Question about Samsung Refrigerators
I have a Samsung RSA1DHMH FRIDGE FREEZER put In new filter and flushed it but there is bubbles in the water, what is causing this to happen and will it make any difference to us drinking the water
    New Friend:
  • 117 Answers
It should be fine just let water run for a bit .Water should be fine to drink
Posted on May 17, 2017
Fridge freezer gurgle noise problem. Freezer window flashes replace filter . New filter installed. Noise continues emanating from freezer. Help please
The problem is AIR In The Line. Either you have a leak in the water line or the filter was not tight. In some cases, people screw the filter in wrong, and cross-tread when screwing the filter back into the fridge. If the filter gasket failed to make a tight seal, air can enter and cause a noise. If the water l;ine has a small pin hole, when water is flowing within the tube, it too can make a noise. That can happen when drawing water down for drinking or when the ICE Maker is reloading the tray.
Feb 03, 2015 | Siemens Bosch Neff Integrated Fridge...
I put a new filter in my Sansung Refrigerator and the water taste worse than the old one, why?
I agree with Gramps... the system needs to be flushed, but one question... why did you change the filter in the 1st place... was it cause you had a smell or taste in the water AND ice, or the filter light came on?? I would remove water line going to ref from house plumbing... run water in bucket for 2 min, then take a small taste to see if good..If water taste good, then hook water line back up to ref, and run water at the door for about 1/2 gal, then taste and smell water to see if it passes... If still have problem, you are going to have to replace filter head and/or water reservoir.... But before i did that i would contact Samsung to get their take, depending on age they might send parts at no charge to you the consumer....... Ken Hawk
preferred Samsung servicer
Jan 20, 2015 | Samsung RF265AA Bottom Freezer French Door...
What happens to filter if fridge is off for a month? It is a kitchen aid french door with freezer bottom. will the filter go bad and need to be replaced?
As water sits at room temps its can cause your filter to go bad or even clog. I would replace the filter and flush the system after filter installed to clean out the supply line to the dispenser door.
Safety first, good luck
Jul 27, 2011 | Refrigerators
I replaced my GE profile MWF water filter (identical GE part) and now I dont have water dispensing and don't have a working ice maker
Quite frequently carbon fines can be flushed from filter and plug the filter. If you have the bypass plug to replace the filter. Put that in and flush system completely. Take the filter and flush it at the kitchen sink. It is best to fill these with water before installing and flush the carbon fines before installing in fridge.
Mar 09, 2011 | GE Mwf Ge Refrigerator Smart Water Filter...
Samsung RF267 water tastes terrible. Filters changed twice and not helping
If new plumbing, system is flushing and may cause a bad taste or odd color.Has a food item spoiled?
Make sure that strong smelling food (for example, fish) is wrapped so that it
is airtight.
Clean out your freezer periodically and throw away any spoiled or suspect food. Place foods in airtight containers to prevent the transfer of odors.And also Flush out water hose from tap end to freezer with warm water And also clean fridge with wet cloth (with soap solution). And then clean with dry cloth. .Keep fridge door open after cleaning all compartments for 4hrs minimum, as fresh air could wipe out any bad odor in fridge. And then start using fridge. Hope, it's helpful.
Jan 29, 2011 | Samsung RM255LASH Side by Side...
1 Answer long does it take to fill and flush a new water dispensing system?
My samsung fridge takes a couple of mins or less.You need to flush the filter first, i.e connect the water to the filter and flush through before connecting to the fridge. When you start to flush filter water will be grey/black ( filter are full of carbon), flush till water comes clear. connect to fridge and you should be set up.
Please rate me if this helps
Dec 31, 2009 | Kenmore Refrigerators
Filter indicator on samsung side by side fridge freezer is on
2 places filter can be top left upper corner of fridge or behind the fridge with a little longer filter type
the smell could be the filter but i would pull all drawers and shelves and i would check for mold also the possibility of water leak behind panel of water spout that has molded over this smell you could never forget cause smells like old gym socks
Apr 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
37 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
