The initial installation was sucessfull. but after several days I needed to access the e-manual I encountered the following problems. The same e-manual appeared but with a slight difference I could not directly acccess ex. scanning without entering the CTRL button and click. When this was done I received the following message. THE OPERATION HAS BEE CANCELLED DUE RESTRICTION IN EFFECT ON THIS COMPUTER PLEASE CONTACT YOUR SYSTEM ADMINISTRATOR. ACTION: RE-INSTALLED PROGRAM OUTCOME: SAME
  • fred_kolowra Jul 25, 2009
    Operating system is Windows EP. the machine is new but need more help.I was told that I,m not logged in a adminstative account.
    now how can I fin or acces an administative account
  • 1,555 Answers
Mr fred Kolowra,
Welcome to fixya,
May I know which installation you are talking about Win XP or Vista. When exactly you were asked to access thee-manual. Is this a new machine or old.
Posted on Jul 25, 2009
  • 1 more comment
  • Aruna Singh
    Aruna Singh Jul 25, 2009
    Mr fred Kolowra,
    This is not a good situation for me cause I have wasted a lot of time in searching your thread. It seems you have not gone through fixya terms of conditions properly. Once you accept the solution your expert can't reach you. Anyways Kindly let me know whether this is your own PC or your organisations. If this is your own then you are the administrator and I'd like to inform you that you have a very critical virus which is not easy to clean. Can you give me an hour of yours for cleaning it.
  • Aruna Singh
    Sorry for the inconvenice Mr fred_Kolowra,
    But you yourself invited the inconvenice. You shall never accept the solution unless you have solved your problem. Once you accept the solution. Even the Expert cannot reach you easilly. It took a lot of effort from me to reach you. I'll provide you the link through which you can reach me and till now I've not recived your answeres just your acceptence closed the window.
    http://www.fixya.com/PostComment.aspx?th...
  • Aruna Singh
    Aruna Singh Jul 26, 2009
    Mr fred Kolowra
    This is the first time in my life that I'm hearing of this operating system Win EP. I will take it as win XP if it is a typo and give you the step by step proceedure of resolving your proble. In any case if in real you are using win EP then kindly do enlighten me I'll dig out your solution for EP.
    1. Place your Windows XP CD in your cd-rom and start your computer (it’s assumed here that your XP CD is bootable – as it should be - and that you have your bios set to boot from CD)
    2. Keep your eye on the screen messages for booting to your cd Typically, it will be “Press any key to boot from cd”
    3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
    4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
    5. The Licensing Agreement comes next - Press F8 to accept it.
    6. The next screen is the Setup screen which gives you the option to do a Repair.
    It should read something like “If one of the following Windows XP installations is damaged, Setup can try to repair it”
    Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
    7. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
    8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically – you will see a progress bar stating “Your computer will reboot in 15 seconds”
    9. During the reboot, do not make the mistake of “pressing any key” to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
    10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
    11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
    12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you’ve made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
    13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
    I tested the above on Windows XP Pro with and without SP1 and also used this method in a real situation where someone could not remember their password and it worked like a charm to fix the problem. This security hole allows access to more than just user accounts. You can also access the Registry and Policy Editor, for example. And its gui access with mouse control. Of course, a Product Key will be needed to continue with the Repair after making the changes, but for anyone intent on gaining access to your system, this would be no problem.
    And in case you are wondering, NO, you cannot cancel install after making the changes and expect to logon with your new password.
    Cancelling will just result in Setup resuming at bootup and your changes will be lost.
Hi there... i bought asus P5G41T-MLX3 last february and this august i encountered problems.. first, the audio was lost then the following day my mouse which was attached on usb port at the back of my unit...
You maybe having spikes on the mains supply that is causing your computer to malfunction.
Connect a surge protection power board to the main outlet and then connect all your computer equipment to the surge protection power board.
A better and more expensive solution is to purchase an Uninterrupted Power Supply and plug all your computer equipment into this UPS. Make sure the UPS has the KVA rating that supports the power requirements of your computer equipment plus a spare capacity for any future needs.
Sep 07, 2012 | ASUS P5G41T-M/CSM Motherboard
In trying to install various versions of Adobe Reader on Windows XP SP3, I get the following error message: "Installation encountered errors; failed to initialize." I get this message on...
Yo! I will have to direct you to a website where you can download anything for your computer.i advice you download another one from here. please follow the link below..
www.download.com
Jul 27, 2011 | Computers & Internet
Can not remove CreataCard Gold from my Dell E310 Computer running Windows XP. Keep getting a window with the following message - An installation support fiel C:\Docume-1\Bill...
If you have tried using the "Add/Remove" or the uninstaller from the software itself and cannot uninstall the program. Reinstall the program again and unistall it.
If it is not sucessfull, then
Try using the System Tools "System Restore" utility in XP to restore your Operating System to the point before you install the software.
Hope it helps.
Oct 16, 2010 | Broderbund Computers & Internet
Dell Inspiron 2200 Ram Upgrade Help
I have worked on several I2200s and never encountered the Plate you mentioned. The vented memory door: http://support.dell.com/support/edocs/systems/ins2200/en/SM/upgrades.htm#1084976
Should rotate away from the chassis and expose the memory slot.
Mar 12, 2010 | Dell Inspiron 2200 Notebook
Hi friends i also have cq40-330tu laptop i install xp sucessfull but i install also audio driver in sucessfull but after restart audio driver it's gone some many times i face same problem how to slove this...
compag cq40 support only vista but you can install xp but some driver be not support.
but i can help setup all driver please add my yahoo i will help you do that. My yahoo: nghiemlaptop@yahoo.com
Jan 19, 2010 | Computers & Internet
The initial installation was sucessfull. but after several days I needed to access the e-manual I encountered the following problems. The same e-manual appeared but with a slight difference I could...
If you go into control panel>user accounts, you can then change accounts, or delete any alternate profiles you may have. If you are not logging on as the system administrator, you will run into a host of problems in trying to configure your computer and accessing certain programs.
If you have setup a password during install, you must log on under the administrator profile and enter the password. If you are the only one who uses your computer, you may consider that you do not need alternate profiles at all.
If you need additional information or help, please write back.
Thanks for using Fixya.
Jul 25, 2009 | Computers & Internet
Can't install lexmark x4530...get spooler subsystem app has encountered a problem,etc.
Print Cartridge(s) Missing
The following print cartridges appear to be missing, not detected, or incorrectly installed:
Cartridge on Right
Cartridge on Left
May 21, 2008 | Office Equipment & Supplies
Installing Nero 8
Just down load windows installer 3.1
WindowsInstaller-KB893803-v2-x86.exe and install it on your PC. After installing the above you try installing nero 8.
This will solve the error "Cannot update MSI engine, please update manually".
Oct 15, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
