Durabrand PDV-705 Portable DVD Player
Problem for Durabrand PDV-705 Portable DVD Player
DVD says loading.... but keeps turning, stops, turns, stops
By isopovm on Jul 25, 2009
I have never had trouble with this unit before. Have always taken care of it. This happens with portable battery and without. Cannot get videos to play anymore. Simple fix???? DVD Durabrand PDV-705
Thank you,
Comments:
Jul 25, 2009
- I took the unit apart and looked over the sliding lense and found that a small piece of the gasket broke off and was blocking the lazer from going past the second track. When we cleaned it out with tiny screwdriver, it works beautifully. I ran a dvd lense cleaning and it couldn't be better. Thank you, (I didn't think that tooth paste would go well with the wiring board.)
Best Solution
posted on Jul 25, 2009
Very Helpful)
alexismsorre
Rank: Wiz
Rating: 78%, 17 votes
is it with every dvd takethe dvd player apart of clean dvd with tooth past let is sitfor 3 day
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Very Helpful)
style_points
Rank: Wiz
Rating: 94%, 47 votes
It is a problem with the laser. Getting a lens cleaner could help, but it is doubtful. Your best bet, tap the unit while the disk is trying to load.
There is a motor that moves the laser into place. Often the motor burns out or it does not focus correctly after a while. Sometimes, they just get stuck. A tap may kick start the motor into place if it is stuck. Most likely, you will have to replace the unit.
P.S. Toothpaste and electronics don't mix. CD players get extremely hot. You will eventually be cleaning Crest out of your DVD player.
Comments:
Jul 26, 2009
- Please mark the question as solved or the person who wanted you to put toothpaste on your dvd player will get credit for the answer. :-)
Was this helpful?
Yes
No
Popular Solutions for Durabrand PDV-705 Portable DVD
Questions and Unsolved Problems for Durabrand PDV-705 Portable DVD
Do you recommend Durabrand PDV-705 Portable DVD Player?
Answer
Answer
I had my dvd player for a while but have not used it. So I decided to use it and now it will not... (More)
Answer
When i turned ON the DVD player, it doesn't work and an orange lite was noted on the ON/standby... (More)
Answer
Instead of green or red light is observe on the ON/Standby light, a permanent yellow light was noted... (More)
Answer
My DVD player is not playing, a fix yellow lite was noted on the ON/STANDBY light found infront of... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Players Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
