Question about The Computers & Internet
Horizontal lines is apearing on my kodakeasyshare z1275 and it is dansing all over the screen, it also apear in the photograph
  • 3422 Answers
The most common cause for the loss of picture is a bad Horizontal Output Transistor (HOT). but I would suggest you get a detailed estimate. I think that this would cost you about $60.
The horizontal lines means the vertical amplifier or deflection system has failed. There are over 100 components in this section and any one of them, or most of them can be at fault. However, the most common failure is the VOT or vertical output transistor (which is often buried inside a chip).
The repair will cost around $250 plus or minus.
ONE: Do a hard reset (just to make sure there is nothing in the coding that is fowling things up). Unplug the power cord; leave it disconnected for 4 hours. That will restore everything to factory defaults when you power it back up.
TWO: Do the "whacking test" by banging your fist on a few strategic places to see if there are any cold solder joints or loose wires acting up inside the set.
If the above steps don't solve ur problem then I suggest you to go for a repair..
Posted on Feb 21, 2008
SOURCE: panasonic sa-ch84m
throw it out the window
hope this helps
Posted on Sep 18, 2008
  • 19 Answers
SOURCE: blank screen
Sometimes an easy solution to this is to turn off your laptop completely, remove the power lead from the socket and the laptop, then remove the battery, leave for a couple of minutes and then try again.
If this does not work, then you are into the realms of programming / restoring.
I hope this helps you, Chris
Posted on Nov 11, 2008
  • 11361 Answers
I just fixed my today, you need to replace the LCD controller board, there are two versions (V320B1-C, 35D003848) you need to open up the tv and remove the shield cover to get to the LCD controller board, this is a common problem with this model. Look here parts (make sure to get the part number of the LCD panel sticker to match wit the LCD controller):
You cam see the one I fixed here:
Notes: be real careful when you remove the back cover, the side switch assembly is attached to the back panel, so do not pull it off too far, or you will damage the switch assembly!
Posted on Dec 28, 2009
  • 691 Answers
SOURCE: My nintedo DS Lite has a big black line across the
Parts are fiddly to install and require some soldering but they are cheap too so if guarantee is out and you know someone with electronic skills then you can give it a go. If you decide to get someone to do it for you you will need new top and bottom screen and it's worth getting the digitizer screen too. Shouldn't cost much more than £15 for the lot
Posted on Feb 14, 2010
White screen on blackberry
i pressed my bb screen hard and then halfway through the page a white mark apeared and the horizontal white line. what should i do
Oct 28, 2012 | RIM BlackBerry Curve 8520 Smartphone
There is a white line on my screen like a scratch but is clearly not on the surface. Is this cosmetic damage or should i return this under warranty?
if the line apeares to be part of the displayed image on the screen and typically would be only either horizontal or vertical then the screen has a deffect and it should be covered under warranty if still active. but examine carefully because sometime the internal of an LCD screen get cracked normally because of something that pushed againest it from the outside or againest the cover and if that what happend it would not be covered under warranty. best of luck
Jan 25, 2011 | Computers & Internet
No picture just 3 curve color lines
do the lines apear all the time? can you make the menu apear.where do the lines apear
Sep 21, 2010 | RCA R61WH76 61" HDTV
On the lcd display lines are apearing both horizontal and vertical,please help.
Your best bet is to contact Furuno. Replacing the LCD in those displays is very time consuming. I recommend writing your waypoints down or transferring them to a computer while you can still somewhat see the screen.
May 27, 2010 | Furuno GP32 Gps 4.5" Display
The pictures have horizontal lines through them. The veiw screen is fine. When you review or save them to the computer they show up whiter and with lines. Thanks ahead for any help.
If this doesn't apear on the print pictures taken directly from the SD card. It has something to do with the settings for the picture transferre on your computer.
Try and reset/adjust the settings within the transferre programe. I cannot tell you the eact steps for that since it will depend on the programe you're using. But it can usually be done right before transferring pics to the computer.
If helpful pls. recommend/rate me and or give me a review. TXS
Dec 03, 2009 | Kodak EasyShare Z612 Digital Camera
Z1275 produces horizontal lines through images. Flash, auto, program....doesn't matter what mode.
If your Z1275 has horizontal lines going through the images you should call Kodak Technical service
the number is 18002356325 op1 op12 op2
hope this help
Sep 16, 2009 | Kodak EasyShare Z1275 Digital Camera
No image on a toshiba Cf27g50
If it is a vertical line, change the horizontal output transistor + capacitors. If it is a horizontal line, replace vertical output transistor + capacitors. Both cost around $10-20.
May 21, 2009 | Toshiba CF27G50 27" TV
Computers & Internet Logo
13 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
