Question about Locks & Locksmithing
How do i use the key symble on swann SWHOM-DP875C TO OPERATE ON A NEXION KEYLESS ENTRY LOCKSET
LOCKSET FITTED TO FRONT DOOR
chuck943
  • 783 Answers
SOURCE: CHANGE CODE ON KEYLESS ENTRY SYSTEM FORD EDGE
Yes you can program your own code by inputting the original code then hit the no. 2 button then input your own 5 digit code.
Posted on Mar 16, 2009
dr_greg
  • 192 Answers
SOURCE: Honda Civic 2002 keyless entry
inspect and or replace the drivers door lock actuator...
Posted on Apr 05, 2009
messstat
  • 365 Answers
SOURCE: Keyless Entry won't Lock/Unlock back door
Factory keyless?
Posted on Jun 14, 2009
  • 3197 Answers
SOURCE: Can't reprogram/operate keyless entry pad for
If the following instructions don't work and you have a good battery the keypad has failed.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in your 4 digit code and press enter.
Posted on Apr 07, 2010
Testimonial: "Bless you....thanks so much... its working, yea."
jas0518
  • 130 Answers
SOURCE: Power door locks not working
this is a comon problem with 05 and 06 dodge and chrysler vans. this will sound crazy but take both battery cables loose, then touch them together for about 30 seconds, this will drain all the reserve power out of the computer and reset the computer. reconnect them and viola your locks will work for a few days or weeks then you'll have to do it again. or go to the dealer and get your ICM computer "reflashed". they may charge up to 90 dollars to do this 20 minute proceedure.
Posted on Jun 11, 2011
How do you reset the alarm system on a 98 olds silhouette after it triggers without the remote entry
Theft Deterrent Arm/Disarm Modes
Important: Although mode 2 provides increased security, the content theft deterrent system disarms only by pressing unlock on the keyless entry transmitter. This can pose a problem if the keyless entry transmitter is damaged, lost, or inoperative for any reason while you attempt to disarm the content theft deterrent system.
Mode 1: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter. The system does not arm when you lock the doors with a power door lock switch.
Mode 2: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the doors with the keyless entry transmitter. The system does not disarm when you unlock the doors with the key.
Mode 3: The system arms when you lock the doors using a power door lock switch or the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter.
Changing the Feature Customization Modes
  1. Turn off the IP dimmer switch.
  2. Turn the ignition switch to the LOCK position.
  3. Remove the BCM PRGRM fuse.
  4. Turn the ignition switch to the ACC position. The BCM flashes the fasten belts indicator and sounds the chime 4 times, which indicates that BCM type 4 is installed on the vehicle. At this point, the BCM has entered the feature customization mode.
  5. In order to change the theft deterrent/shock sensor mode, turn the headlamp switch from OFF to PARK and back to OFF.
  6. The BCM flashes the fasten belts indicator and sounds the chime a number of times equivalent to the theft deterrent/shock sensor mode. A transition past mode 4 repeats the sequence starting with mode 1.
  7. Complete the following steps in order to change the theft deterrent arm/disarm mode:
6.1.
Insert the key in the left front, right front, or liftgate door lock cylinder.
6.2.
Rotate the key from the center to the unlock position.
6.3.
Press the horn button on the remote keyless entry transmitter.
6.4.
Count the number of chimes that you hear. The number of chimes tells you which mode you have set.
6.5.
Press the horn button again in order to change the mode. Continue to press the button until you hear the number of chimes that indicates the mode that you want.
6.6.
Turn the key back to the center position and remove the key from the door key cylinder.
In order to exit and save the current feature customization modes use the following procedure:
  1. Turn the ignition switch to the LOCK position.
  2. Reinstall the BCM PRGRM fuse.
If you are unable to change locking modes Theft Deterrent System Feature Customization Inoperative
Aug 25, 2015 | Cars & Trucks
2011 volvo v60 keyless entry passenger door fails to open? any ideas? door module? allother doors operate ok
Try replacing the Battery in you Key Fob first, Check all your Fuses as well.
Dec 15, 2014 | Volvo Cars & Trucks
2008 cadillac cts key fob not working
Testing would need to be done , scan tool hooked up checking DTC'S - diagnostic trouble codes . View data etc...
