Question about Sharp Measuring Tools & Sensors
Set time zone on a sharp weather station spc775
SOURCE: Set the clock
You are in luck. I had to replace the batteries in my DWS-150 & couldn't find the instruction manual to reset the time. Fortunately, I remembered a while back I had the same situation & thought I might have downloaded the manual - while it was still available. Ifound I have it saved as a pdf file on my pc. Here are some excerpts: About the Atomic Clock The National Institute of Standard and Technology (NIST) in Fort Collins,
Colorado broadcasts the time signal (WWVB at 60kHz AM radio signal) with
an accuracy of 1 second per every 3,000 years. The signal will cover a
distance up to 2,000 miles from the source. Like a typical AM radio, your
Atomic Clock will not able to receive the WWVB signal in places
surrounded by heavy concrete or metal panels. The reception of the time
signal can be affected by mobile phones, TV, electrical appliances or other
electronic interference. To get the best performance of the Atomic clock,
please install the home receiver near a window and away from large metallic
objects. If the unit is not working properly, change the unit position. There
may be some interference at this location.
7
DWS-150-IB SP\ENG 10/12/04 11:30 AM Page 7
SETTING TIME
RADIO-CONTROLLED CLOCK
The home receiver will start synchronizing the clock after the 1st channel of
the RF thermometer is registered.
1. At normal mode, hold the “ - ” button located on the back of the home
receiver for 3 seconds to force synchronization.
2. The antenna icon will appear during the synchronization process (on the
right side of the time display).
3. If the icon disappears afterwards, radio time signal is not available at that
moment. Try setting the home receiver in other locations. Remember to
place the unit away from sources of interference such as mobile phones,
appliances, TV etc.
4. Antenna icon will appear on screen if the radio time reception is
successful. The radio-controlled clock will have a daily synchronization at 1:00 am everyday. If previous attempts of reception were
unsuccessful, the home receiver will attempt synchronization
each hour until successful.
5. Each reception cycle is minimum 2 minutes and maximum 10 minutes.
TIME ZONE SELECTION
Press “ - ” button on back of home receiver to select from the following time
zones in the U.S. (zone is displayed in the upper right hand corner of time
display).
P - Pacific Standard Time M - Mountain Standard Time
C - Central Standard Time E - Eastern Standard Time
MANUAL SETTING FOR CLOCK & CALENDAR
1. Hold “SET ” button for 3 seconds to enter clock set.
2. First, select 12 hour or 24 hour setting using the “ + , - ” buttons located
on the back of the home receiver. Press “ SET ” button to confirm.
3. Select Hour - Use the “ + , - ” buttons located on the back of the home
receiver to adjust hour setting. Press “ SET ” button to confirm.
4. Select Minute - Use the “ + , - ” buttons located on the back of the
home receiver to adjust minute setting. Press “ SET ” button to confirm.
5. DST On/Off (Daylight Savings Time) - Use the “ + , - ” buttons to turn
DST on or off. Press “ SET ” button to confirm.
Now you will select the calendar settings-
6. Select Year - Use the “ + , - ” buttons located on the back of the home
receiver to adjust year setting. Press “ SET ” button to confirm.
7. Select Month - Use the “ + , - ” buttons located on the back of the
home receiver to adjust month setting. Press “ SET ” button to confirm.
8. Select Day - Use the “ + , - ” buttons located on the back of the home
receiver to adjust day setting. Press “ SET ” button to confirm.
9. Select Fahrenheit/Centigrade Temperature Readings - Use the
+ , - “ buttons located on the back of the home receiver to toggle
between Fahrenheit or Centigrade readings. Press “ SET ” button
to confirm.
Posted on Apr 16, 2008
SOURCE: Setting the time zone
I have Auriol 48999 (Lidl)
Hold on 2 sec "Adjust" ,then press clock (about 5 times, until it offers -1, 0, -2 and so on), if you have found your right time zone, then press "adjust" to save it.
Posted on Jul 01, 2012
  • 4 Answers
SOURCE: I can't adjust the time zone on my Sharp weather
letydullketesseduke@yahoo.com
Posted on Sep 10, 2013
jsterben
  • 3 Answers
SOURCE: How do I set the correct time zone on my Sharp
On the SPC595, there were no specific instructions to set time zone, either (default was Pacific, I'm in Eastern), so I'm hoping that what worked on this will work on your unit:
Try hitting the "UP arrow" when the clock is NOT in a setting mode. This is not referenced in any "setting time" area but rather the area of the instructions that tells you what each button does. My manual (if you can call it that) says the following:
"UP Button
In setting mode, press it to increase the setting value. Press it to switch the time zone P/M/C/E"
Posted on Oct 12, 2014
biepeg2000
  • 21 Answers
SOURCE: How do I set inside unit to a correct time zone on an EnviraStation Model DWS-150A weather station?
This is for a DWS-150B it may be similar or at least give you an idea
DWS 150 IB Weather Watcher
Posted on Mar 11, 2015
The time zone is set to Pacific. I need to change to Mountain? Can this be done manually?
You should be able to change time zones manually. It would be helpful to have the manual handy to refer to the exact procedure.
Nov 10, 2015 | Honeywell Te923w Professional Wireless...
Need owners manual for sharp spc775
Here is the best I can find. Hope this helps.
Mar 16, 2015 | Sharp Atomic Weather Station Alarm Clock
Change from 24 hrs to 12 hrs
Instructions
    • 1
      Press the "Power" button to turn the machine on. The device takes approximately 5 to 10 seconds to fully load.
    • 2 Press the "Time" button and hold it down for 8 seconds to begin the setting process for the time. Use the arrows on the left side of the device to select the proper hour and minutes. Use the "Up" button to increase the numbers and use the "Down" button to decrease them.
    • 3 Use the arrows to select the time zone that you are currently in. The device automatically adjusts for daylight savings time. Press the "History" button on the right side of the device to view information regarding past weather history.
Read more : http://www.ehow.com/how_7571640_sharp-wireless-weather-station-instructions.html
Nov 02, 2014 | Sharp Weather Station Atomic Clock
How do I set the correct time zone on my Sharp weather station / atomic clock?
"UP Button
Sep 10, 2013 | Measuring Tools & Sensors
I need a manual for the 00593W weather station. Please?
Push and hold the "-" button on the main unit until "P" displays on the screen. You'll now set the time zone so the system can automatically set the clock. The screen will begin cycling between the time zones. Push the "Set" button when the correct time zone appears.
Mar 06, 2013 | Acu-Rite Acurite Wireless Weather...
How do i set time zone on sharp weather station pcs775
"UP Button
Oct 27, 2012 | Sharp Atomic Weather Station Alarm Clock
Sharp weather station manual spc775
How do I turn the light on my spc775
Jan 12, 2012 | Measuring Tools & Sensors
I actually have the same problem with an older model Brookstone weather station with remote temperature gauge. The time/date settings do not allow you to set time zone and eventually the clock syncs to PST.... ANY HELP HERE?
Mar 19, 2009 | First Alert FWS-101 Wireless RF Weather...
Measuring Tools & Sensors Logo
101 people viewed this question
Top Sharp Measuring Tools & Sensors Experts
Dustin
Dustin
 Paul
Paul
Level 1 Expert
rhodesworks
Are you a Sharp Measuring Tool and Sensor Expert? Answer questions, earn points and help others
