Question about Karcher 2500 PSI Pressure Washer
Engine locked up
My engine is locked up because the pull cord will not come out any more than a few inches but I checked the oil and it is fine. HELP!!! Does this mean the engine is blown or what????
Thanks so much
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Time to take off the head or at least start with a spark plug
try it now
ok it turns time 4 a rebuild
ok it doesnt turn time to but a new machine keep removable parts
remove motor and leave every thing else
Posted on Jul 25, 2009
Was running stopped. Starting pull cord only moves a couple of inches then feels like engine gets locked.
indications are that the ring has seized or broken in the cylinder
check the oil/fuel ratio in use as it may be a bit on the lack of oil side
Nov 19, 2016 | Garden
Unable to pull starter cord nu more then 4 inches I have removed the spark plug and released the pressure still the same what more can I do??
Dear Sir,
I understand that the engine seem jammed. Removing the spark plug was a good idea. This indicates that the engine cannot turn.
The only reason I think this happens, because the pump is jammed.
If with some method you separate the engine from the pump, you will for sure find out if the pump is jammed. Also you can release the pressure from the pump, if you have access to its valves and remove them. So trying to pull the cord with no load from the pump is the next thing you should do, with a few methods I have explained.
Regards,
M.G.
May 31, 2015 | Karcher 2500 PSI Pressure Washer
Pull cord is stuck cannot start mower
is there oil in the engine?remove the top cover and see if the recoil works without the engine on it
Aug 15, 2012 | Garden
The pull cord is locked, can only pull out 5 inches....why?
Could be motor locked up or cord caught in the rewinding mechanism. Remove top engine cover and see if cord pulls now. If not then in winder. If it does see if you can turn the motor over by hand with cover off. If not maybe engine locked up. Did the engine run low on oil? if so when motor cooled, things may have locked up. Try removing spark plug, and light oil to cylinder and let soak.Turn engine with wrench.
Jun 30, 2010 | Briggs & Stratton Power Products 5,550...
Pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Mar 21, 2010 | Karcher 2500 PSI Pressure Washer
Recoil will not pull. The walk behind MTD,Yard Machine mower, a B&S 500 Series stalled while mowing. I went to restart and pull cord will not pull more then a few inches. How do I go about the fix?
If all the safety gear is working on the mower; Possibly sounds like you let it run low on oil and the engine is locked up.
Which would mean a new mower.
Sep 29, 2009 | Mtd Garden
Motor seems to be locked up!!!!!!!!
It may be your engine, but it may also be the water pressure. Try this: Hold the trigger down while pulling the recoil starter. This acts as an unloader for the pressure washer, and may allow the engine to turn over. There is also an oil level in the pump as well as the engine. Check both levels.
Just a thought, but I've been there. Best regards, W/D
Aug 16, 2009 | Devilbliss DeVILBISS Devap DVH2600...
Pull cord is locked. Was running fine and just
any oil in the engine? pull cords are easy to replace but sounds like you run out of oil and the engine locked up!
Jun 21, 2009 | Karcher 2500 PSI Pressure Washer
Poulan 16" cannot start...pull cord locked up
Remove the cover, should be 4 screws that holds it on once the 4 screws are loosened the rope could rewind on its own. If not check to make sure the spring is not broken.
Apr 06, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Karcher 2500 PSI Pressure Washer Logo
424 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
