Question about Sharp Office Equipment & Supplies
How to enter service mode on sharp mx 4112 - Sharp Office Equipment & Supplies
  • 148 Answers
SOURCE: Service Mode On Sharp SF2530
A little rusty on this machine, but try this.
This code means you have had to many paper jams in the fuser without removal. Make sure all is clear in the fuser and exit sections.
Then on the control panel you will press a series of buttons as follows.
Press the Clear, Press interrupt, Press Zero, Press interrupt, Enter # 14, Press start, That should reset the machine...
Hope that helps...
Posted on Jul 02, 2008
i don no
Posted on Jul 08, 2008
SOURCE: Sharp service code H5-01
To enter simulation mode to reset errors enter this sequence on keypad.
P, * , CA , P then enter sim # 14 to reset code.
press " custom settings" button to return to previous menu and CA to exit sim mode.
Posted on Dec 11, 2008
  • 257 Answers
SOURCE: how i can enter in service mode of sharp AR 5316
On the panel display, press #, interrupt,0, interrupt keys in that order. Display will go off then enter the desired number and press Print. If the command has subcode, enter it and press Print to execute.
Posted on Nov 13, 2009
  • 210 Answers
SOURCE: how to enter service mode on Sharp GD8 LCD TV
put tv in standby and press and hold vol down and mode(input) and press power the tv will come on with service menu
Posted on Dec 18, 2009
Sharp mx-m264n how to enter simulation mode
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
"#" key "INTERRUPT" key "C" key "INTERRUPT"
Sep 14, 2015 | Sharp Office Equipment & Supplies
Sharp MX-3100; what does DK mean
h r u . DK MEANS black drum life is over need to replace black drum unit or Reset black drum unit counter.
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code07
Then you can select what you want to clear so the bk drum unit
Feb 26, 2015 | SHARP MX-3100N
How enter sin simulation mode in sharp MX-M354N
To enter simulation mode you need to press the following 4 buttons in quick succession:
# * C *
The # & * keys are to the left & right, respectively, of the zero key,
the C key is the red C to the right of the number 3 key.
Hope this helps
Jan 14, 2015 | Sharp Mx-M354n Mfp
We have a code h4-30 on a sharp mx-2700n how do I reset?
You need to make sure the machine is in Copy Mode when you hit
# * C *
enter 14, then touch start
execute on the screen
the machine will reboot and the code should go away.
If it persists you may need some maintenance. If you're in Houston give us a shout. Our labor rates are low compared to the other Sharp dealers in Houston.
Skelton Business Equipment Houston Copiers
Jul 07, 2014 | Sharp MX-2700N Color Copier
How to clear an service error code on a sharp printer?
try turning the machine off then on. if that doesn't work, from copy mode type # * C * to go into service mode (test: enter a simulation). Clear codes 14, 15, 16, 17. type the number then hit the start key. then CA to reboot, you must try the codes on at a time. Please report what your error code was.
May 29, 2014 | Sharp MX-3501N All-In-One Printer
TA code. After reading your previous questions, I am trying to follow how to clear this code but don't understand your proceedures. it says you want # , 8, c * To enter service mode So.....where do...
To get to service mode, press the # key, the * (star) key, the C (clear) key, then the * (star) key again in rapid succession. This will bring you to the service (simulation) mode.
Nov 03, 2010 | Sharp MX-2700N Color Copier
Sharp MX-2300N Maintenance required.code:TA
Maintenance TA is indicating the machine has reached its 100K scheduled service interval. It requires Transfer Belt Unit, Usually Black Drum & Developer, any feed rollers wornout replaced, any old firmware updated to latest version, and a general clean & check. It is reset in service mode once these parts are replaced.
Dec 23, 2008 | Sharp MX-2300N Color Copier
Dec 10, 2008 | Office Equipment & Supplies
52 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