Keyless Entry System Description and Operation - Active
The keyless entry system is a vehicle entry device. The keyless entry system is used in conjunction with the door locks to unlock the vehicle. Keyless entry will lock/unlock a door or open the rear compartment lid when a corresponding button on the keyless entry transmitter is pressed. This is accomplished by the transmitter sending a radio frequency to the remote control door lock receiver (RCDLR). The RCDLR interprets the signal and activates the requested function via a serial data message. A low transmitter battery or radio frequency (RF) interference from aftermarket devices, such as 2-way radios, power inverters, computers, etc., may cause a system malfunction. High RF traffic areas, such as gas stations that use pay-at-the-pump RF transponders, may also cause interference that could lead to a malfunction. Keyless entry allows you to operate the following features:
• Door lock/unlock
• Rear compartment lid release
• Illuminated entry lamps
• Panic alarm/Vehicle locator
• Remote vehicle start
Your best bet , take it to a qualified repair shop . Dealer
Feb 18, 2018 | 2008 Cadillac Cts
We have the thumb press elongated handle on the outside of the front door entry. I was ready to enter the front door when I pressed the thumb handle and the whole set fell apart. Need instructions to put...
For the Lido Keyed Entry, go to this page:
http://www.kwikset.com/Products/Details/Door-Levers/740LL-26D-SMT.aspx
and click on "Installation Guide", found under the red text " Technical Documents"
If I've steered you to the wrong lockset, the product main page foe Kwikset can be found here:
http://www.kwikset.com/Products/Categories/Handlesets.aspx
Feb 13, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
If i purchase 2 locks with 2 remotes, will the remotes work interchangeablely with the locks? I don't want to have to carry two remotes one for the back door and one for the front door. Thanks.
Not sure which lock you have but most Radio Frequency (RF) locks are programmed to recognize the remote (some as many as 15). So you would program each lock to remember your remote and this will allow you to use the same remote for both locks. Be careful about range though.. if you are using one lock on the front door and the other on the back do you will controlling both locks when you press the button. But if you are planning on each lock being at a different house then you will be fine.
May 06, 2010 | Morning Industries 3-in-1 Keyless Entry...
2000 Lincoln Towncar. Keypad on door will not unlock doors. Interior lights do come on. The last two keys pushed simultaneously will occasionally lock the doors. I am using the code printed on a sticker in...
The driver door module (DDM) is connected on the standard corporate protocol (SCP) communication network. The DDM controls many functions including power windows, power door locks and remote keyless entry. The DDM also communicates with the driver seat module (DSM) to control the power mirror and seat memory functions.
Do you know anything about automotive electronic control modules ?
The driver door module (DDM) receives inputs from the digital transmission range (DTR) sensor, ignition switch, seat switch, window/door lock switches, lighting control module (LCM), keyless entry keypad switch and remote transmitter. The DDM outputs consists of keyless entry keypad switch illumination, power door lock actuators, luggage compartment release solenoid, horn relay, and lighting control module (LCM).
Best thing to do would be to have a factory scan tool hooked up to check for DTC'S diagnostic trouble codes . That should be the first step if it's not programming the code.
  • The doors do not lock/unlock using the keyless entry keypad
  • Keypad.
  • Circuitry.
  • Driver door module (DDM).
  • GO to Pinpoint Test L .
PINPOINT TEST L: THE DOORS DO NOT LOCK/UNLOCK USING THE KEYLESS ENTRY KEYPAD CONDITIONS DETAILS/RESULTS/ACTIONS L1 RETRIEVE THE RECORDED RESULTS FROM BOTH CONTINUOUS AND ON DEMAND SELF TESTS Use the recorded DDM DTCs from the Continuous and On Demand self tests.
  • Are any DTCs recorded?
Yes For DTC B1525, GO to L3 .
For all other DDM DTCs, REFER to the DDM Diagnostic Trouble Code (DTC) Index.
No If the door locks are inoperative, GO to L2 .
If the keypad illumination does not operate, GO to L10 .
If the keypad illumination is on continuously, GO to L14 .
