When i take pictures, the horizontal lines that i see on my screen also appeare in the photograph. Please help me out
techman
  • 3130 Answers
SOURCE: Proscan PS35123-horizontal line only,sound ok
You have whats called a verticle swep falure. Its probably just the verticle output IC but if you dont know much about soldering or circuit troubleshooting ,you should leave this to the pros. Theres way to much Hi voltage inside these sets to twiddle around inside them. Also there are no consumer serviceable parts inside these sets as well, as they are all solid state, and my advice is spend a few bucks and get a pro to do this job for ya, as it can, and will, kill ya if your not careful.. Is it worth saving a few bucks??? Naawww Call a pro.. Good Luck
Posted on Jun 13, 2006
SOURCE: LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
I unplugged the TV and now the picture is back.I read that the LCD's are vunerable to static build up so unless my daughter is using her TV I unplug it.
I was thinking about getting a large LCD for the family room but I'm not going to until they improve on this technology.
Good luck to everyone!.
Cheers.
Posted on May 08, 2008
SOURCE: 3 INCHES HORIZONTAL LINES ON SCREEN
i have a whie line going horizontal all the way across the sceen. how do i get rid of it?
Posted on Nov 22, 2008
zohail
  • 1223 Answers
SOURCE: hORIZONTAL LINES APPEAR IN LCD EVEN AFTER TAKING PICTURES IN IAUT
Case 1: if these lines appear only on cam lcd and not on pics if u see them on pc then ur LCD is faulty get it replaced under warranty
Case 2: if all pics have horizontal lines on them if u see them on computer then it is a BAD CCD see the link below to confirm u can still get it repaired free under warranty if u dont have warranty they will still do it free of cost i am sure it is a manufac fault hope it helps u
http://www.imaging-resource.com/badccds.html
pls rate me FIXYA for diagnosis dont waste time run for warranty claim or tell me i can get help for u and guide u where to go tell me ur region !!
Posted on Mar 31, 2009
  • 10 Answers
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Posted on May 23, 2009
Lines down screen
We have a Samsung LE32A457, whilst we were watching T.V tonight the top halve of the screen suddenly appeared with green lines halfway down the screen and that half of the picture was unwatchable, T.V is 2 years old. We have removed all scart leads but this did not help and the problem still exists, when shutting down a white horizontal line across the centre of the screen appears from this line upwards the picture is faulty. Any help or advice would be grateful.
Jul 08, 2010 | Samsung LE32A457 32 in. LCD TV
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Is there any debris under the printhead nozzle plate?
Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
Horizontal pale blue lines on LCD screen and even on picture
Hey Ma-ya,
Most of the time horizontal lines are a result of taking photographs in very bright situations. If you are seeing horizontal lines on the LCD screen and in your images in low light situations this is most likely digital noise. Two ways that could fix this problem are turning the noise reduction on, and/or making sure your flash is turned on and your subject is within the range of your flash. Another cause of digital noise is having your iso set too high (I never shoot over 400 iso). I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 16, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
Lines appearing on pictures even though lens is clean
yes it can repairable,and it is ccd problem or internal flexible pcb.
this actually referred to aperture system.
Jan 25, 2008 | Panasonic Lumix DMC-LX1 Digital Camera
"Noise" on scanned photographs
if you are able to open the cover of scanner glass then pls clean the glass and see.
Nov 15, 2007 | Canon CanoScan 4200F Flatbed Scanner
Problem with picture and sound
A board (signal) bad ? or possible B board.....proof is by
substituion = can get expensive.................T.
Oct 13, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Horizontal pixel line
I have seen this B4 here is a link that may help. http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Mar 31, 2007 | Samsung SyncMaster 240 T 24.1" Flat Panel...
A horizontal or vertical red line appears on picture.
Red lines are caused by glare. Avoid photographing shiny surfaces that reflect excessive amounts of light into your lens.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
