Question about Stihl Garden
My stihl 250 the spark plug keeps oily up - Stihl Garden
  • Stihl Master
  • 10,873 Answers
Too much oil in the gas.always measure
Posted on May 17, 2017
Part # for spark plug wire on stihl saw model ms 180 c
spark plug wires on small engines are normally part of the coil so you may have to get a new coil pack
talk with stihl service parts or service shop
Jul 30, 2016 | Stihl Garden
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
Jul 30, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
Stihl chainsaw MS460 Can't pull recoil
It could be the recoil is stuck. a couple of things to check. Take the clutch and chain cover off, remove the spark plug and manually try to turn the motor over by turning the clutch. If the motor/engine is not seized, take the pull start/recoil cover off and pull on the cord to see if it will work and that the cord returns back into the recoil automatically. Don't take the nut off the inside of recoil holding the cord spool on. If the engine is not seized, and the recoil now goes in and out by pulling the start cord handle reassemble and pull over the engine a few times. This a good time to check the spark plug is working, now put the spark plug back in and start the engine. It's a good time to clean the air filter as well while the chainsaw is mostly apart and clean all oily sawdust off the chainsaw in the crevices etc..
Jun 05, 2014 | Stihl Chain Saw Handle Models 044 046...
What is the spark plug gap on a MS210?
According to page 62 in the Stihl user manual:
Spark plug (resistor type): Bosch WSR 6 F
Electrode gap: 0.02 in. (0.5 mm)
http://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/STIHL-MS-210-230-250-Instruction-Manual.pdf
Apr 28, 2014 | Standard Oregon Chainsaw Chain For Stihl...
GOT A STIHL OIOAV NOT RUN GOT SPARK
if the plug keeps getting to wet to fir then check for spark if you have spark then clean the carb
Aug 13, 2012 | Stihl Garden
Stihl 025 starts but cuts out have replaced spark plug and new carb
check the spark arrester screen in the muffler. if they stop up it will run like it has
no power and will stall
Oct 29, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Can not start the ms180 chain saw, tried new plug, new gas, starting fluid etc. suggestions ran this morning, and now will not start. only been used twice
Remove the plug and then plug into plug wire. With the spark plug laying on top of engine pull the recoil a couple times and you should see spark at the plug. If all is good and there is the proper mixture of gas/oil ratio in saw then >>With trigger depressed fully and choke on, pull until it fires and then shove the choke in. /////If no spark and the saw is new, I would return to retailer.
Sep 25, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
I got blue smoke coming out of my tail pipe on 200 xr honda 4 stoke dirt bike
This is engine oil burning ,I bet it smells oily. The valve guide seals under the rocker cover are worn ,or the piston rings are worn and poss the bore on such a old bike this is common. If you have little money just keep going ,the spark plug will eventually fail, Or you will need to restore your engine with a strip and rebuild.New seals, rings and check bore piston tolerance .
Mar 03, 2010 | 1987 Honda XR 250 R
Need alternative spark plug for stihl hs81r
STIHL recomends a Bosch USR-7AC
Nov 23, 2009 | Garden
Stihl ms 250 chain saw won't start, doesn't seem to catch spark.
dry the plug asmall squirt of aerostart in the top of carbywith air cleaner off full throttle pull the rope and she should fire up make sure the on/off switch is in the correct position. no don`t laugh ican remember nearly completely stripping amotor years ago before ichecked it put it all back together and it started first go try the aerostart and switch
Aug 03, 2009 | Garden
Garden Logo
42 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
