Question about Crock Pots & Slow Cookers
I require a gasket for a stove top pressure cooker type pc 02, 8 inch, 3.5 ltr
2 Suggested Answers
  • 8 Answers
SOURCE: Can you get me a manual
Try this link
Posted on Apr 28, 2015
Testimonial: "Thanks but not there."
Where can i buy a tower 6 ltr pressure cooker model number 13534 gasket seal?
That part is no longer available at any of the major spares suppliers.
Aug 05, 2017 | Crock Pots & Slow Cookers
Looking for manual for the Farberware 7 in one programmable pressure cooker
pressure cooker manual & recipe booklet library ' hip ...
Free downloadable copies of pressure cooker instruction manuals for stove top pressure cookers, ... Farberware Quick Cuisine Pressure Cooker Recipe Booklet.
FARBERWARE FCP412 USE & CARE INSTRUCTIONS ... > Brands > Farberware Manuals > Coffee Maker
View and Download Farberware FCP412 use & care instructions manual online. ...Salton use & care instruction programmable coffeemaker fcm12ss (12 pages) ... TOLL FREE: 1-888-881-8101, Monday - Friday, 7:30 a.m. - 6 p.m. CST Please ...
Farberware 6-Qt Digital Pressure Cooker -
Jan 01, 2016 | Crock Pots & Slow Cookers
For What????
Make & Model?
Here is a user manual from Presto....
Apr 28, 2015 | Crock Pots & Slow Cookers
Where can i find a manual for ultrex pressure cooker?
The company had a major recall and went out of business. No manuals appear to be available on the web.
Here are some general instructions you can use:
1 Set up your cooker. Place your Ultrex Pressure Cooker on the stove. Remove the lid and pour in no more than 2 inches of water. Depending on what you are cooking the amount of water will vary. More water will ultimately cook larger amounts of food, but you will need to refer to your specific model's instructions on this matter.
  • 2 Put in the food you wish to cook. Close and lock the lid firm to the pot. Make sure it is locked securely so none of contents boil out of the top.
  • 3 Turn on your burner to high heat for approximately ten minutes. Allow the water to boil.
  • 4 Turn the stove down to a low setting after the water is boiling in the cooker. Flip the pressure valve closed and allow your food to simmer.
  • Set the pressure valve to ten pounds. For vegetables, cook 30 to 45 minutes. For meats, cook 45 to 60 minutes.5
  • 6 Open the pressure valve and allow the pressure to discharge. Unlock and remove the lid to find your fully cooked meal.
  • Aug 25, 2014 | Ultrex Crock Pots & Slow Cookers
    Se e4 on my cooker what do i do
    The problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. Mine doesn't have a pressure problem it just goes to E4 once you set the time. I gave the switch a good smack and it has been working for a while. This is the second time and this worked both times now. I am sure the switch will have to be replaced at some time. From what I have seen this is a very common problem. There is one way to fix this problem, albeit not the best. I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this. The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook. Pics of process:
    Jul 21, 2014 | Wolfgang Puck 5-Quart Electronic Pressure...
    Displays E2 and E4 (5 qt Wolfgang Puck pressure cooker - silver) what section is problem mechanical or electronic?
    I think E2 means open circuit in thermocouple in center of bottom. E4 means no contact on pressure sensing switch at edge of bottom. Mine had E4 error. Took out switch and used fine sandpaper to clean contact points. Now it works fine.
    Remove 3 screws in bottom. Remove bottom cover by turning it ~1/4" to clear tabs. Remove switch at edge of bottom with two blue wires going to it. Clean contacts and replace.
    Jul 10, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
    Displays e4 wont work
    Removed the 3 screws on the bottom. There is a relay near the circuit board. Kind of looks like an old morse code relay. Just tapped out "E 4" in morse code. Plugged it in and it works fine.
    May 13, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
    I have lost my manual that came with the pressure cooker. Can I order a new one.
    I have my manual. There's not much to it, but I could copy it and send it if you could provide me a replacement gasket for the inside of the lid. It's a little white donut shaped gasket...
    Mar 20, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
    I have a Rise 'n' Time Stainless Steel Prestige Cooker
    I too have this cooker and the rise part never rises, I find that I have to hold the handles in such a way as to help it reach pressure and then the little pin rises.You have to have the cooker gauge pointing to the left.
    Dec 02, 2009 | Crock Pots & Slow Cookers
    Crock Pots & Slow Cookers Logo
    46 people viewed this question
    Top Crock Pots & Slow Cookers Experts
    Irene Tulloch
    Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
