Question about Miscellaneous
Home choice balance
237996662
My balance from my home choice account
check with Home Choice not fixya
Nov 02, 2016 | Computers & Internet
How/where do I find my voice, text, data, airtime TRACFONE available time still available?
How do I check my minutes on my Tracfone?
    Look at the home screen of your TracFone device, your Airtime Balance Display is shown directly on the home screen of your cell phone. Navigate from any menu or application directly back to the home screen to see your updated balance. View the balance by going to "Menu." Click on "Prepaid" followed by "Airtime Info."
    Additionally, you can enter the following URL to check your balance: "https://www.tracfone.com/direct/CheckBalance?input_phone=1234567890" (replace 1234567890 with your phone number). You will get a text with your balance.
    And finally, some users are reporting the easiest way is to call *777*1# to get your airtime.
TracfoneReviewer How to Check your Tracfone Airtime Balance on Android...
Jan 08, 2016 | ZTE Cell Phones
How many minutes do I have left?
From Your TracFone Step 1 Look at the home screen of your TracFone device, your Airtime Balance Display is shown directly on the home screen of your cell phone. Navigate from any menu or application directly back to the home screen to see your updated balance.
Step 2 View the balance by going to "Menu." Click on "Prepaid" followed by "Airtime Info." This menu will also show your current airtime balance and expiration date.
Related Reading: How to Check Your Prepaid Balance for T-Mobile
Step 3 Add additional airtime to your account by calling 1-800-867-7183, refilling the minutes online or by visiting a participating retailer (see Resources). Enter the PIN number on the back of your refill card to add additional minutes to your account.
From Your Computer Step 1 Check your minute balance by logging in to your account on the TracFone website. Once you are on the homepage, click on "My Account." You'll be prompted to enter your username and password. If you don't currently have a TracFone account, you can register your phone number by clicking on "Register."
Step 2 Find the minute balance of your account displayed in the middle of the "My Account" homepage.
Step 3 View the account expiration date on the "My Account" homepage (see Resources). Your balance expiration date varies depending on the amount of the airtime refill card.
Oct 14, 2015 | Samsung Galaxy Centura Smartphone -...
I cannot get into my Balance app by Connor Wakamo. I was changing my password, entered old password & accidentally hit "Done" before I put in new one. Now locked out. Any solutions for this?
If you are absolutely sure that you didn't enter anything at all into the new password box then your new password is also nothing. When you log in just press her enter key from within the login box. Then you can reset the password again to your own choice.
May 28, 2015 | Balance Computers & Internet
I did a balance board check and the bottom left and the top right sensor are not working. What do I do
Unfortunately, the balance boards are prone to failure. Your choices are to contact Nintendo about repairs (they tend to charge a small fortune) or buy a new one. Repairing this yourself would be difficult because the parts are not easy to get a hold of unless you are a repair shop.
Mar 21, 2011 | Nintendo Wii Fit for Wii
Universal joint removal
The easiest, is to remove the drive shaft
and take to a specialty shop that does drive
shaft work,balancing etc
Next choice is to take down the street to a
local garage and have them replace joints,
assuming they won't use a hammer,and have
the correct tools
You could carefully use a socket,your bench vice
and a hammer and a brass punch
Either way, I personnally balance all drive shafts,
flywheels,clutch assy's etc
Dec 19, 2010 | 2001 GMC Jimmy
I just had my timing belt changed and now the car is vibrating in park, reverse and neutral.
I have been dealing with the same issue in my 05 kia optima for over a year with the vibration getting worse as time went on. I found excessive carbon buildup on the counter balancer shaft which put the shaft out of balance. The vibration started out very light in the beginning and continued to get worse as time past to the point that the steering wheel would shake in any gear that the car was in. We found this solution almost by accident by turning the balancer shaft by hand an felt a very slight roughness while turning it. That is when I made the choice to pull the shaft out an we send a very visible problem.
Nov 17, 2010 | 2005 Kia Optima
Are they the same - windows vista 32 bit platform edition and windows vista home basic 32 bit sp1
Yes and no. Think of 'platform' as a general header when looking at operating architectures (there are different types) and Vista choices.
Vista choices under the 'platform' 32-bit are:
• Windows Vista Home Basic 32-bit
• Windows Vista Home Premium 32-bit
• Windows Vista Ultimate 32-bit
• Windows Vista Business 32-bit
• Windows Vista Enterprise 32-bit
Another example of the "64-bit platform" and Vista choices are:
• Windows Vista Home Basic 64-bit Edition
• Windows Vista Home Premium 64-bit Edition
• Windows Vista Ultimate 64-bit Edition
• Windows Vista Business 64-bit Edition
• Windows Vista Enterprise 64-bit Edition
Mar 05, 2009 | Dell Computers & Internet
Fan "wiggling"
It's out of balance. They make balancing kits you can get where they sell fans. Just like when a tire get's out of balance you have to add some weight to the right spot on one of the blades. It's a time consuming process fiquring out where to add the weight. but it works.
Good luck
Jul 09, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Miscellaneous Logo
18 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
