Question about Saws
Can I by a new handle for hock eye coumpound miter saw
  • 313 Answers
SOURCE: black and decker coumpound miter saw fence
check out for parts
Posted on Jun 03, 2008
  • 37 Answers
SOURCE: The delta universal miter saw stand will not adjust to level posi
Hi, The legs on the stand should have leveling pads on it. at the bottom of each stand legs, there is a hole which the pad goes in. you can adjust the pad by unloosening the top nut. put a level on the saw base and adjust the pad up or down to level your stand.
If this doesn’t work for you, please write back. Thanks,
Posted on Nov 28, 2008
  • 50 Answers
SOURCE: craftsman compound miter
if its like my dewalt, u have to unscrew it before u canunlock the handle. try unsrewing it.
Posted on Dec 04, 2008
  • 10865 Answers
SOURCE: Craftsman 10 inch miter saw, handle broke
I would reattach it with epoxy. Go to the hardware store with the handle and let the clerk help you pick out the best epoxy for the job.
Posted on Mar 18, 2009
  • 843 Answers
SOURCE: New Dewalt 745 saw, blade not parallel with Miter slot
Either take it back, or take it apart and make the holes bigger. For that kind of money, you should be able to adjust it dead-on. I thought I had the same problem on an old Craftsman, but I found that I just hadn't loosened things up enough. It's hard to see how much wiggle room you really have under the washers. And if there are aluminum castings involved, there can be a burr raised by the initial setting that it gets stuck on.
Posted on Jan 19, 2010
How do I fix the spring on the switch for a 10 inch ryobi miter saw? I can hear it rattling around and the switch won't work. Also plastic screws holding handle together are broken.
Hello Anonymous,
First locate the model number of your Ryobi Miter saw... then search Google for Ryobi Miter saw replacement parts... one result I got is below:
Try that link, select your Ryobi saw model and zoom into the provided drawings so you can locate the switch, screws, and spring (if needed). The part numbers are supplied and you can order them online easily on that same link... Then just repair your saw with the new parts. As you already noticed, the saw is easy to disassemble and get access to the parts for repair. Have fun and good luck...
RYOBI Miter Saw Parts
Mar 10, 2015 | Ryobi 10 In Miter Saw With Laser
My LS1216 slide compound miter saws mitering table is stuck at 0 degrees it appears jammed although I've looked for something jammed stopping the plate from moving and see nothing, the handle locking...
Hello stella....... There is a locking mechanism on the miter saw to lock it on whatever setting you require. loosen that locking mechanism and the saw should move for you. Here is a schematic of the parts so you can see exactly which parts are involved
Thanks for choosing Fixya!
Feb 06, 2011 | Makita 10" Dual Bevel Sliding Compound...
How do u unlock a 10'' benchtop compound miter saw
slightly push down on the handle, then look directly over the top at where swivel spring is either on the left or right side , there is going to be a pull pin, it will only pull out far enough for the handle to go up and down, its not suppose to come all the way out
Jan 12, 2011 | Makita 10" Compound Miter Saw LS1040
Hi my name is andres and i would like to know how to remplace te miter saw handle im my miter saw dw 718 dewalt
give me your email address & I'll email you back with a schematic of your tool and simple directions for replacement. Email request to
Feb 11, 2010 | Dewalt Heavy - Duty 12" Double - Bevel...
Changing the blade
there is a nut holding the blade in the center , it is left handle thread , there should be a locking mechanism to hold the blade while you unscrew the nut
Oct 31, 2009 | Makita 10" Compound Miter Saw LS1040
Mar 18, 2009 | Saws
Locking mechanism on miter saw.
Push down on the handle . Facing the saw there is a spring loaded pin on the left rear side , right at the pivot point , pull out on it and raise the handle to the up position.
Jan 03, 2009 | Dewalt DW715 Heavy Duty 12" Single -...
Craftsman compound miter
Sep 05, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Dewalt miter saw .
Either the blade or the guard is out of alignment. You will have to check and find out which one is the culprit.
Aug 29, 2008 | Dewalt DW715 Heavy Duty 12" Single -...
Saws Logo
27 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
