Question about The Audio Players & Recorders
How do you charge the battery of a Telefunken TCR-017BT clock radio
    Top Expert:
  • The Master
  • 80,637 Answers
It charges all the time when the clock is plugged in.
Posted on May 18, 2017
Testimonial: "Thank you for your reply. Wish it had something to plug in. It comes with a USB cable for charging a cellphone but nothing to connect to mains supply. Unfortunately the package does not list contents - maybe I am missing a part."
What are possible causes of P1768 code on a 2001 Chrysler PT Cruiser?
Do the easiest things first:
Check the battery earth lead (bear in mind that if you disconnect the batter you will probably have to re-enter the radio code). Check where it connects to the body/engine block - make sure it is clean and secure.
Then check every other earth lead you can find
Feb 24, 2016 | 2001 Chrysler PT Cruiser
How do i change battery on zack savio?
there should be a small door on the back you open to replace battery
Feb 10, 2015 | iHome Kitchen Timer & Alarm Clock Radio...
The low battery light remains on after I changed the battery,
Hello
There are two possibilities for this fault. The first one is with its battery itself. If the battery did not hold current, in otherwords, it has weak, proper charge both in volts and amperes won't hold on it, and when the device draw current from it while it works, voltage drop will occur, and low voltage indication will be displayed.
The second chance is due to the charger circuit inside the radio. If charger circuit do not give proper voltage and current to battery, the battery won't charge to its full capacity.
Check it by replacing it with a new battery [batteries] first. If it helps you it's OK. If not, your radio need service, and its charger circuit must be checked well. OK.
Nov 15, 2011 | Emerson CKS2237 Clock Radio
When I shut the radio off the clock and radio memory goes to How do I set the clock and stations so that when I tur it on I have the clock and stations.
Have you inserted 2 x AA batteries in the back where you charge the Dewalt batteries? there is a cover with a black phillips screw, this is where the AA batteries go for the memory clock & radio presets.
Nov 28, 2009 | Dewalt DC011 AM/FM Radio
Hi . My clock radio clock continuously displays
Likely a bad backup battery inside the clock, or a capacitor that is leaking a charge.
Nov 17, 2017 | Lenoxx Electronics CDR-190 Clock Radio
Clock not available
I took the truck back for warranty work and this was the dealer's explanation: This is a known, but rare, glitch in the radio. It is not widespread enough for Dodge to issue a bulletin, but there is a write-up in the computer system that Dodge technicians access that covers this. The "repair" is to disconnect the battery for 5 minutes and/or remove the IOD (Ignition Off Draw fuse(s)). The radio then "resets" itself. If the problem persists, they have to replace a component of the radio system.
Jan 06, 2009 | 2008 Dodge Durango
Backup battery not working
Check to make sure the battery connections are clean - free of rust/corrosion/gunk...and that the battery firmly "snaps" into it's connector/holder. BTW, if you have a user manual for the clock, I have the same model but lost my manual and can't figure out how to set the time... you can email my with instructions at donebythefish@gmail.com - I'd appreciate it!
Dec 11, 2007 | RCA RP3710 Clock Radio
50 people viewed this question
Top The Audio Players & Recorders Experts
bihug
bihug
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
