Question about Dryers
Defy tumble dryer dtd258.Selected 40mins,knob never rotated.Stopped it after 40mins.How does 10min cooling period work.Is this in add to the 40mins,would it have stopped on its own after 50mins.
  • 139 Answers
SOURCE: Defy Tumble dryer not heating
Is this an electric dryer? If so, the most common problem would be a burned-out heating element. There could also be a defective temperature sensor inside. This will need to be evaluated by a qualified appliance repair technician to find the exact cause.
Posted on Jan 18, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool Dryer Motor Removal
stand that baby up!!! acess is from front, try removeig 2 screws from under lint filter and then pop top with screw driver lean top back.. youll see the tub and belt(if not broken right there),no belt??? order a 341241 whirlpool dryer belt. 2 5/16screws on either side of iside facade remoivefront caver, disconnect door switch and remove front panel. belt slips over drum , you need to reset tension pulley and wrap around motor shaft. .
Posted on Feb 26, 2008
gittos73
  • 244 Answers
SOURCE: Zanussi Tumble Dryer Model TC7103W ** Heat
have u changed the thermostats if not change these these r what let the heater element get warm if this then works then the element u changed will more then likely be OK m8
Posted on Mar 10, 2008
  • 172 Answers
SOURCE: Tumble dryer not heating
Hi irshaad,
If all the componants are good, you are loosing voltage somewhere. Check the voltage to the dryer. If you do not have 220 volts then you have a blown fuse or a kicked breaker in your fuse box. This would allow only 110 volts to get to the dryer and the dryer would run and not heat. If you have the correct voltage to the dryer check the connections on the terminal block and the wires to the block. Before going any further than that I would really rather have your model so I could guide you correctly. Good luck and I really hope this will FixYa.
Mike Anderson
Posted on Jun 03, 2008
  • 66 Answers
SOURCE: Dryer is working but wont tumbel
This does sound like the belt has broken. Is the Defy autodryer the one that made the sound and then stopped tumbling?
Posted on Nov 12, 2008
How long after the chime and cool down period should the dryer cut off.
most timer havea5min are 10min cool down cycle u can time the cycle
Sep 24, 2015 | Frigidaire FAQE7001LW Dryer
How do you get the water to drain in the Malber WD100 washer/dryer combo?
Hi. I''m assuming you are referring to a WD1000.
To initiate the drain cycle: Rotate far right knob CLOCKWISE to Position 4. It may take 30-45 seconds to recognize the knob's new position, but then it will begin an 11 minute Slow Tumble/Pump Out cycle. During this cycle you'll see the internal drum slowly rotate CW for 60 seconds, pause, then rotate CCW for 5 secs - then repeat. All this time the pump will run and you'll hear water running down the drain. When you hear no more water you can rotate same knob to "straight up", and stop the machine. To turn power off, press the rightmost button.
Sep 21, 2014 | Malber WD1000 Front Load Washer/Dryer
I've bought a Defy Autodry tumble dryer, but the black "rubber" on the door keeps coming out, which then pushes the door open, and the machine then automatically stopped. Can i just replace...
A TUBE OF CONTACT CEMENT WORKS WONDERS ON THE SEALING RUBBER - JUST FOLLOW THE INSTRUCTIONS ON THE TUBE . IF ITS GOOD ENOUGH FOR DOOR SEALS IN THE AUTOMOTIVE INDUSTRY ITS GOOD ENOUGH TO HOLD YOUR DOOR SEAL IN PLACE - GOOD LUCK.
Jul 26, 2011 | Dryers
Blinking AD
AD is auto dry you may need to clean the sensor or you may have a fauilty one ...Auto Dry Loads dried using the Towels, Heavy Duty, Normal, Perm Press, and Delicates cycles will dry automatically at the selected temperature to the desired dryness level. The dryer uses sensing bars to sense the moisture level of the load as it tumbles through heated air. Auto Dry cycles save time and energy and protect fabrics. The estimated drying time will be displayed for about 5 minutes, then the outside of the display will light up in a circular track to indicate the drying time is automatically being determined by the sensors. When the load has reached the selected dryness level, it will continue to tumble, unheated, during a Cool Down period. This helps reduce wrinkling and makes items easier to handle during unloading. The estimated Cool Down time will be displayed. Drying time varies depending on size and dampness of load and fabric type. If the load is too small or almost dry, the sensing bars may not detect enough moisture to continue the cycle and the cycle may end after a few minutes. Select a Timed Dry setting to dry such loads. Room temperature and humidity, type of installation and electrical voltage or gas pressure can also affect drying time. For cycle selection turn the knob on the front of the dryer control panel. The light will illuminate next to the cycle selected. The following is a brief description for what cycles should be chosen for certain items and materials to be dried.
Sep 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Jul 28, 2009 | Kenmore 73952 Gas Dryer
Dryer not heating
  • There are two house circuits/fuses in an electric dryer's circuit.
    If one of them is tripped/blown, the drum may turn, but the heater will not operate. Reset the circuit breaker or replace the house fuse.
  • Outlet wired incorrectly.
    Have a qualified electrician verify that the supply voltage is correct.
  • Gas supply valve to a gas dryer is not open.
    Open the gas supply valve. See Installation Instructions for details.
  • LP gas supply tank is empty or there has been a utility interruption of natural gas.
    Refill or replace the LP tank. Call your natural gas utility company.
  • Dryer does not have enough air supply to support the gas burner.
    The dryer needs space around it for proper ventilation. Do not stack or place laundry or throw rugs against the front or back of the dryer. See Installation Instructions for details about installing a dryer in a closet or alcove.
  • Incorrect cycle or temperature has been selected.
    If the Air Fluff cycle or temperature is selected, the dryer will tumble without heat. Each cycle ends with a Cool Down period during which the load tumbles without heat. Check the location of the indicator on the Cycle Selector knob.
Jan 08, 2009 | Frigidaire Dryers
Nov 11, 2008 | Dryers
Dryers Logo
27 people viewed this question
Top Dryers Experts