L2 CHECK THE DOOR LOCK OPERATION Check the door lock operation by depressing a door lock switch.
  • Do the door locks operate?
Yes GO to L3 .
No GO to Pinpoint Test E . L3 MONITOR THE DDM PID KEY_PAD
Scan tool
Monitor the DDM PID KEY_PAD.
  • Are any of the keyless entry keypad switch numbers present?
Yes GO to L4 .
No GO to L5 . L4 CHECK THE KEYLESS ENTRY KEYPAD SWITCH
Keyless Entry Keypad Switch C525
Yes If 1/2, REPAIR Circuit 78 (LB/YE). TEST the system for normal operation.
If 3/4, REPAIR Circuit 79 (LG/RD). TEST the system for normal operation.
If 5/6, REPAIR Circuit 121 (YE/BK). TEST the system for normal operation.
If 7/8, REPAIR Circuit 122 (YE). TEST the system for normal operation.
If 9/0, REPAIR Circuit 123 (RD). TEST the system for normal operation.
No INSTALL a new keyless entry keypad switch; for additional information, REFER to Keypad-Keyless Entry . L5 CHECK THE KEYLESS ENTRY KEYPAD INPUT WITH THE KEYLESS ENTRY KEYPAD SWITCH Monitor the DDM PID KEY_PAD, while depressing all the keyless entry keypad switches one at a time.
  • Are all the keyless entry keypad switches operating correctly?
Yes GO to L9 .
No GO to L6 . L6 CHECK CIRCUIT 797 (LG/VT) FOR VOLTAGE
Keyless Entry Keypad C525
Measure the voltage between keyless entry keypad C525-7, Circuit 797 (LG/VT), and ground; and between keyless entry keypad C525-8, Circuit 797 (LG/VT), and ground.
  • Are the voltages greater than 10 volts?
Yes GO to L7 .
No REPAIR Circuit 797 (LG/VT). TEST the system for normal operation. L7 CHECK THE KEYLESS ENTRY KEYPAD SWITCH INPUT While monitoring the DDM PID KEY_PAD, momentarily connect a fused (7.5A) jumper wire between positive battery post and keyless entry keypad switch C525 as follows:
    Keypad Button Keyless Keypad Switch C525 Circuit 1/2 Pin 3 78 (LB/YE) 3/4 Pin 4 79 (LG/RD) 5/6 Pin 5 121 (YE/BK) 7/8 Pin 6 122 (YE) 9/0 Pin 1 123 (RD)
  • Are all the keyless entry keypad switch inputs operating correctly?
Yes INSTALL a new keyless entry keypad switch; for additional information, REFER to Keypad-Keyless Entry .
No GO to L8 . L8 CHECK THE KEYLESS ENTRY KEYPAD SWITCH CIRCUITRY FOR AN OPEN
DDM
Measure the resistance between keyless entry keypad switch C525 and DDM as follows:
    Keyless Keypad Switch C525 DDM Circuit Pin 3 C521 Pin 8 78 (LB/YE) Pin 4 C521 Pin 13 79 (LG/RD) Pin 5 C521 Pin 16 121 (YE/BK) Pin 6 C520 Pin 24 122 (YE) Pin 1 C520 Pin 25 123 (RD)
  • Is the resistance less than 5 ohms?
Yes INSTALL a new DDM; for additional information, REFER to Section 419-10 . TEST the system for normal operation.
No REPAIR the circuit in question. TEST the system for normal operation. L9 CHECK THE KEYLESS ENTRY KEYPAD BACKLIGHT Depress a key on the keyless entry keypad.
  • Does the keypad illumination operate correctly?
Yes INSTALL a new DDM. For additional information, REFER to Section 419-10 . TEST the system for normal operation.
No If the keypad illumination does not operate, GO to L10 .
If the keypad illumination is on continuously, GO to L14 . L10 CHECK THE KEYPAD - DDM ACTIVE COMMAND KEYPAD BACKLIGHTING LIGHT ON AND OFF Trigger the DDM active command KEYPAD BACKLIGHTING LIGHT ON and OFF.
  • Does the keypad illumination turn off and on?
