Ricoh Aficio AP3800C Laser Printer
Problem for Ricoh Aficio AP3800C Laser Printer
Waste toner is almost full on Ricoh aficio AP3800C
By schreckie on Jul 25, 2009
I just need to know how to change the toner bottle, or any tricks to get this error to go away. Thank You!
Best Solution
posted on Jul 27, 2009
Very Helpful)
quennie732
Rank: Guru  Ricoh Expert
Rating: 86%, 59 votes
open front door. lower left empty the waste toner. -carl
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Aug 30, 2009
Not Rated)
bphils
Rank: Master
Rating: 72%, 4 votes
turn off the printer and open the front door and check at the left corner of the lower part you will see a white can slip it gently out to where there is no fire and gently pour the waste out from a hole out may into a bag and dispose there after replaced the can to its position, close the printer and turn it on again.
Was this helpful?
Yes
No
Solution #3
posted on Aug 01, 2009
Not Rated)
alandbond
Rank: Apprentice
Rating: 0%, 0 votes
Open the main front cover and you will see the white plastic waste toner bottle on the left hand side halfway up. I lies on its side and you can see the bottom of it.
Slide it out gently keeping it level to avoid spilling all the waste toner.
Either replace with a fresh empty waste bottle or empty the bottle into a large plastic bag you can keep sealed with the bottle inside while you shake it.
You have a good chance of spilling the toner all over your clothes if you are not carefull and note that the waste toner IS HIGHLY INFLAMMABLE so no naked flames nearby!!
Was this helpful?
Yes
No
Popular Solutions for Ricoh Aficio AP3800C Laser
Questions and Unsolved Problems for Ricoh Aficio AP3800C Laser
Do you recommend Ricoh Aficio AP3800C Laser Printer?
Answer
Answer
how do i install wireless ricoh africio ap38000c pcl 5c
Answer
The soft buttons wont react when I am in Scanner mode, Printer and Copy modes work fine.
Answer
i have a savin c3030 and its giving me the error code sc400. what it is?
Answer
Each time I try to print from WordPerfect to the printer, I must set the paper size to 8.5 x 11. For... (More)
Answer
Hi I've got an Ricoh Aficio CL3800 which has started printing black marks (small dots) each dot is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ricoh Aficio AP3800C Laser...:
Top Printer Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
