Question about In Office Equipment & Supplies
How to clear a paper jam in inkjet printer?
I am using inkjet printer and from some day I am facing paper jam problem can anyone tell me how can I come up from this problem????
  • In Master
  • 3,368 Answers
After clearing the jam (instructions in manual) remove the paper and turn front to back and put back in. There is a weave to the paper and it can effect the paper handling of the printer.
Posted on May 17, 2017
Resetting a canon pixma ip5000 paper jam. wont clear
Need to get over the issue that you have been facing? Fed up of paper jam in your Canon Printer? Don't get frustrated. Just consult certified technicians of Canon Printer Support team by dialing toll free number 1-800-243-0019 and get your issue resolved in a short period of time and start using your printer error free.
Sep 03, 2017 | Canon PIXMA iP5000 InkJet Photo Printer
HP Officejet 6500 Wireless one day i come home and when i turn on my printer i get a mssg that there is a paper jam so i look and chek that everything is clear so its a flase paper jam then i resart it and...
You may have to get the printhead replaced but first:-
Was the paper jam cleared?[disconnect everything even your PC and re-connect to start afresh]
Clean the printhead by:-
  • Load a plain A4 size paper into paper tray.
  • On the printers control panel,press the setup button.
  • Select tools nad then press OK.
  • Select 'clean printhead and then press OK.
  • After the printhead cleaning,turn the printer off and then on.
Hope this helps.Thanks!
Oct 13, 2011 | HP Officejet 6500 Wireless All-in-One...
How to open drum to remove the jammed paper inside
Hi Good day!! here are the steps how to remove paper jam in brother hope it help's you!!
1. Pull the paper tray completely out of the printer.
2. Pull the jammed paper up and out of the printer.
3. Press the cover release button and then open the front cover.
4. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
5. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared.
6. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
7. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
8. Pull the Duplex Tray completely out of the printer.
9. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
10. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
11. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
12. Put the drum unit assembly back in the printer.
13. Put the paper tray in the printer.
14. Close the front cover.
Oct 19, 2010 | Brother MFC-7440N Laser Printer
My photosmart 2575 jams everytime paper is loaded. I've cleared the jam, and made sure there is no paper stuck, but it loads 1/2 a new sheet then stops and says there is a paper jam. Anyone know how to fix...
it might be the problem with the rollers which is trying to garba teh paper ... try to clean the rollers at the back of the printer with a dry cloth ... if still you face problem its better to get the printer exchanged with an upgrade model by calling 1-800-HPINVENT
Apr 30, 2010 | HP Photosmart 2575 All-In-One InkJet...
Paper jam in Lexmark printer
First turn the printer off then back on:
1 Make sure:
• You use paper designed for inkjet printers.
• If you are using photo, glossy, or heavyweight matte paper, you load it with the glossy or printable side facing
you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
• The paper is not used or damaged.
• If you are using specialty paper, you follow the instructions that came with it.
• You do not force paper into the printer.
2 Before loading paper, slide the paper guides out toward the edges of the paper support.
3 Load the paper vertically in the center of the paper support, and adjust the paper guides to rest against the edges
of the paper.
Note: To avoid paper jams, make sure the paper does not buckle when you adjust the paper guides.
Apr 12, 2009 | Lexmark X4650 InkJet Printer
"Paper Jam"
Your printer is still trying to print whatever preceded the paper jam. Go to Settings/Printers/your printer/ and clear all documents in the printer que. You will also have to shut down the printer and restart the computer after this to be sure.
Aug 04, 2008 | Dell 962 Photo All-In-One InkJet Printer
Clear paper jam
does the printer have a cancel botton if it does push it
Feb 14, 2008 | Lexmark X5150 All-In-One InkJet Printer
Printer jams
i suggest that you replace the feed rollers, cleaning them automatically tells you that they are worn.They should be tacky to pick up the paper, not matter what type.
Apr 13, 2007 | HP LaserJet 8150n Printer
22 people viewed this question
Top In Office Equipment & Supplies Experts
Level 1 Expert
Tygh Duval
Tygh Duval
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
