Question about Casio Office Equipment & Supplies
Casio calculator key no resonce - Casio Office Equipment & Supplies
Minus 20% of 175.00 using the percentage key
On most Casio calculators you must type: '175 x 20 % -' (and '+' is for adding a percentage)
Feb 18, 2015 | Casio MS-80S Calculator
How do i put secant into my casio fx-260 calculator
The Casio FX-260 does not offer this function as a single key operation. However, calculating sec(x) is simple as sec(x) = 1 / cos(x).
Key in x [COS] [1/x] and the wanted result is displayed.
Jun 07, 2014 | Casio Office Equipment & Supplies
Factorial key
In Run screen enter the number whose factorial you want to calculate, then press OPTN. Using F6> pan the tabs till you see PROB. Press the key that is under the tab. You will find the factorial function.
Dec 09, 2013 | Casio Algebra FX 2.0 Calculator
My calculator is to light and i have no 2nd key
The key is marked [Shift] on Casios, [2nd] on TI's, and [2nd F] on Sharps. I have seen some cheap calculators that mark the key as [Inv]. HP calculators are rather different in that respect.
Sep 20, 2013 | Casio fx-300ES Calculator
Where is the math button on the casio fx-9750G11
It is a calculator and prqactically every button is a MATH button. It depends on what MATH you intend to do. Put the calculator in Run/Mat screen then press the OPTN key. You will see several tabs. Press the function key under a TAB and explore what is offered. Go through all the keys (F6 also) and see what the new tabs do.
In general it is most helpful to read the manual that shipped with the calculator.
Oct 16, 2012 | Casio Calculator Graphing FX 9750GII...
How do I change the tax rate on my Casio dr-210hd from 5% to 6%?
Press AC twice Hold down % set key for 4 seconds. Input tax rate (6%). Press Tax+ key, then press % set key
Source: http://www.casionz.co.nz/Site/CASIO/files//settingandusingtaxandexchangekeys.pdf
May 03, 2011 | Casio DR-210HD Calculator
Problem changing tax rate on casio calculator
Press AC twice. Hold down % set key for about 2 seconds until ?0? disappears on screen, then reappears. Press Tax Rate key. Input tax rate (12.5%) and press % set key.
Apr 11, 2010 | Casio MS-80TV Scientific Calculator
How do you get on second function on a calculator
Use the Shift key or the Alpha key to type letters. If there are two symbols near a key,on the body of the calculator, the symbol to the left is accessed with SHIFT, the one to the right with ALPHA. On certain calculators symbols are color-coded.
Jan 31, 2010 | Casio FX-9750GPlus Calculator
How do i calculate permutation in fx-82ms casio calculator
Find on the calculator the [nPr] key either (you may have to use the [2nd] or [2ndF] key) then
1. Enter the number that corresponds to n eg. 18
2. Press the [nPr] key
3. Enter the number that corresponds to r eg. 5
18[nPr]5 gives 1028160
If you calculate combinaitions use [nCr] key.
Hope it helps
Aug 11, 2009 | Casio FX-115ES Scientific Calculator
29 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
