Question about Toshiba Office Equipment & Supplies
How do i clear the error code C413 at Toshiba estudio 2505
  • Toshiba Master
  • 643 Answers
08-2002 "0"
Posted on Sep 09, 2017
  • 1126 Answers
SOURCE: Toshiba estudio 166 C44 error code
Hold "0" and "8" while turning on machine.....continue holding until machine enters service mode. Enter "400" press enter. Enter "0" press enter. Power off / on. If code returns, machine needs parts replaced. Do Not keep resetting, may cause damage to Fuser Unit.
Posted on Sep 14, 2009
mce_sys
  • 41 Answers
SOURCE: toshiba estudio 4511 error code C440
Press 0-8 then enter 400 and make it 0 then press print switch, if doesen't work u have to change thermostar, then if not working change heater, if not then IH board, and the last solution is to change the system board.
Posted on Jul 24, 2010
  • 132 Answers
SOURCE: toshiba estudio 351c error code
Hi
I hope that this will help you
[CE40] Image quality control test pattern abnormality
(1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color.
(2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" to
check if the low-density pattern abnormality occurs for each color. The values under 320 for Y, M
and C, and under 220 for K are defined as low-density pattern abnormality.
(3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" to
check if the high-density pattern abnormality occurs for each color and identify the color which
pattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality.
(4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image
quality closed-loop control / Laser power (08-557)" to "0" (Invalid).
(5) Perform "Enforced performing of image quality open-loop control (05-394)".
(6) Output the image quality control test pattern (04-270) more than one time and check the patch of the color identified in step (3) to see if the image is abnormal.
(7) Replace the image quality sensor.
(8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image
quality closed-loop control / Laser power (08-557)" to "1" (Valid).
(9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it is
completed normally. (Error [CE40] does not appear.)
(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576).
Good Luck
Regards
Posted on Apr 12, 2011
  • 81 Answers
SOURCE: How to clear the job
if there is a username and passowrd you log in. then at the bottom right of the screen you will see a job status button. if you press it it usally opens up to the jobs list .. if not after you press it look on the top of the display and select job status or print status. the select the job you want to delete and press delete.
NOTE: if your machine has a fax you cannot delete fax jobs without doing an all reset!
Posted on Sep 08, 2011
SOURCE: Toshiba estudio 2830c error code ce40
I want to locate the position of the image sensor for a toshiba E-Studio2500c.
Posted on Jul 19, 2012
To clear the code error c413 of Toshiba estudio 2505
How do i clear the error code C413 at Toshiba estudio 2505 thnx, regard asif ali
Feb 08, 2017 | Toshiba Office Equipment & Supplies
Call for service C413 toshiba estudio 2006
Here is the verbage for the error code at this link
http://printcopy.info/?l=en&mod=erc&brand=Toshiba&model=e-Studio%202006&code=C413
In the interim you may try the following one time to see if it is a false error... Hold "0" and "8" while turning on machine.....continue holding until machine enters service mode. Enter "400" press enter. Enter "0" press enter. Power off / on. If code returns, machine needs parts replaced. Contact your Toshiba technician (there should be an 800 number label on the unit for service. Do Not keep resetting, may cause damage to Fuser Unit.
Aug 11, 2016 | Toshiba Office Equipment & Supplies
Toshiba copier
for e207 model, error code should be in C44, F14, and etc...
Assume your error is C43, check the fuser thermistor, clear the error using 08-400 = Any value => "0"
Oct 01, 2015 | Toshiba e-Studio 207 Copier
How do i clear the error code c413 of toshiba ed2307
Heater lamp abnormality
1. Turn ON the power while [0] and [8] are pressed
simultaneously.
2. Key in "2002", then press [START].
3. Change the current status counter value "3" or "4" to "0",
then press [OK]
4. Turn the power OFF and then back ON.
Jul 23, 2015 | Toshiba Office Equipment & Supplies
How to solve c413 error problem in Toshiba eStudio 2006?
Make a service call to have a representative come repair it.
Apr 22, 2015 | Toshiba Office Equipment & Supplies
How do i clear the error code c413 of toshiba estudio 2505
C413 - Heater lamp abnormality after abnormality judgment (not reaching to intermediate temperature)
See Service Manual, page 8-32:
TOSHIBA STUDIO 2505 service manual
Nov 04, 2014 | Office Equipment & Supplies
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
