Question about Hilti Drills
Hilti gx120 works fine then stops. Sometimes 10 shots, sometimes only a couple.
  • 104 Answers
SOURCE: 2004 stratus 2.7L Erratic idle, sometimes dies, sometimes revs at stops
hey-I have has this before different car but same - idle control valve is failing - computer at shop will pick this up on diagnostic
Posted on Oct 12, 2008
freetek
  • 5568 Answers
SOURCE: driver side electric window
This sounds like an over-current circuit that is tripping.  If there is too much mechanical resistance, this circuit (if used) would interrupt the voltage supply to the motor to prevent overheating if the switch is held after the pane has reached either its upper or lower limit. Listen carefully to the motor while raising or lowering the window to ascertain if it sounds like a groan at some points along the travel. The window may be getting too much drag from gaskets or the elevation mechanics (possibly from rust or dry pivots) that is causing the motor to draw too much current and tripping the over-current protection.
Posted on May 25, 2009
emissionwiz
  • 79865 Answers
SOURCE: 2005 Mustang speedometer sometimes zeroes itself
ok got it. I have seen this problem at the ford dealer, here is what we have found, the needle is driven by a tiny electric motor called a "stepper motor" a stepper motor can go to and hold any position, such as when u are going a constant speed, this ittle motor sticks, they sell no parts for this speedo buy it can be repaired by a authorized factory repair center.
Posted on Nov 05, 2009
  • 508 Answers
SOURCE: UNIT WILL SHUT ITSELF OFF WHEN IN USE SOMETIMES
I suspect that the power supply is not making a proper connection and comes loose in the socket, the gps unit then is forced to use battery power but since the battery is not fully charged yet when the battery power is to low the unit shuts down and will stay down till enough of a charge or the power supply gets bumped and makes a solid connection again.
Posted on Jun 12, 2010
  • 347 Answers
SOURCE: Scooter speeds up or stops, sometimes won't take
Hi please rate me thumbs up 1 to 4 as you feel i have helped,i help as i care not for profit,im disabled myself.my opinion it could be a loose connection on batteries,the throttle pot [what the throttle is connected to] the speed control pot [what the speed volume connects to] if fitted.loose conections to any of them or worn or dirty motor carbon brushes,or carbon brush spring.i hope this has been of help.also you could try downloading the PDF File Troubleshooter on ur product with Adobe Reader.
Posted on Aug 02, 2010
Testimonial: "thank you"
How do i fix my hilti gx120 nailer
go -www.hilti.com.au and there is a live chat section
ask the technicians direct about the problem
Dec 23, 2016 | Cars & Trucks
Can C7-24 hilti charger that had been out in the rain be repaired
try putting it in a bucket covered with rice for a couple days...sometimes this will absorb any and all moisture in the device
Jun 16, 2016 | Hilti Drills
Why is my hilti gx120 nail gun nail gun reading gas as empty when it's full
AR you pushing down on the tip of the air gas tip. Are the gas cartridges old?
Nov 21, 2014 | Tools & Hardware - Others
HP Mini 10 my screen randomly starts jumping
The keyboard has a faulty connection to the mainboard. Have it checked in service please
Mar 23, 2013 | HP Mini 1000 Netbook
Brand new te-7c and hammer action is not working Please help
are you using the right SDS bits? second there is a selector on the side for heavy hammer, light hammer and drill only, make sure that you have the selector in the proper position and then you would need to apply slight pressure to the bit for the hammering action to start, if youhave done all these I would take it back for warranty replacement or repair. Hilti is very good about warrantys.
Aug 31, 2011 | Hilti TE 7C 120V Rotary Hammer Drill...
Service light
You can reset the light. What you need to do it remove the handle assembly from body of tool. The contacts will unplug. Then plug the cord in and pull the trigger and sometimes the light will blink, while holding the trigger in the on position unplug the cord. reinstall the handle and the light should go out. Sometimes you have to pull the trigger while plugging cord in but this should work. and then while holding unplug cord.
Sep 21, 2009 | Hilti Drills
Brand new but wont work.
check the contacts that they align properly, they change them from time to time and clean contacts with pencil eraser sometimes their is a film that stops proper contact of electrodes
Mar 30, 2009 | Saws
2002 Sebring -Odometer Lights Flicker then bing battery indicator
have the engine wire harness checked maybe a communication problem between modules.
Mar 27, 2009 | 2002 Chrysler Sebring
Drills Logo
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
