Question about Sharp Office Equipment & Supplies
Please i need help, hot to enter service mode on sharp copier mx 4112?
  • 148 Answers
SOURCE: Service Mode On Sharp SF2530
A little rusty on this machine, but try this.
This code means you have had to many paper jams in the fuser without removal. Make sure all is clear in the fuser and exit sections.
Then on the control panel you will press a series of buttons as follows.
Press the Clear, Press interrupt, Press Zero, Press interrupt, Enter # 14, Press start, That should reset the machine...
Hope that helps...
Lbcoaster
Posted on Jul 02, 2008
SOURCE: Sharp service code H5-01
To enter simulation mode to reset errors enter this sequence on keypad.
P, * , CA , P then enter sim # 14 to reset code.
press " custom settings" button to return to previous menu and CA to exit sim mode.
Posted on Dec 11, 2008
Cogz
  • 1326 Answers
SOURCE: Minolta CSPro 3000 Copier/how to enter service mode
Press Stop - 0 - 0 - 1 or it maybe User Funciation then meter count - Stop - 0 - 0 -1 , it's been years since I worked on them
Posted on Feb 07, 2009
SOURCE: MX-2300N Sharp Copier will not print
Do you have setup accounts on the copier?
Posted on Apr 02, 2009
rodco1
  • 6 Answers
SOURCE: how to enter service mode in ricoh aficio 3800
Hold down the two arrow keys and count to 5, hit the enter key, the machine should be in serrvice mode if nor repeat. use arrow ke and scroll to machine press enter scroll to data log press enter scroll to pm counter reset presss enter, scroll to fuser oil press enter and exicute this mod Please. DO NOT GO INTO ANY THING ELSE or you could do serious damage to your machine!! If your machine has a Copy feature expander yopt must press Clear mode, Press 1-0-7 and then hold down the stop cancel key 4sec. go into copy sp mode press 7-804-809 press exicute button again Please DO NOT GO ANY WHERE ELSE as damag can be done to your machine. Hope this helps!!
Posted on Jun 17, 2009
Sharp MX-3100; what does DK mean
h r u . DK MEANS black drum life is over need to replace black drum unit or Reset black drum unit counter.
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code07
Then you can select what you want to clear so the bk drum unit
Feb 26, 2015 | SHARP MX-3100N
HALO I Wanna to know sharb service mode?
Yes the Sharp Mx2300n has service mode. To enter service mode you will need the original admin password, this password 9 times our of 10 is admin.
Step 1: press SYSTEM SETTINGS button on printer
Step 2: At the top right side of the screen is two buttons 1 Admin Password 2 Exit. Press Admin Password.
Step 3: Press password button
Step 4: type admin (no caps)
Step 5: press OK
And remember to sign out when your done. I hope you enjoy your sharb printer, I certainly enjoy my sharp it's a good one yes.
McHaggerty out
Feb 23, 2015 | Sharp MX-2300N Color Copier
How enter sin simulation mode in sharp MX-M354N
To enter simulation mode you need to press the following 4 buttons in quick succession:
# * C *
The # & * keys are to the left & right, respectively, of the zero key,
the C key is the red C to the right of the number 3 key.
Hope this helps
Jan 14, 2015 | Sharp Mx-M354n Mfp
We have a code h4-30 on a sharp mx-2700n how do I reset?
You need to make sure the machine is in Copy Mode when you hit
# * C *
enter 14, then touch start
execute on the screen
the machine will reboot and the code should go away.
If it persists you may need some maintenance. If you're in Houston give us a shout. Our labor rates are low compared to the other Sharp dealers in Houston.
Skelton Business Equipment Houston Copiers
http://www.youtube.com/equipmybiz
Jul 07, 2014 | Sharp MX-2700N Color Copier
How to clear an service error code on a sharp printer?
try turning the machine off then on. if that doesn't work, from copy mode type # * C * to go into service mode (test: enter a simulation). Clear codes 14, 15, 16, 17. type the number then hit the start key. then CA to reboot, you must try the codes on at a time. Please report what your error code was.
May 29, 2014 | Sharp MX-3501N All-In-One Printer
I need to enter simulation mode on Sharp MX-M260N. Also, I am looking for the MIB code to enable/disable copier via SNMP
Simulation Mode is # * C * What do you mean by the MIB? I know that you can setup settings for the SNMP on the webpage of the copier. Have you tried that?
Nov 08, 2011 | Sharp MX-2300N Color Copier
TA code. After reading your previous questions, I am trying to follow how to clear this code but don't understand your proceedures. it says you want # , 8, c * To enter service mode So.....where do...
To get to service mode, press the # key, the * (star) key, the C (clear) key, then the * (star) key again in rapid succession. This will bring you to the service (simulation) mode.
Nov 03, 2010 | Sharp MX-2700N Color Copier
Sharp mx 2700n how to go SP mode and i get error code h5.01 how i solve this problem
Use SIM14 to
cancel the trouble.
Entering the simulation mode
1) Copy mode key ON → Program key ON → Asterisk (*) key
ON → CLEAR key ON → Asterisk (*) key ON → Ready for input of a main code of simulation
enter 14
accpet yes clear..
machine should restart.
You may have to have a tech look into why this is jamming...
Hope that helps
Lbcoaster
Dec 23, 2008 | Sharp MX-2700N Color Copier
27 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
