Question about Panasonic Audio Players & Recorders
I NEED PANASONIC SA-VK480 5CD MECHANISM TIMING CHART. HOW I CAN GET IT?
Sa-ak55 cd mechanism diagram
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Disassemble procedure to many brand panasonic devices are given with illustrations.
Jul 11, 2014 | Panasonic SC-VK31 220 Volt 5-VCD/CD...
Panasonic SA-PT460 disc tray don't opening
The tray mechanism tracks may be binding or the mechanism may lack sufficient power to move the tray.
Dec 30, 2013 | Audio Players & Recorders
Panasonic cd stereo sa pm19 The cd reader skips on any cd. I've tried all the lens cleaners. I was told by an electrician that the tracking mechanism for the laser reader needs periodic lubrication so it...
Your Panasonic stereo will have to be disassembled to access the CD drive. REMOVE POWER BEFORE DISASSEMBLY! Be sure to read and heed the warning about exposure to the laser before attempting maintenance. The tracking mechanism may need cleaning before it is lubricated. For lubrication, I have used silicone spray (the kind used to unstick windows) applied to a cotton swab and then applied to the mechanism tracks.
Nov 11, 2013 | Panasonic Audio Players & Recorders
Panasonic model no sa ak 67 aux not work please makenic in bokaro
my set model SA-AK67
its cd mechanism motor is not working.supply ic coming from main pcb to cd loader ocb.please advice
Apr 12, 2011 | Panasonic SC-AK24 CD Shelf System
Panasonic SA-AK29 Disc Drawer won't stay closed.
It is quite possible that the timing within the mechanism had changed. Since the timing is quite important to activate the mode switch to triggerr the sequential action of the mechanism to proceed accordingly, a small change in any of the links can change the mode to keep away from resetting. Please open the set and check if there is any foreign particles lodged into the dirve mechanism. Clean and proceed. Check carefully for any sensors that are out of sync.If you are not sure do not attempt but try tomake a small correction to complete the loading so as the complete the mode. If so the fault might clear. Hope this helps you out.Good day
Jul 20, 2010 | Philips Audio Players & Recorders
Panasonic sa-ht9030
The loading mechanism is out of timing sequence and needs to be rebuilt. This unit should be taken to a Panasonic authorized service center for repair. At that time the loading mechanism may be modified according to engineering updates that may apply to your model. I don't have a listing for your specific model, but there were some models that had a change to prevent this type of problem.
Dan
Aug 29, 2008 | Panasonic sa-ht930 Home Theater Audio...
Jammed CD tray system
You may have a disk that fell out of tray onto lower mechanism. Be careful when disassembling mechanism as they have timing gears that are positioned to perform certain functions
May 06, 2008 | Audio Players & Recorders
Panasonic SA-AK48 JUST GOES TO F6 1 when you turn on
This is an indication of a mechanical error. There is a factory mod available for this model, I believe, that will repair this. The CD loading mechanism needs to be rebuilt and a modification made. You should take this unit to an authorized Panasonic service center and request the modification.
Dan
Apr 24, 2008 | Audio Players & Recorders
Broken tray Panasonic SA-HT820V
You should note that u will not be able to order that particular alone, rather you can only get the entire mechanism.
Thanks........!!!!!!!!
Feb 08, 2008 | Audio Players & Recorders
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
