Question about Acer Tablets & eReaders
I have an ACER Iconia W4, and only kne half of the screen is working, ie: when I touch the screen only one half works
2 Suggested Answers
revrlhoward
  • 7 Answers
SOURCE: how do I start acer iconia in safe mode
Hold the power button in for the count of ten, it should shut it down and cause it to ask you to boot up in safe mood, it may take a couple of tries but it will eventually go to a menu to ask for the boot mode....I recommend spyhunter4...I just removed that virus from a clients pc two days ago
Posted on Oct 12, 2012
8.1 tablet. How do I replace cracked screen?
Amazon.com: Acer Iconia Tab W3-810 8.1" Touch Screen ...
www.amazon.com > ... > Chargers & Adapters
Amazon.com, Inc.Amazon.com: Acer Iconia Tab W3-810 8.1" Touch Screen Digitizer Panel Repair Partreplace: Computers & Accessories.
Sep 09, 2015 | Acer Tablets & eReaders
Tip
Acer Iconia B1-A71 - Touch Screen problem - how to resolve it
Very often problem with this model. In 60% it can be resolved only with reconnecting the Touchscreen flex / ribbon cable (If the Touchscreen is not broken of coerce (: ) .
If this solution not helped you then you must to change your Touchscreen.
on Aug 29, 2014 | Acer Iconia B1-A71 7" 8 GB Wi-Fi Black...
Ive had the screen replaced on my Acer tablet but now screen is cloudy. Is there something that I need to reset?
Cloudy in what way? Is the display distorted or does it just lack brightness? You could try changing the resolution but if a cable was not seated properly when the unit was reassembled, no amount of setting adjustments are going to fix it. Did the technician show it working before you paid for the repair?
Jul 05, 2015 | Acer ICONIA B1-711-83891G01nw 16 GB Tablet...
Hang
Sounds like corrupted software. Re-install the software. O/S. Gopakumar Gopalan Google
May 21, 2014 | Acer Iconia W4-820 8" Tablet - 64GB
Everything works perfectly fine except the screen is unresponsive to my touch yet jumps and presses things on its own
there is a problem with the touch sensitivety to the screen if it keeps happening contact tech support and tell them if they can not fix the problem they will more than likely give you a new tablet in return for the old one after you recieve the new one only if the tablet is still under the usual one year warranty.
Nov 10, 2013 | Acer Aspire Iconia Tab A100
Acer iconia a500 tablet freezes at the boot screen and does not go any further
The following info from
http://community.acer.com/t5/Tablets/Iconia-A500-frozen-at-Acer-logo-boot-screen/td-p/7171/page/28
might be helpful:
"How do I perform a Factory Data Reset if my Acer ICONIA TAB A500 does not boot?The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.
1.Power off the tablet.
2.Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3.With the Volume up button held, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
4.Once the tablet vibrates, switch the touch screen lock switch on and off repeatedly while still holding the Volume up button.
5.Release the Volume up button and stop switching the touch screen lock switch once the "Erasing Userdata..." message appears in the upper left corner of the screen.
6.Once the factory reset has been completed your tablet will load to the Welcome screen. 7.Your Factory Data Reset has completed now follow the onscreen steps to setup your tablet."
Good Luck!
Oct 18, 2013 | Tablets & eReaders
My acer iconia android tablet refuses to startup
Perform a Factory Data Reset of Acer ICONIA
The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.1.Power off the tablet.
Aug 24, 2013 | Acer ICONIA Tab W500PC52G03iss
How do I start acer iconia in safe mode
Oct 12, 2012 | Acer Iconia TAB W500-BZ467 10.1 inch AMD...
I forgot my password on my acer tablet and tried to do a factory reset but it didnt work what should i do????
Acer A510 Tablet, Forgot Password - This is from a Acer Tech and it works for this Model, good chance its the same for most Acer Tablets.
While OFF, Hold the POWER ON button in while also Holding the VOLUME BUTTON down at the same time and then slide the SCREEN ROTATION LOCK BUTTON back and forth about 20 times, then let go off all buttons and wait about a minute, don't touch anything during this period, it will then come back on, now is a good time to go to settings and
Aug 22, 2012 | Acer Iconia Tab A200-10g16u XE.H8QPN.001...
Tablets & eReaders Logo
Top Acer Tablets & eReaders Experts
Nicola Conroy
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
