Question about Hobart Dishwashers
I have a hobart ft900 with error code e516 what is the problem please help
Screen says temp error final rinse e516 on a ft900sd hobart dishwasher
bigg t
  • 640 Answers
SOURCE: what is p3 code on hobart am15 dishwasher
It means that the final rinse thermistor is bad.Your not getting 180 degrees---right?Its located on the booster and costs about $65.I work for hobart.Any ?
Posted on Jan 25, 2009
whytfang
  • 170 Answers
SOURCE: E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Posted on May 19, 2009
  • 109 Answers
SOURCE: Hobart dishwasher model LX30H; displays wrench and E4.
Water is not to top sensor in alotted time.
Top sensor is in right rear corner, and is the upper of the two. Check the connector to the probe on the outside at the back. (sometimes gets wet fro vacuum breaker leaking when dirty or low flow pressure. Machine needs 20 psi flow rate
Posted on Aug 14, 2009
  • 6 Answers
SOURCE: P1 error code on LX30 Hobart
This is a bad sump temperature probe. The unit will function, but will not heat nor display the wash water temperature.
This is a very easy fix. Order Hobart part number 328994 from your nearest Hobart parts dept.
Turn off and drain the unit. Kill the power to the unit at the circuit breaker. Remove the lower front cover. Locate the screw-in temperature probe at the front of the sump. Unplug the sensor from the wiring harness, remove with a 7/16" open end wrench. Screw in the new probe, using teflon tape of the threads, snuggly. It does not need to be super tight. Plug it into the harness, reinstall the front cover, turn the breaker back on, and start up the unit.
TURN THE BREAKER OFF AS EVEN WITH THE UNIT "OFF" THERE WILL BE 120 VOLTS PRESENT AT THE SUMP HEATER (yellow wires) DUE TO ONLY ONE LEG OF POWER BEING SWITCHED OFF!
Posted on Sep 12, 2009
Testimonial: "You were right! can you help mr with a P2 error code?"
  • 110 Answers
SOURCE: lx30h P2 ERROR CODE? WON'T DRAIN COMPLETELY - HELP
the p2 err. is on open or shorted rinse thermistor which is located on the back of the mach next to the vac. brkr. as for draining ck the drain valve for debris, and the end of the drain hose where it connects to the building drain
Posted on Jan 13, 2010
We have an ft900 with error code E516 can we reset to get unit going?
Operation and Care of FT900 SERIES DISHWASHERS SAVE THESE INSTRUCTIONS OPERATION MACHINE PREPARATION - Check before beginning operation. Open the machine doors and make sure all components are in their proper operating positions Pump Intake Screens must be put on holders at each pump intake (Fig.1). Fig. 1 Strainer Pans must be in place on top of each tank (Fig. 2). Fig. 2 End Caps must be correctly installed at ends of all Wash Arms (Fig. 4). Fig. 4 Wash Arms must be properly installed and latched in place (Fig. 5). Fig. 5 The Final Rinse Arm (and Dual Rinse Arm when present) must be properly installed (Fig. 7). Fig. 7 Curtains and drainback pans must be in their proper places, refer to pages 11 - 14. Strainer Baskets must be in place in Strainer Pans (Fig.3). ANK FILLING Assure proper water hardness. Recommended water hardness is 3 grains or less per gallon. Higher hardness may cause excessive formation of lime scale. Chlorides must not exceed 50 ppm. All water (and steam, if equipped) supply valves must be opened and the electric supply turned on before the machine will function. Close all drains and doors. The drain handles are located near the floor at the front of each tank. Rotate drain handles clockwise to the vertical position. The prewash tank,
Sep 29, 2016 | Dishwashers
Causes of low rinse water pressure on a Hobart ft900-d washer
For a machine without a break-tank (a.k.a. cistern) and booster pump: check the inline debris strainer on the rinse water pipework; check you're not missing any rinse jets; check the inlet valve is fully opening.
For a boosted machine, check the pump impeller isn't disintegrating; check that the flexible hoses to the booster pump aren't collapsing internally.
For both machines: descale if you're in a hard water area.
Mar 15, 2015 | Hobart Dishwashers
P2 error, replaced rinse probe, hi limit thermostat, still have an error p2
P2 error is the final rinse probe. Depends on the model of the D/W for location, next to the vac breaker.
Apr 26, 2012 | Hobart AM15T Dishwasher
Lx30h P2 ERROR CODE? WON'T DRAIN COMPLETELY - HELP
Dec 25, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Temperature Problem
Whats the model?lxih,lx30h,lx18,lx40?What temps are low,wash or rinse?Im a hobart tech and service these units.Let me know.
Jan 19, 2009 | Hobart 24 in. LXIC-5 Built-in Dishwasher
What is p3 code on hobart am15 dishwasher
Jan 08, 2009 | Hobart 29 in. AM15-1 Free-Standing...
Rinse cycle has no water
check the sump probe under the screen and the 2 probes in the right back corner.clean them with a light grit sandpaper.let me know.
Mar 28, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwashers Logo
220 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