No GO to L11 . L11 CHECK DDM GROUND - JUMPER CIRCUIT 66 (LB) TO GROUND
DDM 522
Connect a fused (7.5A) jumper wire between DDM C522-4, circuit 66 (LB), and ground.
  • Does the keypad illuminate?
No GO to L12 . L12 CHECK CIRCUIT 51 (BK/W) FOR OPEN
Measure the voltage between keyless entry keypad C525-7, circuit 797 (LG/VT), and ground; and between keyless entry keypad C525-8, circuit 797 (LG/VT), and ground.
Yes GO to L13 .
No REPAIR circuit 797 (LG/VT). TEST the system for normal operation. L13 CHECK CIRCUIT 66 (LB) FOR OPEN Measure the resistance between keyless entry keypad C525-2, Circuit 66 (LB), and DDM C522-4, Circuit 66, (LB).
No REPAIR Circuit 66 (LB). TEST the system for normal operation. L14 CHECK THE KEYPAD ILLUMINATION - DDM DISCONNECTED
DDM C522
  • Does the keypad illumination turn off?
No GO to L15 . L15 CHECK KEYLESS ENTRY KEYPAD FOR SHORT TO GROUND
Yes GO to L16 .
No INSTALL a new keyless entry keypad switch. For additional information, REFER to Keypad-Keyless Entry . TEST the system for normal operation. L16 CHECK CIRCUIT 66 (LB) FOR SHORT TO GROUND Measure resistance between DDM C522-4, circuit 66 (LB), and ground.
  • Is resistance greater than 10,000 ohms?
Yes System OK. CLARIFY the concern with the customer.
No REPAIR circuit 66 (LB). TEST the system for normal operation.
Nov 03, 2017 | Lincoln Town Car Cars & Trucks
2001 subaru impreza WRX unlocking doors with key
usually after opening the door you can deactivate the alarm by pushing th unlock button or simply insert keyy in ignition and turn it on.
Aug 13, 2009 | 2001 Subaru Impreza
Keyless entry on honda civic 2006 not working
The keyless entry is designed to work with the doors closed (closed - not locked). If the door ajar sensor thinks the door is open the keyless entry is disabled. When you manually lock the door it might tighten the door just enough to activate the keyless entry. I would try slamming all the doors closed and then see if the keyless entry works. If it still wont work have the wiring checked on the front door lock.
May 12, 2009 | 2006 Honda Civic Hybrid
Key Pad Entry does not work
does the key pad light when you press a button at night? If yes, the fuse is ok.
Do you have the plastic card with the permanent code in your owner manual packet? If yes, tryit.
report back.
Keyless Entry The keyless entry keypad is hardwired to the GEM. The GEM interprets the inputs from the keyless entry keypad and then controls the associated operation. The keyless entry keypad will be illuminated for five seconds when any button is pressed. Additionally, it will request the illuminated entry feature to turn the courtesy lamps on. If a lock all doors code is entered, the illumination will turn off, as well as request the illuminated entry feature to turn off the courtesy lamps. When pressed, the keyless entry keypad supplies the ground signal to the GEM or the GEM receives a signal from the keyless entry remote transmitter. Then the GEM outputs a ground signal to the appropriate lock or unlock relay which supplies the power to the actuator to lock or unlocks all doors, including the luggage compartment. The keyless entry remote transmitter also unlocks the liftgate or activates the panic alarm by sending a signal to the GEM.
--------------------------------------------------------------- Visual Inspection Chart Mechanical Electrical
  • Keyless entry keypad
  • Keyless entry remote transmitter
  • Central junction box (CJB) Fuse F222 (20A)
  • Circuitry
  • Generic electronic module (GEM)
  • No communication with generic electronic module (GEM)
  • Generic electronic module.
  • Circuitry.
  • REFER to Section 419-10 .
Mar 08, 2009 | 2003 Ford Taurus
Need to have a master key for all locksets
Any locksmith can rekey the locks to a single Master. Some make house calls, but it costs less to take them off and take them if this is feasible.
Mar 01, 2009 | Kwikset 907 907-15 Satin Nickel Smart...
Locks & Locksmithing Logo
125 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
