My plotter just goes on and do nothing else - Office Equipment & Supplies
Plotter will not print
Check lan card led blinking pattern., Replace lan card(Jetdirect card 620n) & check, mostly lan card issue might be there..
Jun 12, 2015 | HP DesignJet 5500PS InkJet Printer
I have access to a 450 plotter but it does not seem to be working. Not sure who may have used last. Turned it on and it goes through all diagnostics and then all 3 leds in the error group are on solid....
It will probably be useful to interpret the error light pattern. Download the service manual and match the pattern and get a starting point to diagnose the problem. The manual can be downloaded from: www.lpscomputer.com/ec/manuals.htm
Feb 22, 2010 | HP DesignJet 450c InkJet Printer
Data & cartriege light on
the problem is caused by the TRAILING CABLE (RIBBON CABLE THAT GOES FROM CARRIAGE ASSY TO MAIN LOGIC BOARD)
REPLACE IT AND YOU WILL HAVE A LIKE NEW WORKING PLOTTER.....CHEERS.
Sep 13, 2009 | HP DesignJet 430 InkJet Printer
HP 7585B Plotter boot problem
so sorry to hear about your issues with you hp 7585b. I would like to know if you were able to correct the problem. If not I would be interested in purchasing the carosels off your machine. Please contact me at rsizod at yahoo. I would apreciate a call back thanks.
Sep 02, 2009 | HP (7585b) Printer
HP 750c+ plotter not responding
turn and unplug for 30 secs then open and remove / re-install each ink barrel according to your manual. You will have to go through the ink installation on your keypad one by one.
Apr 28, 2009 | HP DesignJet 750c plus InkJet Printer
Partial plot
if connected via ethernet cable then i believe you have a bad network card, if connected via parrallel, then check to make sure the cable is not over 15 feet in length. also try to uninstall and reinstall the drivers on your computer as they sometimes become corrupt. Good luck!
Aug 17, 2008 | HP DesignJet 750c plus InkJet Printer
Request for designjet plotter info
my hp 450c plotter works properly in vista. First I' ve tried unsuccesfully to add new printer through windows menu. Then through Autocad menu (plotter manager) I added the specific plotter.
Jul 09, 2008 | HP DesignJet 450c InkJet Printer
450c Plotter apparently dead
Check the cable connections, and the cable connector inside the plotter. Make sure your cables are good.
Dec 29, 2007 | HP DesignJet 450c InkJet Printer
k24674
jasbo
jasbo
