlogic .30 code water problem
You can unclick the top part which gives better access to the lower part with the blockage. Hot water, pipe-cleaners, cable ties, bits of wire can all be employed to get the grease out.
Jun 06, 2009 | AEG 24 in. Favorit 60820W Free-standing...
Have an Aeg oko 4020 dishwasher. Installed a new pump and it worked for awhile. It now won't switch off but the cycles do not run. Someone suggested there maybe water in some area that has caused some sort...
Nov 29, 2008 | AEG Dishwashers
Aeg dishwasher favorit 665 i
TWO THINGS YOU NEED TO CHECK.IS THE PIPE FROM THE TAP TO THE MACHINE NOT JAMMED.ALSO YOU NEED TO CHECK THE FILTER THAT IS LOCATED WHERE THE PIPE FROM THE TAP SCREWS ON IF ITS NOT BLOCKED AND IS THE VALVE IT SELF IS NOT FAULTY.GOODLUCK.MOHAMED
Sep 18, 2008 | AEG Dishwashers
AEG WASHING MACHINE
Aug 22, 2008 | AEG Lavamat 72640 Front Load Washer
Have an AEG 8081i dishwasher. It is displaying "CE" in the timer screen with flashing indicator lights. What is it?
Aeg 8081iM "CE" fault..
Fixed it! :) wax valve looks like it got water in it, blew the controlling triac on the main board and fried a track on the board. Bought a new wax valve, installed it. Got a quote for a new board...too much($600Aud+ I'd buy a new one If I had to pay that)...Found a dead machine which had a blown transormer but good board, so played swapsies with the transformers on the main board. Fixed the source of the leak, switched it on and started washing the dishes! :) Now have a $30 spare parts machine for the experience! :)
Jun 09, 2008 | AEG Dishwashers
Dishwashers Logo
22 people viewed this question
Top AEG Dishwashers Experts
paulcarew
Mike
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
